6321F7
6321F7
    VCC
    LED Circuit Board Indicator Single Yellow Tinted 2V 10mA Round with Domed Top, 3mm (T-1) Through Hol...
6321F7 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 6321F Series T-1 Circuit Board Indicator Description and Features .100 TYP. .200 TYP. All dimensions in inches. OR IE NT AT ION NOT C H DE NOT E S C AT HODE (-) .200 .100 TYP. LE D T -1 S IZE C OLOR AS S P E C IF IE D .100±.015 TYP. HOUS ING : B LAC K T HE R MOP LAS T IC (UL94-V Ø) .420 .150±.015 Features • T-1 LED block mounting design assures height and side-by-side spacing alignment saves assembly costs. • Blocks have interlock feature which allows for multi LED arrays. • Black plastic mounting block provides high contrast ratio. • High Brite and Super Brite light output. • Standoffs prevent flux entrapment. • Meets UL 94V-O and Bellcore flammability specifications. • RoHS Compliant Available options: • Low current, 5 Volt and 12 Volt built-in resistors. • Bicolor and blue LEDs also offered. Call factory for ordering information. Refer to “Mounting Hole Pattern 2.pdf” Electro-Optical Characteristics and Ratings Part Number Emitted Colo r Typical Intensity (mcd) Rated Current (mA ) Continuous Forward Current Max. (mA) Forward Voltage Typ. (V) Max. (V) Reverse Breakdown Voltage Min. (V) Peak Wavelength (nm) 6321F1 Red 10 10 25 6.5 10 25 3.0 3.0 635 Amber 1.9 2.2 5 6321F3 5 602 6321F5 Green 8.5 10 25 2.1 3.0 5 565 6321F7 Yellow 10 10 25 2.0 3.0 5 583 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
6321F7 价格&库存
很抱歉,暂时无法提供与“6321F7”相匹配的价格&库存,您可以联系我们找货
