5306H3
5306H3
    VCC
    LED AMBER T1-3/4 RT ANG PCB
5306H3 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5306 Series T-1 3/4 Right Angle LED Assembly Description and Features Features • Block mounting, low profile design, and height and spacing alignment saves assembly cost and time. • Super Brite LEDs • Built-in resistor operates directly off 5V supply without external resistor. • Standoffs prevent flux entrapment. • RoHS Compliant .36 0 .200 .240 .200 MAX. .430 .300 .130 MIN. .020 Housing: Black Nylon, UL94V-O .200 .100 Alternate LEDs are also available in this package as a standard variation. All dimens ions in inches . ANODE (+) Electro-Optical Characteristics and Ratings Continuous Forward Forward Peak Forward Forward Voltage Max. Current @ 1msVoltage Typ. Current Max. (V) (V) 300pps (A) (mA) 60 1.0 2.0 3.0 60 1.0 2.0 3.0 Typ. Intensity (mcd) Rated Current (mA) Red 6.3 10 5306H3 Amber 10 10 5306H5 Green 10 10 60 2.2 5306H7 Yellow 6.3 10 60 5306H1LC Red 2.3 2.0 5306H5LC Green 2.3 5306H7LC Yellow 2.1 Part Number Color 5306H1 Reverse Break-down Peak Voltage Min. Wavelength (nm) (V) 5 650 5 608 3.0 .09 5 563 2.1 3.0 1.0 5 585 7 1.8 2.2 .007 5 635 2.0 7 1.8 2.2 .007 5 565 2.0 7 1.9 2.7 .007 5 583 5306H1-5V Red 8 10 15 5 7.5 - 5 635 5306H3-5V Amber 8 10 15 5 7.5 - 5 583 Green 8 10 15 5 7.5 - 5 565 5306H5-5V CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5306H3 价格&库存
很抱歉,暂时无法提供与“5306H3”相匹配的价格&库存,您可以联系我们找货
