LTL-2785Y
LTL-2785Y
    LITE-ON(光宝)
    插件-16,2.54mm
    发光二极管/LED 插件-16,2.54mm 16mcd 插件
LTL-2785Y 数据手册
Light Bars LTL-2000 Series Features Rectangular light bar. Choices of three bright colors-green/yellow/high efficiency red. Large, bright, uniform light emitting areas. Low power requirement. Excellent ON-OFF contrast. Can be used with panel and legend mount. Easy mounting on P.C. board. Categorized for light output. Yellow and green categorized for dominant wavelength. Description The LTL-2300/2400/2500/2600/2700/2800 series light bars are rectangular light sources designed for a variety of applications where a large bright source of light is required. These light bars are configured in single-in-line and dualin-line packages. The green series devices utilize LED chips which are made from GaP on a transparent GaP substrate. The yellow and high efficiency red series devices utilize LED chips which are made trom GaAsP on a transparent GaP substrate. All devices have white bar. Devices Part No. Size of Light Emitting Areas Green Yellow Hi. Eff. Red 2500G 2400Y 2300HR 8.89mm 2550G 2450Y 2350HR 19mm 2800G 2700Y 2600HR 8.89mm 3.81mm(.350 in 2855G 2755Y 2655HR 8.89mm 2820G 2720Y 2620HR 8.89mm 2885G 2785Y 2685HR 8.89mm 3.81mm(.350 in 3.76mm(.748 in .150 in.) .148 in.) Package Dimension A 9-36 A B B .150 in.) C C 8.89mm(.350 in .350 in.) D D 3.81mm(.350 in .150 in.) E E F F 19.05mm(.350 in .750 in.) Package Dimensions A. LTL-2300/2400/2500 Internal Circuit Diagram B. LTL-2350/2450/2550 D. LTL-2655/2755/2855 E. LTL-2620/2720/2820 F. LTL-2685/2785/2885 Notes : All dimensions are in millimeters (inches). Tolerance: DISPLAYS C. LTL-2600/2700/2800 0.25mm (0.010") unless otherwise noted. Pin Connection Connection Pin No. A LTL-2300/2400/2500 B LTL-2350/2450/2550 C LTL-2600/2700/2800 D LTL-2655/2755/2855 1 Cathode A Cathode A Cathode A Cathode A 2 Anode A Anode A Anode A Anode A 3 Cathode B Cathode B Anode B Anode B 4 Anode B Anode B Cathode B Cathode B 5 Cathode C Cathode C Cathode C 6 Anode C Anode C Anode C 7 Cathode D Anode D Anode D 8 Anode D Cathode D Cathode D 9-37 Connection Pin No. E. LTL-2620/2720/2820 F. LTL-2685/2785/2885 1 Cathode A Cathode A 2 Anode A Anode A 3 Anode B Anode B 4 Cathode B Cathode B 5 Cathode C Cathode C 6 Anode C Anode C 7 Anode D Anode D 8 Cathode D Cathode D 9 Cathode E Cathode E 10 Anode E Anode E 11 Anode F Anode F 12 Cathode F Cathode F 13 Cathode G Cathode G 14 Anode G Anode G 15 Anode H Anode H 16 Cathode H Cathode H Internal Circuit Diagrams A. LTL-2300/2400/2500 B. LTL-2350/2450/2550 C. LTL-2600/2700/2800 D. LTL-2655/2755/2855 E. LTL-2620/2720/2820 F. LTL-2685/2785/2885 Absolute Maximum Ratings at Ta=25 Green Yellow Hi.- Eff. Red Unit Power Dissipation Per Chip 75 60 75 mW Peak Forward Current Per Chip (1/10 Duty Cycle, 0.1ms Pulse Width) 100 80 100 mA Continuous Forward Current Per Chip Derating Linear from 25 Per Chip 25 0.33 20 0.27 25 0.33 mA mA/ 5 5 Parameter Reverse Voltage Per Chip -35 to +85 Storage Temperature Range -35 to +85 Solder Temperature 1/16 Inch Below Seating Plane for 3 Seconds at 260 9-38 5 Operating Temperature Range V Electrical/Optical Characteristics at Ta=25 Parameter Symbol Unit Test Condition mcd IF=10mA 635 nm IF=20mA 40 nm IF=20mA 623 nm IF=20mA V IF=20mA Min. Typ. 2300 1.4 4.2 2350 3.5 8 1.4 4.2 4.2 LTL- Average Luminous 2600 IV Intensity Per Bar 2620 1.4 2655 3.5 8 2685 7 16 P Peak Emission Wavelength Spectral Line Half-Width d Dominant Wavelength Forward Voltage, and Bar VF Reverse Current, and Bar IR 2.0 Max. 2.6 100 A VR=5V DISPLAYS Hi.-Eff Red LTL-2300HR/2600HR Yellow LTL-2400Y/2700Y Parameter Symbol Unit Test Condition mcd IF=10mA 585 nm IF=20mA 35 nm IF=20mA 588 nm IF=20mA V IF=20mA Min. Typ. 2400 1.4 4.2 2450 3.5 8 1.4 4.2 4.2 LTL- Average Luminous 2700 IV Intensity Per Bar 2720 1.4 2755 3.5 8 2785 7 16 P Peak Emission Wavelength Spectral Line Half-Width d Dominant Wavelength Forward Voltage, and Chip VF Reverse Current, and Chip IR 2.1 Max. 2.6 100 A VR=5V Green LTL-2500G/2800G Parameter LTL- Symbol Unit Test Condition mcd IF=10mA 565 nm IF=20mA 30 nm IF=20mA 569 nm IF=20mA V IF=20mA Min. Typ. 2500 1.4 4.2 2550 3.5 8 1.4 4.2 4.2 Average Luminous 2800 Intensity Per Bar 2820 1.4 2855 3.5 8 2885 7 16 Peak Emission Wavelength IV P Spectral Line Half-Width Dominant Wavelength d Forward Voltage, and Chip VF Reverse Current, and Chip IR 2.1 Max. 2.6 100 A VR=5V Notes: 1.Clean only in water, isopropanol,ethanol,freon TF (or equivalent). 2.Luminous intensity is measured with a light sensor and filter combination that approximates the CIE (Commision Internationale De L’Eclairage)eye-response curve. 9-39 Typical Electrical/Optical Characteristic Curves (25 Ambient Temperature Unless Otherwise Noted) 9-40
LTL-2785Y 价格&库存
很抱歉,暂时无法提供与“LTL-2785Y”相匹配的价格&库存,您可以联系我们找货
