6200T7
6200T7
    VCC
    SMD
    LED YELLOW 1.65MM RT ANGLE SMD
6200T7 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 6200T Series Bright Pipes™ Right Angle Sub-Miniature SMT LED Assemblies Description and Features • Tape and reel packaged for high-speed pick-and-place installation. • Packaged 1000 pieces per reel. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Ideal for backlighting applications. • Wide angle view. • Direct-view optics provide smooth uniform appearance. • High output. • Low current (2mA). • Built-in resistor for 5V and 5V low current. • 100K+ hour MTBF. • Easy post-reflow solder joint inspection. • No adhesives. • UL94V-O rated housing of black polyphenylen sulfide. • RoHS Compiant .240±.005 .180±.003 ANODE(+) .173±.003 TERMINAL .243 .236 .185 .170 + .011±.002 ANODE(+) LED .134±.012 Refer to “Solder Pad Geometry 1.pdf” .049±.005 All dimensions in inches. .119±.005 Electro-Optical Characteristics and Ratings Part Number Rated Current (mA) Luminous Forward Forward Peak Intensity Voltage Typ. Voltage Max. Wavelength (nm) (V) Typ. (mcd) (V) Color Lens Color 6200T1 Red Red 10 5.0 2.2 3.0 635 6200T5 Green Green 10 4.0 2.3 3.0 565 6200T7 Yellow Yellow 10 3.8 2.2 3.0 585 6200T1LC Red Red 2.0 .5 1.8 2.2 635 6200T5LC Green Green 2.0 1.2 1.8 2.2 565 6200T7LC Yellow Yellow 2.0 .5 1.9 2.7 583 6202T1-5V Red Red 10 5.0 5.0 6.0 635 6202T5-5V Green Green 10 5.0 5.0 6.0 583 6202T1-5VLC Red Red 3.5 2.0 5.0 6.0 635 6202T5-5VLC Green Green 3.5 2.0 5.0 6.0 583 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
6200T7 价格&库存
很抱歉,暂时无法提供与“6200T7”相匹配的价格&库存,您可以联系我们找货
