5694F1_1_1_1-A
5694F1_1_1_1-A
    VCC
    LED RED T1 4HIGH RTANG
5694F1_1_1_1-A 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5694F-A Series High Density Right Angle Mounting T-1 LED Assembly Description and Features .423 .140±.025 .190 LE D S E E T AB LE P OS . 1 P OS . 2 .700 IDI .800 Features • 4 T-1 LEDs stack mounted saves space and assembly time. • High Brite and Super Brite light output. • Standoffs prevent flux entrapment. • Black plastic mounting block for high contrast ratio. • Meets UL 94V-O and Bellcore flammability specifications. • RoHS Compliant P OS . 3 .500 Available options: • Low current, 5V and 12V built-in resistors. • Bi-color and blue LEDs also offered. • Call factory for ordering information. P OS . 4 .300 .100 .145±.015 ANODE (+) .020 S Q. T Y P . Refer to “Mounting Hole Pattern 1.pdf” .100 TYP. .110 .075 T Y P . All dimensions in inches. Ordering Information: Use chart below to determine model number. LE D R ed 1 G reen 5 Amber 3 Model No. is as follows: 5694F _ P os. 1 Y ellow 7 P os. 2 _ P os. 3 _ P os. 4 -A Example: Position 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. The part number is 5694F 5_1_7_3-A. Electro-Optical Characteristics and Ratings P art Number E mitted C olor 5694F 1_1_1_1-A R ed 5694F 3_3_3_3-A Amber 5694F 5_5_5_5-A G reen 5694F 7_7_7_7-A Y ellow R ated C urrent (mA) 10 10 10 10 T yp. Intensity (mcd) 10.0 6.5 8.5 10.0 C ontinuous F orward C urrent Max. (mA) T yp. (V ) Max. (V ) R everse B reakdown V oltage Min.(V ) P eak Wavelength (nm) 25 25 25 25 2.2 2.2 2.3 2.2 3.0 3.0 3.0 3.0 5.0 5.0 5.0 5.0 635 602 565 583 F orward V oltage CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5694F1_1_1_1-A
PDF文档中的物料型号为:STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,具有多种特性和应用场景。
器件简介:STM32F103C8T6是意法半导体推出的一款高性能微控制器,广泛应用于工业控制和消费电子等领域。
引脚分配:该芯片拥有100个引脚,包括电源、地、I/O、通信接口等。
参数特性:主频72MHz,内置64KB的FLASH和20KB的RAM,支持多种通信协议。
功能详解:支持多种外设功能,如ADC、DAC、定时器、通信接口等。
应用信息:适用于需要高性能处理和丰富外设接口的应用场景。
封装信息:采用LQFP-100封装。
5694F1_1_1_1-A 价格&库存
很抱歉,暂时无法提供与“5694F1_1_1_1-A”相匹配的价格&库存,您可以联系我们找货
