engineered to light up your design
www.vcclite.com
1.800.522.5546
T-1 StatusPak™ Circuit Board Indicators
Description and Features
.095±.020
.182/.192
.192
.218
.040
Ø.125
.286
MAX.
.200
.135 MIN.
C AT HODE
C AT HODE
TYP.
.100
.020 T Y P .
.020 S Q.
TYP.
.190±.020
.100
All dimensions in inches.
P rinted C ircuit B oard as s embly has been made fas ter and eas ier than ever before. Now you can mount from one to ten circuit
board indicators , as a s ingle unit, in one eas y s tep.
T -1 S tatus P ak™ is cus tomized to your s pecification. Y ou choos e the number of LE Ds , color s equence and pos ition.
S tatusP ak™ is shipped to you as a complete unit, ready for one-step P C board mounting. Unique snap-together feature allows
you to add or take away S tatusP ak™ modules as needed without any special tooling.
•RoHS Compliant
Refer to Mounting Hole Pattern 1.pdf
ELECTRO-OPTICAL CHARACTERISTICS AND RATINGS
P art Number
E mitted
C olor
Lens
C olor
C MC 01R
C MC 01Y
C MC 01G
C MW01R
C MW01Y
C MW01G
H.E .R ed
Y ellow
H.E .G reen
H.E .R ed
Y ellow
H.E .G reen
C lear
C lear
C lear
R ed
Y ellow
G reen
P ackage
T ype
Non-Diffused
Non-Diffused
Non-Diffused
Diffused
Diffused
Diffused
Luminous Intensity
Min.
(mcd)
24.0
24.0
24.0
3.2
3.2
3.2
F orward V oltage
T yp.
(mcd)
T yp.
(V )
Max.
(V )
60.0
60.0
60.0
20.0
12.5
2.0
2.1
2.2
2.0
2.1
2.5
2.5
2.5
2.5
2.5
12.5
2.2
2.5
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
V iewing
Angle
(degrees)
P eak
Wavelength
(nm)
30
30
30
130
120
120
625
590
565
625
590
565
www.vcclite.com
1.800.522.5546
How to order a Multi Position Assembly
1. Determine the lens type you require:
-diffused or non-diffused
2. Determine the number of positions you require
including any open spaces. (CML does not recommend assemblies of greater than ten positions.)
3. Determine the specific LED required in each position from the table below.
CMC (Non-Diffused)
CMW (Diffused)
R = Ultra Brite Red
Y = Ultra Brite Yellow
G = Ultra Brite Green
X = Open Space
R = Hi-Brite Red
Y = Hi-Brite Yellow
G = Hi-Brite Green
X = Open Space
Example:
C M W - 05 - R Y G G R
Lens Type
# of Positions
LED Sequence
很抱歉,暂时无法提供与“CMC01G”相匹配的价格&库存,您可以联系我们找货
