engineered to light up your design
www.vcclite.com
1.800.522.5546
5320 & 5322 Series T-1 Right Angle LED Assembly
Description and Features
.180
MAX.
.130±.020
.190 MAX.
.090
.130 MAX.
.020
F LUX WAS H
S T AND-OF F
T -1 LE D
S UP E R -B R IT E
DIM A
.100
.150 MIN.
Note: Alternate LEDs are also available
ANODE
in this package as a standard variation.
.040
All dimensions in inches.
5320
5322
Features
• T-1 LED lamp right angle mounted,
preassembled and tested.
• Black Nylon block, high contrast ratio,
height and spacing alignment - saves
assembly cost.
• High Brite and Super Brite LEDs-diffused lens.
• Mounting pins secure block to PC board
while soldering.
• 2 different board heights to select from.
• RoHS Compliant
Refer to “Mounting Hole Pattern 1.pdf”
DIM A
.35 (8.9)
.25 (6.4)
Electro-Optical Characteristics and Ratings
P art Number
5322F 1
5322F 5
5322F 7
5320F 1
5320F 5
5320F 7
E mitted
C olor
R ed
G reen
Y ellow
R ed
G reen
Y ellow
T ypical
Intensity
(mcd)
10
16
6.3
10
16
6.3
R ated
C urrent
(mA)
10
10
10
10
10
10
C ontinuous
F orward
C urrent Max.
(mA)
30
30
30
30
30
30
T yp.
(V )
Max.
(V )
R everse
B reakdown
V oltage Min.
(V )
2.0
2.2
2.1
2.0
2.2
2.1
3.0
3.0
3.0
3.0
3.0
3.0
5
5
5
5
5
5
F orward V oltage
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
P eak
Wavelength
(nm)
650
562
585
650
562
585
