BXRC-35A4001-D-73-SE
    BRIDGELUX(普瑞)
BXRC-35A4001-D-73-SE 数据手册
® ® Bridgelux Décor Series Class A on Vero SE Series LED Array ™ Product Data Sheet DS125 BXRC-30A1001 BXRC-35A1001 BXRC-40A1001 | | | 30A2001 35A2001 40A2001 | | | 30A4001 35A4001 40A4001 | | | 30A10K1 35A10K1 40A10K1 Vero SE Introduction Bridgelux Décor Series™ Class A on Vero SE products are a revolutionary advancement in lighting designed to match how humans perceive and prefer light. The Class A specification was created by the Lighting Research Center (LRC) behavior studies in conjunction with Bridgelux and other ASSIST members. Based on human factor response testing, the Décor Series Class A products provide vibrant, natural and brilliant looking light, evoking an emotional attraction and response. The Décor Series Class A products were developed for high-end retail, museum, architectural, premium building and hospitality applications. Bridgelux Décor Series Class A on Vero SE products are available on all Vero SE form factors. The platform has been engineered with poke-in connectivity options and can operate over a broad current range, enabling multiple degrees of flexibility in luminaire design optimization. Features • Poke-in connectivity • Light quality is based on human perception of color and light • High gamut area index (GAI) Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • No harmful UV or near IR light in the spectrum • Flexibility for application driven lighting design requirements • Substantially broader GAI and color spectrum than halogen • High quality, true color reproduction • Radial die pattern enhances optical uniformity • Based on Bridgelux Vero® Series LED array platform • No exposed solder pads or electrical connections • Uniform consistent white light • Flexibility in design optimization • Enhanced ease of use and manufacturability • Ability to configure multiple Vero SE in series and parallel reduces customer driver cost Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 7 Electrical Characteristics 11 Eye Safety 12 Absolute Maximum Ratings 13 Performance Curves 14 Typical Radiation Pattern 20 Typical Color Spectrum 22 Mechanical Dimensions 21 Packaging and Labeling 25 Design Resources 28 Precautions 28 Disclaimers 28 About Bridgelux 29 1 Product Feature Map In addition to delivering the performance and light quality required for many lighting applications, Décor Series Class A on Vero SE LED arrays incorporate several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 2D Bar code provides full manufacturing traceability Optic mounting holes Tc Measurement point Radial die configuration improves lumen density and beam control Mounting location Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Test port for probing Dual poke-in connectors Product Nomenclature The part number designation for Bridgelux Décor Class A on Vero SE LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 - 15 16 BXRC – 30 A 1001 – B – 7 3 - SE Special Edition Product Family Nominal CCT 30 = 3,000K 35 = 3,500K 40 = 4,000K Gen. 7 CCT Bin Options 3 = 3 SDCM Array Configuration Typical GAI GAI >80 Nominal Flux 1001- 1000lm 2001- 2000lm 4001- 4000lm 10K1- 10,000lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Nominal Drive Current4 (mA) Typical Pulsed Flux5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux7,8 Tc = 25ºC (lm) Typical Vf (V) 93 270 93 360 1056 929 1407 1238 80 93 350 1026 3500 80 93 270 BXRC-35A1001-C-73-SE 3500 BXRC-35A1001-D-73-SE 3500 80 93 80 93 BXRC-40A1001-B-73-SE 4000 80 Décor Class A Vero SE 10 Décor Class A Vero SE 10 BXRC-40A1001-C-73-SE 4000 BXRC-40A1001-D-73-SE 4000 Décor Class A Vero SE 13 BXRC-30A2001-B-73-SE Décor Class A Vero SE 13 Part Number Nominal CCT1 (K) GAI2 CRI3 Typical Power (W) Typical Efficacy (lm/W) Décor Class A Vero SE 10 BXRC-30A1001-B-73-SE 3000 80 Décor Class A Vero SE 10 BXRC-30A1001-C-73-SE 3000 80 35.0 9.4 113 35.0 12.5 Décor Class A Vero SE 10 BXRC-30A1001-D-73-SE 3000 113 903 26.0 9.1 Décor Class A Vero SE 10 BXRC-35A1001-B-73-SE 113 1137 1001 35.0 9.4 122 Décor Class A Vero SE 10 Décor Class A Vero SE 10 360 1516 1335 35.0 12.5 122 350 1106 973 26.0 9.1 Décor Class A Vero SE 10 122 93 270 1210 1065 35.0 9.4 129 80 93 360 1614 1420 35.0 12.5 129 80 93 350 1176 1035 26.0 9.1 129 3000 80 93 450 1836 1652 35.0 15.6 118 BXRC-30A2001-C-73-SE 3000 80 93 630 2570 2313 35.0 21.9 118 Décor Class A Vero SE 13 BXRC-30A2001-D-73-SE 3000 80 93 500 1869 1683 31.8 15.9 118 Décor Class A Vero SE 13 BXRC-35A2001-B-73-SE 3500 80 93 450 1974 1776 35.0 15.6 126 Décor Class A Vero SE 13 BXRC-35A2001-C-73-SE 3500 80 93 630 2763 2486 35.0 21.9 126 Décor Class A Vero SE 13 BXRC-35A2001-D-73-SE 3500 80 93 500 2009 1808 31.8 15.9 126 Décor Class A Vero SE 13 BXRC-40A2001-B-73-SE 4000 80 93 450 2111 1900 35.0 15.6 135 Décor Class A Vero SE 13 BXRC-40A2001-C-73-SE 4000 80 93 630 2955 2660 35.0 21.9 135 Décor Class A Vero SE 13 BXRC-40A2001-D-73-SE 4000 80 93 500 2150 1936 31.8 15.9 135 Décor Class A Vero SE 18 BXRC-30A4001-B-73-SE 3000 80 93 900 3696 3327 35.0 31.2 118 Décor Class A Vero SE 18 BXRC-30A4001-C-73-SE 3000 80 93 1170 4807 4326 35.0 40.6 118 Décor Class A Vero SE 18 BXRC-30A4001-D-73-SE 3000 80 93 1050 3594 3234 29.0 30.4 118 Décor Class A Vero SE 18 BXRC-35A4001-B-73-SE 3500 80 93 900 3974 3576 35.0 31.2 127 Décor Class A Vero SE 18 BXRC-35A4001-C-73-SE 3500 80 93 1170 5167 4650 35.0 40.6 127 Décor Class A Vero SE 18 BXRC-35A4001-D-73-SE 3500 80 93 1050 3864 3477 29.0 30.4 127 Décor Class A Vero SE 18 BXRC-40A4001-B-73-SE 4000 80 93 900 4251 3826 35.0 31.2 136 Décor Class A Vero SE 18 BXRC-40A4001-C-73-SE 4000 80 93 1170 5527 4974 35.0 40.6 136 Décor Class A Vero SE 18 BXRC-40A4001-D-73-SE 4000 80 93 1050 4134 3720 29.0 30.4 136 Décor Class A Vero SE 29 BXRC-30A10K1-B-73-SE 3000 80 93 1800 11209 10088 52.0 93.6 120 Décor Class A Vero SE 29 BXRC-30A10K1-C-73-SE 3000 80 93 1710 14197 12778 69.4 118.6 120 Décor Class A Vero SE 29 BXRC-30A10K1-D-73-SE 3000 80 93 2100 9444 8500 37.6 78.9 120 Décor Class A Vero SE 29 BXRC-35A10K1-B-73-SE 3500 80 93 1800 12050 10845 52.0 93.6 129 Décor Class A Vero SE 29 BXRC-35A10K1-C-73-SE 3500 80 93 1710 15263 13737 69.4 118.6 129 Décor Class A Vero SE 29 BXRC-35A10K1-D-73-SE 3500 80 93 2100 10153 9137 37.6 78.9 129 Décor Class A Vero SE 29 BXRC-40A10K1-B-73-SE 4000 80 93 1800 12890 11601 52.0 93.6 138 Décor Class A Vero SE 29 BXRC-40A10K1-C-73-SE 4000 80 93 1710 16327 14694 69.4 118.6 138 Décor Class A Vero SE 29 BXRC-40A10K1-D-73-SE 4000 80 93 2100 10861 9775 37.6 78.9 138 Product Notes for Table 1: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 6. Typical performance values are provided as a reference only and are not a guarantee of performance. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide The following product configurations are available: Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 4,5 Nominal Drive Current4 (mA) Minimum DC Flux6 Tc = 70ºC (lm) Typical Vf (V) 982 864 1309 1152 955 270 93 80 93 4000 80 93 270 4000 80 93 360 BXRC-40A1001-D-73-SE 4000 80 93 350 Décor Class A Vero SE 13 BXRC-30A2001-B-73-SE 3000 80 93 Décor Class A Vero SE 13 BXRC-30A2001-C-73-SE 3000 80 93 Décor Class A Vero SE 13 BXRC-30A2001-D-73-SE 3000 80 93 Décor Class A Vero SE 13 BXRC-35A2001-B-73-SE 3500 80 93 Décor Class A Vero SE 13 BXRC-35A2001-C-73-SE 3500 80 Décor Class A Vero SE 13 BXRC-35A2001-D-73-SE 3500 80 Décor Class A Vero SE 13 BXRC-40A2001-B-73-SE 4000 80 93 Décor Class A Vero SE 13 BXRC-40A2001-C-73-SE 4000 80 93 Décor Class A Vero SE 13 BXRC-40A2001-D-73-SE 4000 80 93 500 Décor Class A Vero SE 18 BXRC-30A4001-B-73-SE 3000 80 93 Décor Class A Vero SE 18 BXRC-30A4001-C-73-SE 3000 80 93 Décor Class A Vero SE 18 BXRC-30A4001-D-73-SE 3000 80 93 Décor Class A Vero SE 18 BXRC-35A4001-B-73-SE 3500 80 Décor Class A Vero SE 18 BXRC-35A4001-C-73-SE 3500 80 Décor Class A Vero SE 18 BXRC-35A4001-D-73-SE 3500 Décor Class A Vero SE 18 BXRC-40A4001-B-73-SE Décor Class A Vero SE 18 Part Number Nominal CCT1 (K) GAI2 CRI3 Décor Class A Vero SE 10 BXRC-30A1001-B-73-SE 3000 80 93 270 Décor Class A Vero SE 10 BXRC-30A1001-C-73-SE 3000 80 93 360 Décor Class A Vero SE 10 BXRC-30A1001-D-73-SE 3000 80 93 350 Décor Class A Vero SE 10 BXRC-35A1001-B-73-SE 3500 80 93 Décor Class A Vero SE 10 BXRC-35A1001-C-73-SE 3500 80 Décor Class A Vero SE 10 BXRC-35A1001-D-73-SE 3500 Décor Class A Vero SE 10 BXRC-40A1001-B-73-SE Décor Class A Vero SE 10 BXRC-40A1001-C-73-SE Décor Class A Vero SE 10 Typical DC Flux Tc = 70ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 34.3 9.3 106 34.3 12.3 106 840 25.5 8.9 107 1058 931 34.3 9.3 114 360 1410 1241 34.3 12.3 114 350 1029 905 25.5 8.9 115 1125 991 34.3 9.3 122 1501 1321 34.3 12.3 122 1094 963 25.5 8.9 123 450 1707 1537 34.4 15.5 110 630 2390 2151 34.4 21.6 110 500 1738 1565 31.2 15.6 111 450 1836 1651 34.4 15.5 119 93 630 2569 2312 34.4 21.6 119 93 500 1868 1682 31.2 15.6 120 450 1963 1767 34.4 15.5 127 630 2748 2474 34.4 21.6 127 2000 1800 31.2 15.6 128 900 3438 3094 34.3 30.9 111 1170 4470 4023 34.3 40.2 111 1050 3342 3008 28.5 29.9 112 93 900 3696 3326 34.3 30.9 120 93 1170 4805 4324 34.3 40.2 120 80 93 1050 3594 3234 28.5 29.9 120 4000 80 93 900 3953 3558 34.3 30.9 128 BXRC-40A4001-C-73-SE 4000 80 93 1170 5140 4626 34.3 40.2 128 Décor Class A Vero SE 18 BXRC-40A4001-D-73-SE 4000 80 93 1050 3844 3460 28.5 29.9 129 Décor Class A Vero SE 29 BXRC-30A10K1-B-73-SE 3000 80 93 1800 10424 9382 50.9 91.6 114 Décor Class A Vero SE 29 BXRC-30A10K1-C-73-SE 3000 80 93 1710 13204 11884 67.9 116.1 114 Décor Class A Vero SE 29 BXRC-30A10K1-D-73-SE 3000 80 93 2100 8783 7905 36.8 77.3 114 Décor Class A Vero SE 29 BXRC-35A10K1-B-73-SE 3500 80 93 1800 11206 10086 50.9 91.6 122 Décor Class A Vero SE 29 BXRC-35A10K1-C-73-SE 3500 80 93 1710 14194 12775 67.9 116.1 122 Décor Class A Vero SE 29 BXRC-35A10K1-D-73-SE 3500 80 93 2100 9442 8498 36.8 77.3 122 Décor Class A Vero SE 29 BXRC-40A10K1-B-73-SE 4000 80 93 1800 11987 10789 50.9 91.6 131 Décor Class A Vero SE 29 BXRC-40A10K1-C-73-SE 4000 80 93 1710 15184 13666 67.9 116.1 131 Décor Class A Vero SE 29 BXRC-40A10K1-D-73-SE 4000 80 93 2100 10101 9090 36.8 77.3 131 Product Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4 Product Selection Guide The following product configurations are available: Table 3: Selection Guide, Pulsed Measurement Data (Tj = Tc = 85°C) Nominal Drive Current4 (mA) Typical Pulsed Flux5,6,7 Tc = 85ºC (lm) Minimum Pulsed Flux7,8 Tc = 85ºC (lm) Typical Vf (V) 950 836 1267 1114 Part Number Nominal CCT1 (K) GAI2 CRI3 Typical Power (W) Typical Efficacy (lm/W) Décor Class A Vero SE 10 BXRC-30A1001-B-73-SE 3000 80 93 270 Décor Class A Vero SE 10 BXRC-30A1001-C-73-SE 3000 80 93 360 34.0 9.2 103 34.0 12.3 Décor Class A Vero SE 10 BXRC-30A1001-D-73-SE 3000 80 93 350 924 103 813 25.3 8.9 104 Décor Class A Vero SE 10 BXRC-35A1001-B-73-SE 3500 80 93 270 Décor Class A Vero SE 10 BXRC-35A1001-C-73-SE 3500 80 93 360 1024 901 34.0 9.2 111 1365 1201 34.0 12.3 Décor Class A Vero SE 10 BXRC-35A1001-D-73-SE 3500 80 93 350 996 111 876 25.3 8.9 112 Décor Class A Vero SE 10 BXRC-40A1001-B-73-SE 4000 80 93 270 Décor Class A Vero SE 10 BXRC-40A1001-C-73-SE 4000 80 93 360 1089 959 34.0 9.2 119 1452 1278 34.0 12.3 Décor Class A Vero SE 10 BXRC-40A1001-D-73-SE 4000 80 93 119 350 1059 932 25.3 8.9 120 Décor Class A Vero SE 13 BXRC-30A2001-B-73-SE 3000 80 Décor Class A Vero SE 13 BXRC-30A2001-C-73-SE 3000 80 93 450 1652 1487 34.1 15.4 108 93 630 2313 2082 34.1 21.5 Décor Class A Vero SE 13 BXRC-30A2001-D-73-SE 3000 108 80 93 500 1682 1514 31.0 15.5 Décor Class A Vero SE 13 BXRC-35A2001-B-73-SE 109 3500 80 93 450 1776 1598 34.1 15.4 Décor Class A Vero SE 13 116 BXRC-35A2001-C-73-SE 3500 80 93 630 2486 2238 34.1 21.5 116 Décor Class A Vero SE 13 BXRC-35A2001-D-73-SE 3500 80 93 500 1808 1627 31.0 15.5 117 Décor Class A Vero SE 13 BXRC-40A2001-B-73-SE 4000 80 93 450 1900 1710 34.1 15.4 124 Décor Class A Vero SE 13 BXRC-40A2001-C-73-SE 4000 80 93 630 2659 2394 34.1 21.5 124 Décor Class A Vero SE 13 BXRC-40A2001-D-73-SE 4000 80 93 500 1935 1742 31.0 15.5 125 Décor Class A Vero SE 18 BXRC-30A4001-B-73-SE 3000 80 93 900 3327 2994 34.1 30.7 108 Décor Class A Vero SE 18 BXRC-30A4001-C-73-SE 3000 80 93 1170 4326 3893 34.1 39.9 108 Décor Class A Vero SE 18 BXRC-30A4001-D-73-SE 3000 80 93 1050 3234 2911 28.3 29.7 109 Décor Class A Vero SE 18 BXRC-35A4001-B-73-SE 3500 80 93 900 3576 3218 34.1 30.7 117 Décor Class A Vero SE 18 BXRC-35A4001-C-73-SE 3500 80 93 1170 4650 4185 34.1 39.9 117 Décor Class A Vero SE 18 BXRC-35A4001-D-73-SE 3500 80 93 1050 3478 3129 28.3 29.7 117 Décor Class A Vero SE 18 BXRC-40A4001-B-73-SE 4000 80 93 900 3826 3443 34.1 30.7 125 Décor Class A Vero SE 18 BXRC-40A4001-C-73-SE 4000 80 93 1170 4974 4477 34.1 39.9 125 Décor Class A Vero SE 18 BXRC-40A4001-D-73-SE 4000 80 93 1050 3720 3348 28.3 29.7 125 Décor Class A Vero SE 29 BXRC-30A10K1-B-73-SE 3000 80 93 1800 10088 9079 50.5 90.9 111 Décor Class A Vero SE 29 BXRC-30A10K1-C-73-SE 3000 80 93 1710 12778 11500 67.4 115.3 111 Décor Class A Vero SE 29 BXRC-30A10K1-D-73-SE 3000 80 93 2100 8500 7650 36.6 76.8 111 Décor Class A Vero SE 29 BXRC-35A10K1-B-73-SE 3500 80 93 1800 10845 9760 50.5 90.9 119 Décor Class A Vero SE 29 BXRC-35A10K1-C-73-SE 3500 80 93 1710 13736 12363 67.4 115.2 119 Décor Class A Vero SE 29 BXRC-35A10K1-D-73-SE 3500 80 93 2100 9137 8223 36.6 76.8 119 Décor Class A Vero SE 29 BXRC-40A10K1-B-73-SE 4000 80 93 1800 11601 10441 50.5 90.9 128 Décor Class A Vero SE 29 BXRC-40A10K1-C-73-SE 4000 80 93 1710 14694 13225 67.4 115.2 128 Décor Class A Vero SE 29 BXRC-40A10K1-D-73-SE 4000 80 93 2100 9775 8797 36.6 76.8 127 Product Notes for Table 3: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1-12 and the flux vs. current characteristics shown in Figures 13-24. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Product Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 10 Part Number BXRC-30A1001-B-73-SE BXRC-30A1001-C-73-SE BXRC-30A1001-D-73-SE BXRC-35A1001-B-73-SE BXRC-35A1001-C-73-SE BXRC-35A1001-D-73-SE GAI 80 80 80 80 80 80 CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 93 135 180 270 405 540 33.3 33.8 35.0 36.4 37.8 4.5 6.1 9.5 14.8 20.4 562 738 1056 1549 1984 506 664 950 1394 1786 125 121 112 105 97 93 180 240 360 540 720 33.3 33.8 35.0 36.4 37.7 6.0 8.1 12.6 19.7 27.1 748 980 1407 2049 2618 673 882 1267 1845 2356 125 121 112 104 96 93 175 233 350 525 700 24.9 25.4 26.0 27.4 28.4 4.4 5.9 9.1 14.4 19.9 548 719 1026 1511 1936 493 647 924 1360 1742 126 122 113 105 97 93 135 180 270 405 540 33.3 33.8 35.0 36.4 37.8 4.5 6.1 9.5 14.8 20.4 606 795 1137 1668 2137 545 715 1024 1502 1924 135 130 120 113 105 93 180 240 360 540 720 33.3 33.8 35.0 36.4 37.7 6.0 8.1 12.6 19.7 27.1 806 1056 1516 2208 2820 726 951 1365 1987 2538 135 130 120 112 104 93 175 233 350 525 700 24.9 25.4 26.0 27.4 28.4 4.4 5.9 9.1 14.4 19.9 591 775 1106 1628 2086 532 697 996 1465 1877 135 131 122 113 105 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Product Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 10 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Part Number BXRC-40A1001-B-73-SE BXRC-40A1001-C-73-SE BXRC-40A1001-D-73-SE BXRC-30A2001-B-73-SE BXRC-30A2001-C-73-SE BXRC-30A2001-D-73-SE BXRC-35A2001-B-73-SE BXRC-35A2001-C-73-SE BXRC-35A2001-D-73-SE GAI 80 80 80 80 80 80 80 80 80 CRI 93 93 93 93 93 93 93 93 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 33.3 4.5 645 580 144 180 33.8 6.1 846 761 139 270 35.0 9.5 1210 1089 128 405 36.4 14.8 1775 1598 120 540 37.8 20.4 2274 2047 112 180 33.3 6.0 858 772 143 240 33.8 8.1 1124 1011 138 360 35.0 12.6 1614 1452 128 540 36.4 19.7 2350 2115 120 720 37.7 27.1 3001 2701 111 175 24.9 4.4 628 565 144 233 25.4 5.9 824 741 139 350 26.0 9.1 1176 1059 129 120 525 27.4 14.4 1731 1558 700 28.4 19.9 2218 1996 112 113 32.3 3.7 500 450 137 225 33.2 7.5 968 871 129 450 35.0 15.8 1836 1652 117 675 36.3 24.5 2653 2387 108 900 37.5 33.7 3384 3045 100 158 32.3 5.1 694 625 136 315 33.2 10.5 1344 1210 128 630 35.0 22.1 2570 2313 117 107 945 36.4 34.4 3688 3319 1260 37.8 47.6 4707 4236 99 125 29.6 3.7 495 445 134 250 30.3 7.6 959 863 126 500 31.8 15.9 1869 1682 118 106 750 33.2 24.9 2641 2377 1000 34.4 34.4 3377 3039 98 113 32.3 3.7 538 484 147 225 33.2 7.5 1040 936 139 450 35.0 15.8 1974 1776 125 675 36.3 24.5 2852 2567 117 900 37.5 33.7 3638 3275 108 158 32.3 5.1 746 672 146 315 33.2 10.5 1445 1301 138 630 35.0 22.1 2763 2486 125 945 36.4 34.4 3965 3569 115 1260 37.8 47.6 5061 4555 106 125 29.6 3.7 532 479 144 250 30.3 7.6 1031 928 136 500 31.8 15.9 2009 1808 126 750 33.2 24.9 2839 2555 114 1000 34.4 34.4 3630 3267 105 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Product Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 13 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Part Number BXRC-40A2001-B-73-SE BXRC-40A2001-C-73-SE BXRC-40A2001-D-73-SE BXRC-30A4001-B-73-SE BXRC-30A4001-C-73-SE BXRC-30A4001-D-73-SE BXRC-35A4001-B-73-SE BXRC-35A4001-C-73-SE BXRC-35A4001-D-73-SE GAI 80 80 80 80 80 80 80 80 80 CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) 93 93 93 93 93 93 93 93 93 Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 32.3 3.7 575 517 157 225 33.2 7.5 1113 1001 149 450 35.0 15.8 2111 1900 134 675 36.3 24.5 3051 2746 125 900 37.5 33.7 3891 3502 115 158 32.3 5.1 798 718 156 315 33.2 10.5 1545 1391 148 630 35.0 22.1 2955 2659 134 123 945 36.4 34.4 4241 3817 1260 37.8 47.6 5413 4871 114 125 29.6 3.7 569 512 154 250 30.3 7.6 1103 993 145 500 31.8 15.9 2150 1935 135 122 750 33.2 24.9 3038 2735 1000 34.4 34.4 3885 3497 113 450 33.3 15.0 1985 1786 132 600 33.9 20.4 2603 2343 128 900 35.0 31.5 3696 3327 117 1350 36.7 49.5 5498 4948 111 1800 38.0 68.4 7074 6367 103 129 585 33.4 19.5 2511 2260 780 34.0 26.5 3291 2962 124 1170 35.0 41.0 4807 4326 117 107 1755 36.8 64.5 6915 6223 2340 38.1 89.3 8870 7983 99 525 27.7 14.6 1914 1723 131 700 28.2 19.8 2489 2240 126 1050 29.0 30.5 3594 3234 118 107 1575 30.4 47.9 5133 4620 2100 31.5 66.2 6534 5881 99 450 33.3 15.0 2133 1920 142 600 33.9 20.4 2799 2519 137 900 35.0 31.5 3974 3576 126 119 1350 36.7 49.5 5910 5319 1800 38.0 68.4 7605 6845 111 585 33.4 19.5 2700 2430 138 780 34.0 26.5 3538 3184 133 1170 35.0 41.0 5167 4650 126 1755 36.8 64.5 7433 6690 115 2340 38.1 89.3 9535 8581 107 525 27.7 14.6 2058 1853 141 700 28.2 19.8 2677 2409 135 1050 29.0 30.5 3864 3478 127 1575 30.4 47.9 5519 4967 115 2100 31.5 66.2 7026 6323 106 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Product Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 18 Décor Class A Vero SE 29 Décor Class A Vero SE 29 Décor Class A Vero SE 29 Décor Class A Vero SE 29 Décor Class A Vero 29 Décor Class A Vero SE 29 Part Number BXRC-40A4001-B-73-SE BXRC-40A4001-C-73-SE BXRC-40A4001-D-73-SE BXRC-30A10K1-B-73-SE BXRC-30A10K1-C-73-SE BXRC-30A10K1-D-73-SE BXRC-35A10K1-B-73-SE BXRC-35A10K1-C-73-SE BXRC-35A10K1-D-73-SE GAI 80 80 80 80 80 80 80 80 80 CRI Drive Current1 (mA) 93 93 93 93 93 93 93 93 93 Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 152 450 33.3 15.0 2282 2054 600 33.9 20.4 2994 2695 147 900 35.0 31.5 4251 3826 135 128 1350 36.7 49.5 6323 5690 1800 38.0 68.4 8136 7322 119 585 33.4 19.5 2888 2599 148 780 34.0 26.5 3784 3406 143 1170 35.0 41.0 5527 4974 135 123 1755 36.8 64.5 7951 7156 2340 38.1 89.3 10199 9180 114 525 27.7 14.6 2202 1982 151 700 28.2 19.8 2863 2577 145 1050 29.0 30.5 4134 3720 136 1575 30.4 47.9 5904 5314 123 2100 31.5 66.2 7516 6764 114 900 49.6 44.7 5873 5286 131 1200 50.5 60.6 7750 6975 128 1800 52.0 93.6 11209 10088 120 2700 54.1 146.1 16526 14874 113 3600 55.8 201.0 21308 19177 106 143 855 66.2 56.6 8065 7259 1140 67.3 76.7 10251 9226 134 1710 69.4 118.7 14197 12778 120 109 2565 72.1 185.0 20141 18127 3420 74.4 254.6 25245 22720 99 1050 35.4 37.2 5195 4675 140 1400 36.2 50.6 6686 6017 132 2100 37.6 79.0 9444 8500 120 108 3150 39.5 124.4 13445 12101 4200 41.2 172.9 16946 15251 98 900 49.6 44.7 6314 5683 141 1200 50.5 60.6 8331 7498 138 1800 52.0 93.6 12050 10845 129 122 2700 54.1 146.1 17766 15990 3600 55.8 201.0 22907 20616 114 855 66.2 56.6 8670 7803 153 1140 67.3 76.7 11020 9918 144 1710 69.4 118.7 15263 13736 129 2565 72.1 185.0 21652 19487 117 3420 74.4 254.6 27139 24425 107 150 1050 35.4 37.2 5584 5026 1400 36.2 50.6 7187 6468 142 2100 37.6 79.0 10153 9137 129 3150 39.5 124.4 14454 13008 116 4200 41.2 172.9 18217 16395 105 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Product Décor Class A Vero SE 29 Décor Class A Vero SE 29 Décor Class A Vero SE 29 Part Number BXRC-40A10K1-B-73-SE BXRC-40A10K1-C-73-SE BXRC-40A10K1-D-73-SE GAI 80 80 80 CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) 93 93 93 Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 49.6 44.7 6754 6079 151 1200 50.5 60.6 8912 8021 147 1800 52.0 93.6 12890 11601 138 2700 54.1 146.1 19005 17104 130 3600 55.8 201.0 24503 22053 122 855 66.2 56.6 9275 8347 164 1140 67.3 76.7 11788 10610 154 1710 69.4 118.7 16327 14694 138 125 2565 72.1 185.0 23162 20846 3420 74.4 254.6 29031 26128 114 1050 35.4 37.2 5974 5377 161 1400 36.2 50.6 7688 6920 152 2100 37.6 79.0 10861 9775 138 3150 39.5 124.4 15462 13916 124 4200 41.2 172.9 19487 17539 113 Notes for Table 4: 1. Alternate drive currents in Table 4 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and not a guarantee of performance. 10 Electrical Characteristics Table 5: Electrical Characteristics Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Nominal Drive Current 1 (mA) Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2,3, 8 Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆TC (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (C/W) Minimum Typical 270 32.4 35.0 37.6 -16.1 540 34.9 37.8 40.6 -16.1 360 32.4 35.0 37.6 -16.1 720 34.9 37.7 40.5 -16.1 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold4 Tc = -40ºC (V) 0.49 31.1 38.7 0.57 33.6 41.6 0.37 31.1 38.7 0.43 33.6 41.6 350 24.1 26.0 28.0 -11.8 0.49 23.1 28.7 700 26.3 28.4 30.5 -11.8 0.57 25.3 31.3 450 32.4 35.0 37.6 -14.3 0.28 31.2 38.6 900 34.7 37.5 40.3 -14.3 0.35 33.5 41.2 630 32.4 35.0 37.6 -14.3 0.20 31.2 38.6 1260 34.9 37.8 40.6 -14.3 0.24 33.8 41.5 500 29.4 31.8 34.2 -13.3 0.34 28.4 35.0 1000 31.8 34.4 37.0 -13.3 0.41 30.8 37.9 900 32.4 35.0 37.6 -14.9 0.15 31.2 38.6 1800 35.2 38.0 40.9 -14.9 0.19 34.0 41.8 1170 32.4 35.0 37.6 -14.9 0.11 31.2 38.6 2340 35.3 38.1 41.0 -14.9 0.13 34.1 42.0 1050 26.8 29.0 31.2 -12.2 0.16 25.8 32.0 2100 29.2 31.5 33.9 -12.2 0.19 28.2 34.7 1800 48.1 52.0 55.9 -24.9 0.06 46.1 57.5 3600 51.7 55.8 60.0 -24.9 0.07 49.7 61.6 1710 64.2 69.4 74.6 -33.2 0.04 61.5 76.8 3420 68.8 74.4 80.0 -33.2 0.05 66.2 82.2 2100 34.8 37.6 40.4 -17.4 0.06 33.4 41.6 4200 38.1 41.2 44.3 -17.4 0.07 36.7 45.4 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 11 Eye Safety Table 5: Eye Safety Classifications Part Number BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE CCT1, 3 Drive Current 3 (mA) 2700K/3000K 4000K2 270 RG1 RG1 405 RG1 RG1 540 RG1 RG1 360 RG1 RG1 540 RG1 RG1 720 RG1 RG2 350 RG1 RG1 525 RG1 RG1 700 RG1 RG1 450 RG1 RG1 675 RG1 RG1 900 RG1 RG1 630 RG1 RG1 945 RG1 RG1 1260 RG1 RG2 500 RG1 RG1 750 RG1 RG1 1000 RG1 RG1 900 RG1 RG1 1350 RG1 RG1 1800 RG1 RG1 1170 RG1 RG1 1755 RG1 RG1 2340 RG1 RG1 1050 RG1 RG1 1575 RG1 RG1 2100 RG1 RG1 1800 RG1 RG1 RG1 2700 RG1 3600 RG1 RG1 1710 RG1 RG2 2565 RG1 RG2 3420 RG1 RG2 2100 RG1 RG1 3150 RG1 RG1 4200 RG1 RG1 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 12 Absolute Maximum Ratings Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 105°C BXRC-xxx100x-B-7x-SE BXRC-xxx100x-C-7x-SE BXRC-xxx100x-D-7x-SE Maximum Drive Current2 540mA 720mA 700mA Maximum Peak Pulsed Drive Current3 770mA 1030mA 1000mA Maximum Reverse Voltage4 -60V -60V -45V BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Maximum Drive Current2 900mA 1260mA 1000mA Maximum Peak Pulsed Drive Current3 1290mA 1800mA 1430mA Maximum Reverse Voltage4 -60V -60V -55V BXRC-xxx400x-B-7x-SE BXRC-xxx400x-C-7x-SE BXRC-xxx400x-D-7x-SE Maximum Drive Current2 1800mA 2340mA 2100mA Maximum Peak Pulsed Drive Current3 2570mA 3340mA 3000mA Maximum Reverse Voltage4 -60V -60V -50V BXRC-xxx10Kx-B-7x-SE BXRC-xxx10Kx-C-7x-SE BXRC-xxx10Kx-D-7x-SE Maximum Drive Current2 3600mA 3420mA 4200mA Maximum Peak Pulsed Drive Current3 5140mA 4890mA 6000mA Maximum Reverse Voltage4 -90V -120V -65V Notes for Table 6: 1. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. Arrays may be driven at higher currents however lumen maintenance may be reduced. 3. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed current indicate values where the LED array can be driven without catastrophic failures. 4. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 13 Performance Curves Figure 1: Vero SE 10B Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 2: Vero SE 10C Drive Current vs. Forward Voltage (Tj=Tc=25°C) 800 600 700 600 Forward Current (mA) Forward Current (mA) 500 400 300 200 500 400 300 200 100 0 100 32 33 34 35 36 37 0 38 32 33 34 Figure 3: Vero SE 10D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 38 900 800 600 Forward Current (mA) Forward Current (mA) 37 1000 700 500 400 300 200 700 600 500 400 300 200 100 100 24 25 26 27 28 0 29 32 33 34 35 36 37 38 Forward Voltage (V) Forward Voltage (V) Figure 5: Vero SE 13C Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 6: Vero SE 13D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 1400 1100 1000 1200 900 1000 Forward Current (mA) Forward Current (mA) 36 Figure 4: Vero SE 13B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 800 0 35 Forward Voltage (V) Forward Voltage (V) 800 600 400 800 700 600 500 400 300 200 200 100 0 32 33 34 35 Forward Voltage (V) 36 37 38 0 29 30 31 32 33 34 35 Forward Voltage (V) 14 Performance Curves Figure 8: Vero SE 18C Drive Current vs. Forward Voltage (Tj=Tc=25°C) 2000 2700 1800 2400 1600 2100 1400 Forward Current (mA) Forward Current (mA) Figure 7: Vero SE 18B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 1200 1000 800 600 400 1500 1200 900 600 300 200 0 1800 32 33 34 35 36 37 38 0 39 32 33 34 35 Figure 9: Vero SE 18D Drive Current vs. Forward Voltage (Tj=Tc=25°C) Forward Current (mA) Forward Current (mA) 39 3500 1750 1500 1250 1000 750 500 3000 2500 2000 1500 1000 500 250 0 26 27 28 29 30 31 32 47 48 49 50 51 52 53 54 55 56 57 58 Forward Voltage (V) Forward Voltage (V) Figure 11: Vero SE 29C Drive Current vs. Forward Voltage (Tj=Tc=25°C) Figure 12: Vero SE 29D Drive Current vs. Forward Voltage (Tj=Tc=25°C) 4000 4500 3500 4000 3000 3500 Forward Current (mA) Forward Current (mA) 38 4000 2000 2500 2000 1500 1000 3000 2500 2000 1500 1000 500 500 0 37 Figure 10: Vero SE 29B Drive Current vs. Forward Voltage (Tj=Tc=25°C) 2250 0 36 Forward Voltage (V) Forward Voltage (V) 0 63 64 65 66 67 68 69 70 71 Forward Voltage (V) 72 73 74 75 76 33 34 35 36 37 38 39 40 41 42 Forward Voltage (V) 15 Performance Curves Figure 14: Vero SE 10C Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 13: Vero SE 10B Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 100 200 300 400 500 0% 600 0 100 200 300 Forward Current (mA) 600 700 800 Figure 16: Vero SE 13B Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 500 Forward Current (mA) Figure 15: Vero SE 10D Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 40% 80% 60% 40% 20% 20% 0% 0 100 200 300 400 500 600 700 0% 800 0 100 200 300 Forward Current (mA) 400 500 600 700 800 900 1000 Forward Current (mA) Figure 17: Vero SE 13C Typical Relative Luminous Flux vs. Drive Current Figure 18: Vero SE 13D Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 400 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 100 250 400 550 700 850 Forward Current (mA) 1000 1150 1300 0 100 200 300 400 500 600 700 800 900 1000 1100 Forward Current (mA) 16 Performance Curves Figure 20: Vero SE 18C Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 19: Vero SE 18B Typical Relative Luminous Flux vs. Drive Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 200 400 600 800 1000 1200 1400 1600 1800 0% 2000 100 400 700 Forward Current (mA) 1000 1300 1600 1900 2200 2500 Forward Current (mA) Figure 21: Vero SE 18D Typical Relative Luminous Flux vs. Drive Current Figure 22: Vero SE 29B Typical Relative Luminous Flux vs. Drive Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux y = -7E-08x2 + 0.001x + 0.027 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 0 2400 500 1000 Forward Current (mA) 200% 200% 180% 180% 160% 160% 140% 140% 120% 100% 80% 60% 2000 2400 Forward Current (mA) 4000 60% 20% 0% 1600 3500 80% 40% 1200 3000 100% 20% 800 2500 120% 40% 400 2000 Figure 24: Vero SE 29C Typical Relative Luminous Flux vs. Drive Current Relative Luminous Flux Relative Luminous Flux Figure 23: Vero SE 29C Typical Relative Luminous Flux vs. Drive Current 0 1500 Forward Current (mA) 2800 3200 3600 4000 0% 0 500 1000 1500 2000 2500 3000 3500 4000 4500 Forward Current (mA) 17 Performance Curves Figure 25: Vero SE 10 Typical DC Flux vs. Case Temperature1 Figure 26: Vero SE 13 Typical DC Flux vs. Case Temperature1 103% Neutral White 25°C Pulsed 97% 94% 91% 88% Warm White Neutral White 100% Cool White Relative Luminous Flux Relative Luminous Flux 103% Warm White 100% 85% Cool White 25°C Pulsed 97% 94% 91% 88% 85% 82% 82% 0 25 50 75 100 125 0 25 Case Temperature (°C) Figure 27: Vero SE 18 Typical DC Flux vs. Case Temperature1 75 100 125 Figure 28: Vero SE 29 Typical DC Flux vs. Case Temperature1 103% 103% Warm White Neutral White 100% 25°C Pulsed 97% 94% 91% 88% 85% Warm White Neutral White 100% Cool White Relative Luminous Flux Relative Luminous Flux 50 Case Temperature (°C) Cool White 25°C Pulsed 97% 94% 91% 88% 85% 82% 0 25 50 75 100 125 Case Temperature (°C) 82% 0 25 50 75 100 125 Case Temperature (°C) Note for Figures 25-28: 1. Flux measurements taken under DC conditions. 2. Characteristics shown for warm white based on 3000K and 80 CRI. 3. Characteristics shown for neutral white based on 4000K and 80 CRI. 4. Characteristics shown for cool white based on 5000K and 70 CRI. 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 18 Performance Curves Figure 29: 3000K Class A Color Shift vs. Case Temperature1 0.37 0.369 15°C 25°C 0.367 0.366 15°C Pulsed Center Point Color, Tc=25°C 0.368 0.368 25°C 0.366 45°C Pulsed Center Point Color, Tc=25°C 45°C 0.365 ccy ccy Figure 30: 3500K Class A Color Shift vs. Case Temperature1 0.364 0.364 70°C 0.363 70°C 0.362 85°C 85°C 0.362 0.36 0.361 105°C 105°C 0.36 0.416 0.4165 0.417 ccx 0.4175 0.418 0.4185 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Figure 31: 4000K Class A Color Shift vs. Case Temperature1 0.3760 15°C 0.3740 25°C 0.3720 Pulsed Center Point Color, Tc=25°C 45°C ccy 0.3700 0.3680 70°C 0.3660 85°C 0.3640 105°C 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Note for Figures 29-31: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 19 Typical Radiation Pattern Figure 32: Typical Spatial Radiation Pattern Notes for Figure 32: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 33: Typical Polar Radiation Pattern 20 Mechanical Dimensions Figure 34: Drawing for Vero SE 10 LED Array Notes for Figure 34: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.01mm. 4. Mounting slots (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 21 Mechanical Dimensions Figure 35: Drawing for Vero SE 13 LED Array Notes for Figure 35: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.01mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 22 Mechanical Dimensions Figure 36: Drawing for Vero SE 18 LED Array Notes for Figure 36: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.01mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 23 Mechanical Dimensions Figure 37: Drawing for Vero SE 29 LED Array Notes for Figure 37: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.01mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 24 Packaging and Labeling Figure 38: Drawing for Vero SE 10 Packaging Tray Notes for Figure 38: 1. Dimensions are in millimeters. 2. Drawings are not to scale. Figure 39: Drawing for Vero SE 13 Packaging Tray Notes for Figure 39: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 25 Packaging and Labeling Figure 40: Drawing for Vero SE 18 Packaging Tray Notes for Figure 40: 1. Dimensions are in millimeters. 2. Drawings are not to scale. Figure 41: Drawing for Vero SE 29 Packaging Tray Notes for Figure 41: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 26 Packaging and Labeling Figure 42: Vero SE Series Packaging and Labeling Notes for Figure 42: 1. Each tray holds 100 COBs for Vero 10 SE, Vero 13 SE, and Vero 18 SE and 50 COBs for Vero 29 SE. 2. Each tray is vacuum sealed in ansalesfanti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 43: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E1000C 73 27 Design Resources Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing is on going. Please contact your Bridgelux sales representative for more information. 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero SE LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero SE LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero SE LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 28 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/Bridgelux-inc-_2 WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8401 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Décor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Décor Series Class A on Vero SE Series Product Data Sheet DS125 Rev A (10/2016) 29
BXRC-35A4001-D-73-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-35A4001-D-73-SE”相匹配的价格&库存,您可以联系我们找货
