5332H7
5332H7
    VCC
    LED YELLOW T1-3/4 VERTICAL PCMNT
5332H7 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5332 Series T-1 3/4 Vertical LED Assembly Description and Features Features • Block mounting design assures height and side-by-side spacing-alignment saves assembly costs. • Ultra Brite T-1 3/4 LED lamp-non-diffused high intensity light. • Press-in mounting pin secures assembly to PC board while beingsoldered. • Standoffs prevent flux entrapment. • RoHS Compliant .450±. 010 .190 .100 .150 .020 S T AND-OF F F OR P OS T C LE ANING .020 Housing: Black Nylon, UL94V-O .100 Note: Alternate LEDs are also available in this package as a standard variation. .100 Refer to “Mounting Hole Pattern 3.pdf” All dimensions in inches. ÿ. 290 Electro-Optical Characteristics and Ratings Part Number 5332H1 5332H5 5332H7 Emitted Colo r Red Green Yellow Typical Intensity (mcd) 68 100 160 Rated Current (mA ) 20 20 20 Continuous Forward CurrentMax. (mA) 60 60 60 Forward Voltage Typ. (V) Max. (V) 2.1 2.2 2.2 3.0 3.0 3.0 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. Reverse Breakdown VoltageMin. (V) 5 5 5 Peak Wavelength (nm) 650 563 585 Peak Forward Current at 1MS-300PPS (A) 1.0 .09 1.0
5332H7
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,输入阻抗大于10kΩ,输出阻抗小于100Ω。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN-24封装,尺寸为4mm x 4mm。
5332H7 价格&库存
很抱歉,暂时无法提供与“5332H7”相匹配的价格&库存,您可以联系我们找货
