CMD67-21VGC/TR8
CMD67-21VGC/TR8
    VCC
    SMD,3.2x2.8mm
    发光二极管/LED SMD,3.2x2.8mm
CMD67-21VGC/TR8 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD67-21 SERIES SMT LEDs Description and Features Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase eflow compatible. • Compact form enables high density placement. • Packaged 2000 pieces per reel. • RoHS Compliant Leading Edge LED Optoelectronic Performance • Consistent high brightness. • Integral lensing for narrow angle light dispersion. • Bi-color available. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 1.pdf” Electro-Optical Characteristics and Ratings P art Number C MD67-21VG C /TR8 C MD67-21VY C /TR8 C MD67-21VR C /TR8 C MD67-21S R C /TR8 C MD67-21UR C /TR8 E mitted C olor G reen Y ellow H.E . R ed B right R ed B right R ed Lens C olor C lear C lear C lear C lear C lear Luminous Intensity Min. (mcd) 15.0 6.0 6.0 25.0 36.0 T yp. (mcd) 25.0 10.0 10.0 40.0 62.0 F orward V oltage T yp. (V ) 2.1 2.0 2.0 1.7 1.7 Max. (V ) 2.8 2.8 2.8 2.4 2.4 P olarity Mark Indicates C athode C athode C athode Anode Anode V iew P eak Wavelength Angle (degrees) (nm) 120 570 120 585 120 640 120 660 120 660 Absolute Maximum Ratings Green H.E.Red Yellow Bright Red Units Power Dissipation.....................................................105....................120......................105......................100..................mW Storage/Operating Temperature.........................-40 to +85...........-40 to +85...........-40 to +85............-40 to +85...............°C Peak Forward Current (1μs @ 10% duty cycle)........150...................150......................150......................150...................mA Reverse Voltage (IR=100μA).....................................5.0....................5.0.......................5.0........................5.0.....................V Lead Solder Time @ 260°C........................................5........................5..........................5.........................5.............Seconds Average Forward Current...........................................25.....................30........................30........................30....................mA CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMD67-21VGC/TR8
1. 物料型号:CMD67-21系列SMT LED,包括不同颜色的LED,如绿色、黄色、高效率红色、亮红色。 2. 器件简介:这些LED采用表面贴装技术,适用于高速自动插入,兼容对流和蒸汽相流焊接,具有紧凑的外形,便于高密度布局,每卷2000件,符合RoHS标准。 3. 引脚分配:文档中没有明确提供引脚分配信息,但通常SMT LED会有阳极和阴极标记。 4. 参数特性:包括发光强度、正向电压、峰值波长和视场角度。例如,CMD67-21VGC/TR8绿色LED的典型发光强度为25.0 mcd,正向电压典型值为2.1V。 5. 功能详解:LED具有一致的高亮度、内置透镜以实现窄角度光分布,并且有双色选项。 6. 应用信息:文档中没有提供具体的应用信息,但SMT LED通常用于指示灯、背光、照明等。 7. 封装信息:封装细节包括尺寸和极性标记,例如,极性标记指示为阴极或阳极。
CMD67-21VGC/TR8 价格&库存
很抱歉,暂时无法提供与“CMD67-21VGC/TR8”相匹配的价格&库存,您可以联系我们找货
CMD67-21VGC/TR8
  • 2000+2.855912000+0.36659
  • 4000+2.661924000+0.34169
  • 6000+2.638296000+0.33866
  • 10000+2.6134010000+0.33546
  • 14000+2.6066414000+0.33460
  • 20000+2.5599920000+0.32861
库存:9846
CMD67-21VGC/TR8
  • 1+7.864141+1.00946
  • 10+5.4781910+0.70319
  • 100+3.98689100+0.51177
  • 500+3.37592500+0.43334
  • 1000+3.163581000+0.40609
库存:9846
