5684F3_5_3_3
5684F3_5_3_3
    VCC
    LED QUAD 2X2 AMB/RED/AMB/AMB PCB
5684F3_5_3_3 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5684F Series PC Board Quad Array T-1 LEDs Description and Features All dimensions in inches. HOLDE R MAT 'L: B LAC K T HE R MOP LAS T IC P OLY E S T E R UL94V -0 .580 .140 LE D (4) .260 .200 Available options : • Low current, 5V and 12V built-in resistors . • Bi-color and blue LEDs also offered. • Call factory for ordering information. .070 Refer to “Mounting Hole Pattern 2.pdf” .090 .350 Features • 4 T-1 LEDs mounted in single block • High density - only 0.26" wide • Black plastic mounting block for high contrast ratio. • Meets UL 94V-O and Bellcore flammability specifications . • RoHS Compliant .270 .130 .240 Pos # 2 Pos #1 Pos # 4 Pos # 3 ANODE (+) Ordering Information: Use chart below to determine model number. LE D R ed 1 G reen 5 Amber 3 Model No. is as follows: 5684F P os. 1 _ Y ellow 7 P os. 2 _ P os. 3 _ P os. 4 E xample: P osition 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. The part number is 5684F 5_1_7_3. Electro-Optical Characteristics and Ratings P art Number 5684F 1_1_1_1 5684F 3_3_3_3 5684F 5_5_5_5 5684F 7_7_7_7 E mitted C olor R ed Amber G reen Y ellow R ated C urrent (mA) 10 10 10 10 T yp. Intensity (mcd) 10 6.5 8.5 10 C ontinuous F orward C urrent Max. (mA) T yp. (V ) Max. (V ) R everse B reakdown V oltage Min.(V ) P eak Wavelength (nm) 25 25 25 25 2.2 2.2 2.3 2.2 3.0 3.0 3.0 3.0 5.0 5.0 5.0 5.0 635 602 565 583 F orward V oltage CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5684F3_5_3_3 价格&库存
很抱歉,暂时无法提供与“5684F3_5_3_3”相匹配的价格&库存,您可以联系我们找货
