5640H1
5640H1
    VCC
    LED RED T1-3/4 QUAD RT ANG PCB
5640H1 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5640 Series T-1 3/4 Right Angle 4 Wide LED Assembly Description and Features All dimensions in inches. .990 .210 MAX. .350 .250 TYP. .240 .200 .130 .020 .130 MIN. .200 .100 TYP. ANODE(+) CATHODE(-) .250 TYP. The user who may have a requirement calling for various color / electrical specifications , a part number can be determined by referring to the chart shown below. Model No. is as follows: 5640H Pos. 1 ; Pos. 2 ; Pos. 3 ; Features •Quad assembly with 4 LEDs permits easy installation-assures matched height and center to center spacing, reduces assembly time and costs . •Super Brite LEDs •High contrast ratio. •Low current - only 2mA •Built-in resistor chips - operates off 5 volt or 12 volt supply without external resistor. •Standoffs prevent flux entrapment. •RoHS Compliant Housing: Black Nylon, UL94V-O Refer to “Mounting Hole Pattern 4.pdf” Pos. 4 When specifying all 4 LEDs of the same type Example: 4 each 5 volt red LEDs, the part number is 5640H1-5V When specifying a variety of colors Example: Position 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. All standard voltage. The part number is 5640H5;1;7;3. Alternate LEDs are also available in this package as a standard variation. Electro-Optical Characteristics and Ratings Part Number 1 3 5 7 1LC 5LC 7LC 1-5V 3-5V 5-5V 1-12V LED Emitted Color Red Amber Green Yellow Red Green Yellow Red Amber Green Red Red 1 Typical Intensity (mcd) Rated Current (mA) Continuous Forward Current Max. (mA) 6.3 10.0 10.0 6.3 2.3 2.3 2.1 8 8 8 8 10 10 10 10 2.0 2.0 2.0 10 10 12 12 35.0 35.0 30.0 35.0 7.0 7.0 7.0 15.0 15.0 15.0 20 Amber 3 Green 5 Yellow 7 Forward Voltage Typ. (V) Max. (V) Reverse Breakdown Voltage Min.(V) Peak Wavelength (nm) 2.0 2.0 2.2 2.1 1.8 1.8 1.9 5.0 5.0 5.0 12 3.0 3.0 3.0 3.0 2.7 2.2 2.7 7.5 7.5 7.5 15.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 - 650 608 563 585 635 565 583 635 583 565 635 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5640H1 价格&库存
很抱歉,暂时无法提供与“5640H1”相匹配的价格&库存,您可以联系我们找货
