TM
6300T Series 3mm (T-1) LED
SMD Right Angle
Circuit Board Indicator
6300T1 - Red
Single level Surface Mount CBI, available in five different LED colors
LONG LIFE
LED
Applications
• Industrial
• Infrastructure
• Storage Servers
• Switchers
• Telecommunications
• Medical
• Food Service
• IoT
• Automation & Control
Key Features
• Elimination of Mixed Technology Boards
(SMT and Through-Hole components)
• Available in automation-friendly tape and
reel
• Available in 3 different colors (red, green
and yellow) and 2 different bi-colors
(red/green and green/yellow)
• Made with AlGaAs
• Diffused Lens
• Viewing Angle: 50 degrees
• Moisture Sensitive Level (MSL): 3
• Package: 1000 pcs/reel
• Surface mount device
• LED Bulb Size: 0.112” (2.85mm)
• Compatible with automatic placement
equipment
• Compatible with infrared and vapor phase
solder processes
• Black case enhances contrast ratio
• Housing material meets UL94V-0
• Lens material meets UL94-HB
• Black housing enhances contrast ratio
equipment
• Compliant with RoHS and REACH
requirements
the first call for illuminated components
www.vcclite.com
1
1.800.522.5546
09/16 Rev 1
Ordering Data
Part Number*
Color
Reel Qty
6300T1
Red
1,000 pcs/reel
6300T5
Green
1,000 pcs/reel
6300T7
Yellow
1,000 pcs/reel
6300T15
Red/Green
1,000 pcs/reel
6300T75
Yellow/Green
1,000 pcs/reel
*Please consult
the specific product
data sheet for others colors
Product Dimensions
Notes:
1. All dimensions are in millimeters (inches).
2. Tolerance is ±0.25(0.01") unless otherwise noted.
3. The specifications, characteristics and technical data described in the datasheet are subject to
change without prior notice
4. The device has a single mounting surface. The device must be mounted according to the
specifications.
www.vcclite.com
2
1.800.522.5546
09/16 Rev 1
Product Specifications
Lens Type
Emitting Color (Material)
Part No.
6300T1
lv (mcd) [2]
@ 10 mA
Super Bright Red (AlGaAs)
Viewing
Angle [1]
Min.
Typ.
2 θ 1/2
8
18
50°
Diffused
Notes:
1. θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 of the optical peak value.
2. Luminous intensity / luminous Flux: +/-15%.
3. Luminous intensity value is traceable to CIE127-2007 standards.
Electrical / Optical Characteristics at TA=25°C
Symbol
Parameter
Emitting Color
Typ.
λpeak
Peak Wavelength
Super Bright Red
λD [1]
Dominant Wavelength
Δλ1/2
Max.
Units
Test Conditions
655
nm
IF=10mA
Super Bright Red
640
nm
IF=10mA
Spectral Line Half-width
Super Bright Red
nm
IF=10mA
C
Capacitance
Super Bright Red
45
pF
VF=0V;f=1MHz
VF [2]
Forward Voltage
Super Bright Red
1.8
2.5
V
IF=10mA
IR
Reverse Current
Super Bright Red
10
uA
VR=5V
Notes:
1. Wavelength: +/-1nm.
2. Forward Voltage: +/-0.1V.
3. Wavelength value is traceable to CIE127-2007 standards.
4. Excess driving current and / or operating temperature higher than recommended conditions may result in severe
light degradation or premature failure.
Absolute Maximum Ratings at TA=25°C
Parameter
Values
Units
Power dissipation
75
mW
DC Forward Current
30
mA
Peak Forward Current [1]
155
mA
5
V
Reverse Voltage
Operating Temperature
-40°C To +85°C
Storage Temperature
-40°C To +100°C
Notes:
1. 1/10 Duty Cycle, 0.1ms Pulse Width.
2. Relative humidity levels maintained between 40% and 60% in production area are recommended to avoid the
build-up of static electricity – Ref JEDEC/JESD625-A and JEDEC/J-STD-033.
www.vcclite.com
3
1.800.522.5546
09/16 Rev 1
Relative Radiant Intensity
Luminous Intensity
Relative Value at IF=10ma
Forward Current (mA)
wavelength λ (nm)
Relative Intensity vs. Wavelength
12
8
4
1.7 1.9
2.1
Relative Luminous Intensity
30
40
60
80
1.0
0.5
8
12
16
IF - Forward Current (mA)
Luminous Intensity vs. Forward Current
40
2.3 2.5
Forward Voltage(V)
Forward Current vs. Forward Voltage
100
2.5
2.0
1.5
1.0
0.5
Ambient Temperature TA (°C)
Forward Current vs. Derating Curve
60
80
Luminous Intensity vs. Ambient Temperature
Test Conditions : IF=10mA Ta=25°C RH
很抱歉,暂时无法提供与“6300T15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.349051+5.21271
- 10+29.8272010+3.85339
- 100+23.64702100+3.05497
- 500+20.93875500+2.70509
- 国内价格 香港价格
- 1000+20.058191000+2.59133
- 2000+19.313212000+2.49508
- 3000+18.931933000+2.44583
