CMD11-21SRC/TR8
CMD11-21SRC/TR8
    VCC
    1206(3016公制)
    LED RED CLEAR 1206 SMD
CMD11-21SRC/TR8 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD11-21 SMT LEDs 1206 Package Size Description and Features 3.00± 0.20 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2000 pieces per reel. • RoHS Compliant CA T HO DE MA R K 1.50± 0.20 2.00± 0.20 1.80± 0.20 1.10± 0.20 Ø .045 0.90± 0.10 Leading Edge LED Optoelectronic Performance • Consistent high brightness. • Integral lensing for narrow angle light dispersion. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. 0.60 • Refer to “Solder Pad Geometry 3.pdf” 1.30 1.60 All dimensions in mm. Electro-Optical Characteristics and Ratings P A R T N U MB E R Out put C olor P a cka ge Type P a cka ge Color T e s t C urre nt (mA) Forward Voltage Typ. (V) Forward Voltage Max. (V) Luminous Intensity Min. (mcd) Luminous Intensity Typ. (mcd) Luminous Intensity Max. (mcd) Peak Wavelength(nm) Viewing Angle 20 1/2 (degrees) Power Dissipation (mW) Operating Temperature (°C) S torage Temperature (°C) Peak Forward Current Max.(1µs@10%dutycycle)(mA) R everse Voltage (IR=100µA) (V) 5.0 5.0 5.0 5.0 5.0 Lead S older Time @ 260°C CMD11-21VGC/TR8 CMD11-21VYC/TR8 CMD11-21VRC/TR8 CMD11-21SRC/TR8 Gr een S i ngle Clea r 20 2.1 2.8 3.0 7.5 570 20 105 -30 to +90 -30 to +90 150 5.0 5 Y e llow S i ngle Clea r 20 2.0 2.8 3.0 6.0 585 20 70 -30 to +90 -30 to +90 150 5.0 5 Re d S i ngle Clea r 20 2.0 2.8 3.0 6.0 640 20 100 -30 to +90 -30 to +90 150 5.0 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. Re d S i ngle Clea r 20 1.7 2.4 30.0 51.0 660 20 100 -30 to +90 -30 to +90 150 5.0 5
CMD11-21SRC/TR8 价格&库存
很抱歉,暂时无法提供与“CMD11-21SRC/TR8”相匹配的价格&库存,您可以联系我们找货
CMD11-21SRC/TR8
  • 2000+3.238582000+0.41808
  • 4000+3.074314000+0.39687
  • 6000+2.990126000+0.38600
  • 10000+2.8951010000+0.37374
  • 14000+2.8386014000+0.36644
  • 20000+2.7835320000+0.35933
库存:3142
CMD11-21SRC/TR8
  • 1+8.475321+1.09410
  • 10+5.9231210+0.76463
  • 100+4.35732100+0.56250
  • 500+3.66044500+0.47254
  • 1000+3.432251000+0.44308
库存:3142
