COM-14000
COM-14000
    SPARKFUNELECTRONICS
    COM-14000
COM-14000 数据手册
BL Series of LED Bargraph Indicator Device BL 48 Segments 100 mm LED Linear Array BL48-1005MFA03 BL48-1005MFK03 M Description The BL series of LED Bargraph display, using high brightness LED chips and semiconductor encapsulations processing technology , is the i d e a l d i s p l a y d e v i c e t o r e p l a c e m o v i n g c o il indicators. Widely used in electronic display meters and instruments. The feature is as follows. Features The use of sub-block scattering techniques, wide angle of view Clearly display,uniform brightness Full color display Antimagnetic,aseismatic,impact resistance High reliability,maximum mean life Absolute Maximum Rating ( TA = 25 ℃ ) Symbol IF VR PW TJ TStg Peak forward current Reverse voltage Power dissipation Operating temperature range Storage temperature range Soldering time at 260℃ Typ. Min. 30 80 5 0.2 ( F.S.) -25 -40 Units mA V W Max. 100 0.3 70 85 ℃ ℃ 3 s ec Electro- optical Characteristics ( TA = 25 ℃ ) Symbol Red (E80) 625nm 80mcd 2.0V λP Peak wavelength Segment brightness Forward voltage IV VF Http://www.barmeter.com Green(G60) Blue(B140) 570nm 60mcd 2.0V 464nm 140mcd 3.2V Http://www.barmeter.com Test condition IF = 20mA IF = 20mA IF = 20mA Http://www.barmeter.com Dime nsion and Circuit Pin1 Pin13 Pi n 25 Pin14 B1 B2 B3 G1 G2 G3 R3 R2 R1 3.3 101.4+ - 0.3 BL48-1005MFA03 Segment1 1.2 9.0 25- 0.5 C2 C15 C16 6.73 2.54x33=83.82 Segment 1 Segment48 C1 B1 B2 B3 G1 G2 G3 R3 R2 R1 Segment 48 99 + - 0.2 Pin25 BL48-1005MFK03 4.5 8.5 6.3 Pin14 0.85 2.1 Pin1 Pin13 Segment1 Segment48 C1 Unit:mm C2 C15 C16 Pin Definition Pin No. 1 2 3 4 5 B3 C1 C3 C4 C6 6 7 G2 B1 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 R3 G3 R1 C10 C13 C14 C16 R B a r m e t e r E l e c t r o n i c s Co . B2 C15 G1 R2 C12 C11 C9 C8 C7 C5 C2 TEL: 86 - 2 1 - 68065675 ,68065 676 FAX:86 - 2 1 - 68065673 No.5998 Yanggao R d ( S ) .S hanghai Http:// www. barmeter. com
COM-14000 价格&库存
很抱歉,暂时无法提供与“COM-14000”相匹配的价格&库存,您可以联系我们找货
