5310F1
5310F1
    VCC
    LED RED T1 VERTICAL PCB
5310F1 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5310F Series T-1 LED Circuit Board Indicator Description and Features Features • Block mounting, height and spacing alignment saves assembly cost and time. • Standoffs prevent flux entrapment. • Press-in mounting pin secures assembly to PC board while soldering. • RoHS Compliant .115±.015 DIM "A" ±. 020 Housing: Black Nylon,UL94V-O .020 S T AND-OF F F OR P OS T C LE ANING .020 S Q. TYP. Alternate LEDs are available in this package as standard variations. .150 MIN. Refer to “Mounting Hole Pattern 4.pdf” P ANE L ANODE (+) ÿ. 200 ANODE (+) All dimens ions in inches . Electro-Optical Characteristics and Ratings Part Number Color Typ. Intensity (mcd) Rated Current (mA) Continuous Reverse Forward Forward Forward Break-down Current Max. Voltage Typ. Voltage Max. Voltage Min. (V) (V) (mA) (V) 30 2.0 5 3.0 Peak Wavelength (nm) DIM A (inches) 5310F1 Red 10 10 650 .580 5310F3 Amber 7 10 30 2.2 3.0 5 603 .580 5310F5 Green 16 10 30 2.2 3.0 5 562 .580 5310F7 Yellow 6.3 10 30 2.1 3.0 5 585 .580 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5310F1 价格&库存
很抱歉,暂时无法提供与“5310F1”相匹配的价格&库存,您可以联系我们找货
