engineered to light up your design
www.vcclite.com
1.800.522.5546
5682F Series Dual Mount T-1 LED Assembly
Description and Features
Features
• 2 T-1 LEDs mounted in single block
saves space and assembly time.
• High density only 0.13" wide.
• Black plastic mounting block for high
contrast ratio.
• Meets UL 94V-O and Bellcore
flammability specifications .
• RoHS Compliant
All dimensions in mm.
HOLDE R
MAT 'L: B LAC K T HE R MOP LAS T IC
P OLY E S T E R UL94V -0
14.70
3.80±0.50
Top LE D
Available options :
• Low current, 5V and 12V built-in resistors .
• Bi-color and blue LEDs also offered.
• Call factory for ordering information.
3.30
1.50
Refer to "Mounting Hole Pattern 1.pdf"
6.80
8.90
2.30
4.83
4.06
Bottom LE D
6.10
ANODE +
Ordering Information:Use chart below to determine model number.
LE D
R ed
1
G reen
5
Amber
3
Model No. is as follows: 5682F
Top LE D
_
Y ellow
7
B ottom LE D
Example:To order red LED on top and green LED on bottom, the part number would be 5682F1_5.
Electro-Optical Characteristics and Ratings
P art Number
5682F 1_1
5682F 3_3
5682F 5_5
5682F 7_7
E mitted
C olor
R ed
Amber
G reen
Y ellow
R ated
C urrent
(mA)
10
10
10
10
T yp.
Intensity
(mcd)
10.0
6.5
8.5
10.0
C ontinuous
F orward
C urrent Max.
(mA)
25
25
25
F orward V oltage
T yp.
(V )
Max.
(V )
R everse
B reakdown
V oltage Min.(V )
P eak
Wavelength
(nm)
2.2
2.2
2.3
2.2
3.0
3.0
3.0
3.0
5.0
5.0
5.0
5.0
635
602
565
583
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5682F7;7”相匹配的价格&库存,您可以联系我们找货
