CMD17-21VGC/TR8
CMD17-21VGC/TR8
    VCC
    发光二极管/LED 0805
CMD17-21VGC/TR8 数据手册
TM CMD17-21 Series SMT LEDs 0805 Package Size Available in 7 colors: Green, Super Red, High Efficiency Red, Yellow, Super Yellow and Super Orange, with water-clear or diffused color lenses. Descriptions and Features Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 3000 pieces per reel. • Lead Finish (Plating): Au • Under Plating Material: NiCu Leading Edge LED Optoelectronic Performance • Consistent high brightness. • Bi-color available. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. Dimensions All dimensions in mm. 0.20 R 0.60 Solder Pad Geometry for 0805 Package Size 1.25 1.40 2.00±0.20 C AT HODE MAS K 3.40 1.30 1.25±0.20 1.10±0.10 0.40 1.10 the first call for illuminated components www.vcclite.com 1  1.800.522.5546 02/17 Rev 3 Electro-Optical Characteristics Luminous Intensity Part Number Emitted Color Lens Color CMD17-21SRC/TR8 Super Red Clear CMD17-21VYC/TR8 Yellow Clear CMD17-21VRC/TR8 CMD17-21VGC/TR8 CMD17-21UGC/TR8 CMD17-21VRD/TR8 CMD17-21VYD/TR8 CMD17-21VGD/TR8 CMD17-21UYC/TR8 H.E.Red Green Green H.E.Red Yellow Green Super Yellow CMD17-21USOC/TR8 Super Orange Clear Forward Voltage Test Peak View Angle Typ. Max. Current Wavelength (mA) (nm) (degrees) (mcd) (mcd) (V) (V) 20 660 140 10.0 21.0 1.7 2.4 20 640 140 4.5 13.0 2.0 2.8 Min. Typ. 5.0 12.0 2.0 2.8 20 585 140 8.0 15.0 2.1 2.8 20 570 140 2.8 20 20 Clear 6.0 Clear Red Diffused 3.0 Yellow Diffused 2.5 Green Diffused 4.0 Clear 41.0 Clear 26 10.0 6.0 4.0 7.0 61.0 43.0 2.1 2.0 2.0 2.1 2.1 2.1 2.8 20 2.8 20 2.8 20 2.8 2.8 20 570 640 505 570 590 620 140 140 140 140 140 140 Absolute Maximum Ratings Red Yellow Green Units Power Dissipation.......................................................100.................105................105........................ mW Operating/Storage Temperature..........................-40 to +85......-40 to +85......-40 to +85.....................°C Peak Forward Current (1 μs @ 10% duty cycle).......150.................150................150.........................mA Reverse Voltage (IR=100μA)..................................... 5.0..................5.0.................5.0............................V Lead Solder Time @ 260°C..........................................5.....................5....................5.....................seconds Average Forward Current............................................30...................30..................30...........................mA Compliances and Approvals the first call for illuminated components www.vcclite.com 2 1.800.522.5546 02/17 Rev 3
CMD17-21VGC/TR8 价格&库存
很抱歉,暂时无法提供与“CMD17-21VGC/TR8”相匹配的价格&库存,您可以联系我们找货
CMD17-21VGC/TR8
  • 1000+2.109501000+0.27059
  • 4000+1.719034000+0.22050
  • 8000+1.581518000+0.20286
  • 12000+1.5454912000+0.19824
  • 28000+1.5356728000+0.19698
库存:57000
CMD17-21VGC/TR8
  • 4000+1.586424000+0.20349
库存:4000
