6300T1
6300T1
    VCC
    LEDSINGLEREDRIGHTANGLESMD
6300T1 数据手册
TM 6300T Series 3mm (T-1) LED SMD Right Angle Circuit Board Indicator 6300T1 - Red Single level Surface Mount CBI, available in five different LED colors LONG LIFE LED Applications • Industrial • Infrastructure • Storage Servers • Switchers • Telecommunications • Medical • Food Service • IoT • Automation & Control Key Features • Elimination of Mixed Technology Boards (SMT and Through-Hole components) • Available in automation-friendly tape and reel • Available in 3 different colors (red, green and yellow) and 2 different bi-colors (red/green and green/yellow) • Made with AlGaAs • Diffused Lens • Viewing Angle: 50 degrees • Moisture Sensitive Level (MSL): 3 • Package: 1000 pcs/reel • Surface mount device • LED Bulb Size: 0.112” (2.85mm) • Compatible with automatic placement equipment • Compatible with infrared and vapor phase solder processes • Black case enhances contrast ratio • Housing material meets UL94V-0 • Lens material meets UL94-HB • Black housing enhances contrast ratio equipment • Compliant with RoHS and REACH requirements the first call for illuminated components www.vcclite.com 1  1.800.522.5546 09/16 Rev 1 Ordering Data Part Number* Color Reel Qty 6300T1 Red 1,000 pcs/reel 6300T5 Green 1,000 pcs/reel 6300T7 Yellow 1,000 pcs/reel 6300T15 Red/Green 1,000 pcs/reel 6300T75 Yellow/Green 1,000 pcs/reel *Please consult the specific product data sheet for others colors Product Dimensions Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25(0.01") unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice 4. The device has a single mounting surface. The device must be mounted according to the specifications. the first call for illuminated components www.vcclite.com 2 1.800.522.5546 09/16 Rev 1 Product Specifications Lens Type Emitting Color (Material) Part No. 6300T1 lv (mcd) [2] @ 10 mA Super Bright Red (AlGaAs) Viewing Angle [1] Min. Typ. 2 θ 1/2 8 18 50° Diffused Notes: 1. θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 of the optical peak value. 2. Luminous intensity / luminous Flux: +/-15%. 3. Luminous intensity value is traceable to CIE127-2007 standards. Electrical / Optical Characteristics at TA=25°C Symbol Parameter Emitting Color Typ. λpeak Peak Wavelength Super Bright Red λD [1] Dominant Wavelength Δλ1/2 Max. Units Test Conditions 655 nm IF=10mA Super Bright Red 640 nm IF=10mA Spectral Line Half-width Super Bright Red 20 nm IF=10mA C Capacitance Super Bright Red 45 pF VF=0V;f=1MHz VF [2] Forward Voltage Super Bright Red 1.8 2.5 V IF=10mA IR Reverse Current Super Bright Red 10 uA VR=5V Notes: 1. Wavelength: +/-1nm. 2. Forward Voltage: +/-0.1V. 3. Wavelength value is traceable to CIE127-2007 standards. 4. Excess driving current and / or operating temperature higher than recommended conditions may result in severe light degradation or premature failure. Absolute Maximum Ratings at TA=25°C Parameter Values Units Power dissipation 75 mW DC Forward Current 30 mA Peak Forward Current [1] 155 mA 5 V Reverse Voltage Operating Temperature -40°C To +85°C Storage Temperature -40°C To +100°C Notes: 1. 1/10 Duty Cycle, 0.1ms Pulse Width. 2. Relative humidity levels maintained between 40% and 60% in production area are recommended to avoid the build-up of static electricity – Ref JEDEC/JESD625-A and JEDEC/J-STD-033. the first call for illuminated components www.vcclite.com 3 1.800.522.5546 09/16 Rev 1 Relative Radiant Intensity Product Specifications Luminous Intensity Relative Value at IF=10ma Forward Current (mA) wavelength λ (nm) Relative Intensity vs. Wavelength 20 16 12 8 4 0 1.5 1.7 1.9 2.1 Relative Luminous Intensity Forward Current (mA) 30 20 10 40 60 80 1.0 0.5 0 4 8 12 16 20 IF - Forward Current (mA) Luminous Intensity vs. Forward Current 40 20 1.5 0 50 0 2.0 2.3 2.5 Forward Voltage(V) Forward Current vs. Forward Voltage 0 2.5 100 2.5 2.0 1.5 1.0 0.5 0 -40 -20 Ambient Temperature TA (°C) Forward Current vs. Derating Curve 0 20 40 60 80 Ambient Temperature TA (°C) Luminous Intensity vs. Ambient Temperature Test Conditions : IF=10mA Ta=25°C RH
6300T1 价格&库存
很抱歉,暂时无法提供与“6300T1”相匹配的价格&库存,您可以联系我们找货
6300T1
  • 1000+8.865421000+1.14533
