5372T3-5V
5372T3-5V
    VCC
    LED AMBER T-3/4 VERT 5V PCB
5372T3-5V 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5370 Series T3/4 Right Angle LED Assembly Description and Features .200 .040 .090 .010 .130 Ø. 080 . .200 .250 + .030 LE D .130 MIN. All dimensions in inches. Features • Sub-miniature 2.0 mm LED vertical mounted to simplify PC board mounting, saves assembly time and costs. • Can be stacked side by side on 0.100" centers. • High Brite LEDs, high intensity light output, diffused lens. • Black Nylon plastic enhances contrast ratio. • Low current,only 2 mA. • Built-in resistor chip. Operates off 5 volts without external resistor. • RoHS Compliant Electro-Optical Characteristics and Ratings P art Number 5370T1 5370T5 5370T7 5370T1LC 5370T5LC 5370T7LC 5372T1-5V 5372T3-5V 5372T5-5V 5372T1-5VLC 5372T3-5VLC 5372T5-5VLC E mitted C olor R ed G reen Y ellow R ed G reen Y ellow R ed Amber G reen R ed Amber G reen T ypical Intensity (mcd) R ated C urrent (mA) 5.0 4.0 3.8 .5 1.2 .5 5.0 5.0 5.0 2.0 4.0 2.0 10 10 10 2.0 2.0 2.0 9.6 10 10 3.5 3.5 3.5 C ontinuous F orward C urrent Max. (mA) 30 30 20 7 7 7 13 13 13 5 5 5 P eak F orward C urrent At 1ms-300 P P S (A) T yp. (V ) Max. (V ) .06 .06 .06 .007 .007 .007 - 2.2 2.3 2.2 1.8 1.8 1.9 5.0 5.0 3.0 3.0 3.0 2.2 2.2 2.7 6.0 6.0 - 5.0 5.0 5.0 5.0 6.0 6.0 6.0 6.0 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. F orward V oltage R everse B reakdown V oltage Min. (V ) 5 5 5 5 5 5 5 5 5 5 5 5 P eak Wavelength (nm) 635 565 583 635 565 583 635 565 583 635 565 583
5372T3-5V 价格&库存
很抱歉,暂时无法提供与“5372T3-5V”相匹配的价格&库存,您可以联系我们找货
