5682F5_5
5682F5_5
    VCC
    插件
    发光二极管/LED 翠绿色 插件 8.5mcd
5682F5_5 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5682F Series Dual Mount T-1 LED Assembly Description and Features Features • 2 T-1 LEDs mounted in single block saves space and assembly time. • High density only 0.13" wide. • Black plastic mounting block for high contrast ratio. • Meets UL 94V-O and Bellcore flammability specifications . • RoHS Compliant All dimensions in mm. HOLDE R MAT 'L: B LAC K T HE R MOP LAS T IC P OLY E S T E R UL94V -0 14.70 3.80±0.50 Top LE D Available options : • Low current, 5V and 12V built-in resistors . • Bi-color and blue LEDs also offered. • Call factory for ordering information. 3.30 1.50 Refer to "Mounting Hole Pattern 1.pdf" 6.80 8.90 2.30 4.83 4.06 Bottom LE D 6.10 ANODE + Ordering Information:Use chart below to determine model number. LE D R ed 1 G reen 5 Amber 3 Model No. is as follows: 5682F Top LE D _ Y ellow 7 B ottom LE D Example:To order red LED on top and green LED on bottom, the part number would be 5682F1_5. Electro-Optical Characteristics and Ratings P art Number 5682F 1_1 5682F 3_3 5682F 5_5 5682F 7_7 E mitted C olor R ed Amber G reen Y ellow R ated C urrent (mA) 10 10 10 10 T yp. Intensity (mcd) 10.0 6.5 8.5 10.0 C ontinuous F orward C urrent Max. (mA) 25 25 25 20 F orward V oltage T yp. (V ) Max. (V ) R everse B reakdown V oltage Min.(V ) P eak Wavelength (nm) 2.2 2.2 2.3 2.2 3.0 3.0 3.0 3.0 5.0 5.0 5.0 5.0 635 602 565 583 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5682F5_5
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入侧的发光二极管引脚和输出侧的光敏三极管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm。
5682F5_5 价格&库存
很抱歉,暂时无法提供与“5682F5_5”相匹配的价格&库存,您可以联系我们找货
5682F5_5
    5682F5_5
    • 1+52.482631+6.78614
    • 10+39.3327010+5.08582
    • 100+31.57381100+4.08257
    • 500+28.18502500+3.64440
    • 1000+27.083591000+3.50198
    • 2000+26.152302000+3.38156
    库存:656
