engineered to light up your design
www.vcclite.com
1.800.522.5546
5694F-A Series High Density Right Angle Mounting T-1 LED Assembly
Description and Features
.423
.140±.025
.190
LE D
S E E T AB LE
P OS . 1
P OS . 2
.700
IDI
.800
Features
• 4 T-1 LEDs stack mounted saves
space and assembly time.
• High Brite and Super Brite light output.
• Standoffs prevent flux entrapment.
• Black plastic mounting block for high
contrast ratio.
• Meets UL 94V-O and Bellcore flammability
specifications.
• RoHS Compliant
P OS . 3
.500
Available options:
• Low current, 5V and 12V built-in resistors.
• Bi-color and blue LEDs also offered.
• Call factory for ordering information.
P OS . 4
.300
.100
.145±.015
ANODE (+)
.020 S Q. T Y P .
Refer to “Mounting Hole Pattern 1.pdf”
.100
TYP.
.110
.075 T Y P .
All dimensions in inches.
Ordering Information: Use chart below to determine model number.
LE D
R ed
1
G reen
5
Amber
3
Model No. is as follows: 5694F
_
P os. 1
Y ellow
7
P os. 2
_
P os. 3
_
P os. 4
-A
Example: Position 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. The part number is 5694F 5_1_7_3-A.
Electro-Optical Characteristics and Ratings
P art Number
E mitted
C olor
5694F 1_1_1_1-A R ed
5694F 3_3_3_3-A Amber
5694F 5_5_5_5-A G reen
5694F 7_7_7_7-A Y ellow
R ated
C urrent
(mA)
10
10
10
10
T yp.
Intensity
(mcd)
10.0
6.5
8.5
10.0
C ontinuous
F orward
C urrent Max.
(mA)
T yp.
(V )
Max.
(V )
R everse
B reakdown
V oltage Min.(V )
P eak
Wavelength
(nm)
25
25
25
25
2.2
2.2
2.3
2.2
3.0
3.0
3.0
3.0
5.0
5.0
5.0
5.0
635
602
565
583
F orward V oltage
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5694F1_7_5_5-A”相匹配的价格&库存,您可以联系我们找货
