CMD2821VRCTR8T1
CMD2821VRCTR8T1
    VCC
    SMD,2.5x2mm
    发光二极管/LED SMD,2.5x2mm
CMD2821VRCTR8T1 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD28-21 Series SMT LEDs Description and Features All dimensions in mm. 4.20 MAX. 2.50±0.20 0.40 0.50 2.00±0.20 C ATHODE 0.80 0.13±0.07 MAX. Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2000 pieces per reel. • RoHS Compliant Leading Edge LED Optoelectronic Performance • Consistent high brightness. • Low current types available. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. 1.40±0.20 0.26 Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor P ackage T ype P ackage C olor T est C urrent (mA) F orward Voltage Typ. (V) F orward V oltage Max. (V ) Luminous Intensity Min. (mcd) Luminous Intensity T yp. (mcd) Luminous Intensity Max. (mcd) P eak Wavelength (nm) Viewing Angle 20 1/2 (degrees) P ower Dissipation (mW) Operating Temperature (°C ) S torage T emperature (°C ) P eak Forward C urrent Max. (1µs @ 10% duty cycle) (mA) R everse V oltage (IR =100µA) (V ) Lead S older T ime @ 260°C C MD28-21VG C /T R 8 C MD28-21VY C /T R 8 C MD28-21VR C /TR 8 C MD2821 VRCTR8T1 C MD2821 VYCT R8T1 C MD2821VGCTR 8T1 G reen S ingle C lear 20 2.1 2.8 1.0 5.5 570 150 105 -40 to +85 -40 to +85 150 5.0 5 Y ellow S ingle C lear 20 2.0 2.8 3.5 6.0 585 150 105 -40 to +85 -40 to +85 150 5.0 5 R ed S ingle C lear 20 2.0 2.8 1.5 3.0 640 150 100 -40 to +85 -40 to +85 150 5.0 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. H.E . R ed S ingle C lear 1 2.0 2.8 0.1 0.16 640 150 105 -40 to +85 -40 to +85 150 5.0 5 Y ellow S ingle C lear 1 2.1 2.8 0.25 0.4 585 150 105 -40 to +85 -40 to +85 150 5.0 5 G reen S ingle C lear 1 2.1 2.8 0.1 0.16 570 150 105 -40 to +85 -40 to +85 150 5.0 5
CMD2821VRCTR8T1 价格&库存
很抱歉,暂时无法提供与“CMD2821VRCTR8T1”相匹配的价格&库存,您可以联系我们找货
CMD2821VRCTR8T1
    • 1+11.13480
    • 200+4.44960
    • 500+4.29840
    • 1000+4.22280
