5307H7
5307H7
    VCC
    LED YELLOW T1-3/4 RT ANG PCB
5307H7 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5307 Series T-1 3/4 Right Angle LED Assembly Description and Features All dimensions in inches. .210 .360 .240 .130 MIN. .200 MAX. .240 .020 .110 .100 ANODE (+) Features • Press-in pin design holds block in place while being soldered. • Block mounting, low profile design, height & spacing alignment save assembly cost. • Super Brite LEDs-high intensity light output, diffused lens. • Built-in resistor chip operates off 5V supply without external resistor. • Standoffs prevent flux entrapment. • RoHS Compliant Housing: Black Nylon, UL94V-O Alternate LEDs are also available in this package as a standard variation. Refer to “Mounting Hole Pattern 4.pdf” Electro-Optical Characteristics and Ratings Part Number Color Typ. Intensity (mcd) Rated Current (mA) Continuous Forward CurrentMax. (mA) 60 Forward VoltageTyp. (V) Forward VoltageMax. (V) PeakForward Current@1ms300pps(A) Reverse Break-down VoltageMin. (V) 5 Peak Wavelength (nm) Red 6.3 10 2.0 3.0 1.0 5307H3 Amber 10 10 60 2.0 3.0 1.0 5 608 5307H5 Green 10 10 60 2.2 3.0 .09 5 563 5307H7 Yellow 6.3 10 60 2.1 3.0 1.0 5 585 5307H1LC Red 2.3 2.0 7 1.8 2.2 .007 5 635 5307H5LC Green 2.3 2.0 7 1.8 2.2 .007 5 565 5307H7LC Yellow 2.1 2.0 7 1.9 2.7 .007 5 583 5307H1 650 5307H1-5V Red 8 10 15 5 7.5 - 5 635 5307H3-5V Amber 8 10 15 5 7.5 - 5 583 Green 8 12 15 5 7.5 - 5 565 5307H5-5V CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5307H7
物料型号:5307系列T-1 3/4直角LED组件。
器件简介:具有压入式引脚设计,能在焊接时固定模块;模块安装、低轮廓设计,节省组装成本;超亮LED,高亮度输出,散光透镜;内置电阻芯片,可在5V供应下操作而无需外部电阻;支架防止助焊剂滞留。符合RoHS标准。
引脚分配:文档未明确列出引脚分配图,但提到了压入式引脚设计。
参数特性:提供了不同颜色LED的典型强度、额定电流、连续正向电流最大值、正向电压典型值、正向电压最大值、1ms-300pps时的峰值正向电流、反向击穿电压最小值和峰值波长。
功能详解:文档强调了其低轮廓设计、内置电阻芯片、超亮LED和支架防止助焊剂滞留的特点。
应用信息:适用于需要高亮度输出和内置电阻的LED应用。
封装信息:外壳材料为黑色尼龙,符合UL94V-0标准。文档还提到了其他标准变化的LED选项。
5307H7 价格&库存
很抱歉,暂时无法提供与“5307H7”相匹配的价格&库存,您可以联系我们找货
