Double Ultra Bright Flex
Inspired LED Double Ultra Bright Flexible Strips are a
simple, customizable solution for all of your LED task
lighting needs. These uniquely bright strips can be cut
to length and terminated with solderless end
connectors for easy DIY installation, or ordered in
custom lengths for your convenience. Energy efficient,
with a range of options for color temperature, Inspired
LED Double Ultra Bright Flex Strips are the perfect
option for any area where the brightest light is just
right!
Product Features:
Minimal Heat Production- No IR or UV
Available in various colors; warm white (3000K),
pure white (4200 K), or cool white (6000K)
Custom lengths or full 12m reels
Adhesive mounting to almost any flat surface
Class 2 DC plug in connector (3.5 x 1.3 mm)
12VDC Class 2 power systems only
1000 Lumens (198 LEDs) per meter
Energy efficient 18 Watts per meter
Dimmable with compatible systems
Rated to last up to 100,000 hours
Instructions:
1. Clean desired mounting surface(s) and test all
products prior to installation
2. Temporarily mount LED flex strips using scotch tape
3. Interconnect LED strips with compatible DC cables
4. Run cable from LED system to control device and
connect to class 2 power source
5. When satisfied with placement, peel adhesive backing
from strips and press firmly to adhere
LEDs in place
LED Flex Interconnection
Class 2 DC
Power
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Inspired LED:
12V-DUB-PW-12M
很抱歉,暂时无法提供与“12V-DUB-PW-12M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 396+10.02051396+1.29702
