BXRE-50C2000-C-24
BXRE-50C2000-C-24
    BRIDGELUX(普瑞)
    BXRE-50C2000-C-24
BXRE-50C2000-C-24 数据手册
Bridgelux V13 Array ® Product Data Sheet DS44 BXRE-27x2000 | 30x2000 | 35x2000 | 40x2000 | 50x2000 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These Chip-on-Board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V13 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED Arrays deliver increased system level efficacy and longer service life. Typical applications include, but are not limited to, replacement lamps, task, accent, spot, track, down light, wide area, security, and wall pack. Features Benefits • Market leading efficacy of 130 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 70, 80 and 90 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • Energy Star / ANSI compliant color binning structure with 3SDCM and 4SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Flux & Electrical Characteristics 6 Absolute Maximum Ratings 7 Performance Curves 8 Typical Radiation Pattern 11 Typical Color Spectrum 12 Mechanical Dimensions 13 Color Binning Information 14 Packaging 15 Design Resources 17 Precautions 17 Disclaimers 17 About Bridgelux 18 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties Solder Pads White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Designed to comply with global safety standards for creepage and clearance distances Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 2000 – C – 23 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K CCT Bin Options 23 = 3 SDCM 24 = 4 SDCM Array Configuration Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Nominal Flux 2000 = 2000lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E2000-C-23 2700 80 500 1985 1856 32.3 16.2 123 BXRE-27G2000-C-23 2700 90 500 1660 1549 32.3 16.2 103 BXRE-30E2000-C-23 3000 80 500 2120 1921 32.3 16.2 131 BXRE-30G2000-C-23 3000 90 500 1682 1570 32.3 16.2 104 BXRE-35E2000-C-23 3500 80 500 2150 1964 32.3 16.2 133 BXRE-40E2000-C-23 4000 80 500 2200 2022 32.3 16.2 135 BXRE-40G2000-C-23 4000 90 500 1900 1786 32.3 16.2 118 BXRE-50C2000-C-24 5000 70 500 2315 2134 32.3 16.2 143 BXRE-50E2000-C-24 5000 80 500 2200 1990 32.3 16.2 136 BXRE-50G2000-C-24 5000 90 500 2015 1809 32.3 16.2 125 Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 8,9 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux Tc = 85ºC (lm) Minimum DC Flux10 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E2000-C-23 2700 80 500 1818 1700 31.3 15.6 116 BXRE-27G2000-C-23 2700 90 500 1461 1363 31.3 15.6 93 BXRE-30E2000-C-23 3000 80 500 1910 1730 31.3 15.6 122 BXRE-30G2000-C-23 3000 90 500 1480 1382 31.3 15.6 95 BXRE-35E2000-C-23 3500 80 500 1947 1779 31.3 15.6 123 BXRE-40E2000-C-23 4000 80 500 1984 1824 31.3 15.6 127 BXRE-40G2000-C-23 4000 90 500 1672 1572 31.3 15.6 107 BXRE-50C2000-C-24 5000 70 500 2037 1878 31.3 15.6 130 BXRE-50E2000-C-24 5000 80 500 1936 1751 31.3 15.6 124 BXRE-50G2000-C-24 5000 90 500 1773 1592 31.3 15.6 113 Notes for Tables 1 & 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at nominal test current are guaranteed by 100% test. 8. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27E2000-C-23 BXRE-27G2000-C-23 BXRE-30E2000-C-23 BXRE-30G2000-C-23 BXRE-35E2000-C-23 CRI 80 90 80 90 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 30.2 5.3 761 696 144 350 31.4 11.0 1448 1325 132 500 32.3 16.2 1985 1818 123 700 33.4 23.4 2634 2418 113 1050 35.1 36.9 3566 3293 97 175 30.2 5.3 636 559 120 350 31.4 11.0 1211 1065 110 500 32.3 16.2 1660 1461 103 700 33.4 23.4 2203 1943 94 1050 35.1 36.9 2982 2646 81 175 30.2 5.3 812 731 154 350 31.4 11.0 1547 1392 141 500 32.3 16.2 2120 1910 131 700 33.4 23.4 2813 2540 120 1050 35.1 36.9 3809 3459 103 175 30.2 5.3 644 567 122 350 31.4 11.0 1227 1079 112 500 32.3 16.2 1682 1480 104 700 33.4 23.4 2232 1969 95 1050 35.1 36.9 3022 2681 82 175 30.2 5.3 824 746 156 350 31.4 11.0 1569 1419 143 500 32.3 16.2 2150 1947 133 700 33.4 23.4 2853 2590 122 1050 35.1 36.9 3863 3527 105 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-40E2000-C-23 BXRE-40G2000-C-23 BXRE-50C2000-C-24 BXRE-50E2000-C-24 BXRE-50G2000-C-24 CRI 80 90 70 80 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 30.2 5.3 843 760 158 350 31.4 11.0 1605 1446 145 500 32.3 16.2 2200 1984 135 700 33.4 23.4 2919 2640 124 1050 35.1 36.9 3952 3594 106 175 30.2 5.3 728 640 138 350 31.4 11.0 1386 1219 126 500 32.3 16.2 1900 1672 118 700 33.4 23.4 2521 2224 108 1050 35.1 36.9 3413 3028 93 175 30.2 5.3 887 780 168 350 31.4 11.0 1689 1485 154 500 32.3 16.2 2315 2037 143 700 33.4 23.4 3072 2710 131 1050 35.1 36.9 4159 3690 113 175 30.2 5.3 843 741 159 350 31.4 11.0 1605 1411 146 500 32.3 16.2 2200 1936 136 700 33.4 23.4 2919 2576 125 1050 35.1 36.9 3952 3507 107 175 30.2 5.3 772 679 146 350 31.4 11.0 1470 1292 134 500 32.3 16.2 2015 1773 125 700 33.4 23.4 2674 2359 114 1050 35.1 36.9 3620 3212 98 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Minimum Typical Maximum 500 29.9 32.3 34.7 -17 1050 32.0 35.1 37.9 -17 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.22 28.5 35.8 0.28 30.6 39.0 BXRE-xxx2000-C-2x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 6 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds Maximum Drive Current3,4,5 1050mA Maximum Peak Pulsed Drive Current6 1500mA Maximum Reverse Voltage7 -55V Notes for Table 5: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN41: Assembly Considerations for Bridgelux V Series LED Arrays. 3. DC Forward Current for LM-80 is the maximum drive current for which LM-80 data is currently available. 4. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. Contact your Bridgelux sales representatives for LM-80 report. 5. Arrays may be driven at higher currents however lumen maintenance may be reduced. 6. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 7. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 7 Performance Curves Figure 1: Drive Current vs. Voltage (Tj = Tc = 25°C) Figure 2: Typical Relative Luminous Flux vs. Current (Tj = Tc = 25°C) Note for Figure 2: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 8 Performance Curves Figure 3: Typical DC Flux vs. Case Temperature Figure 4: Typical DC ccy Shift vs. Case Temperature Notes for Figures 3-4: 1. 2. 3. 4. Characteristics shown for warm white based on 3000K and 80 CRI. Characteristics shown for neutral white based on 4000K and 80 CRI. Characteristics shown for cool white based on 5000K and 70 CRI. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 9 Performance Curves Figure 5: Typical DC ccx Shift vs. Case Temperature Notes for Figure 5: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 10 Typical Radiation Pattern Figure 6: Typical Spatial Radiation Pattern Note for Figure 6: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where Iv is ½ of the peak value. Figure 7: Typical Polar Radiation Pattern 11 Typical Color Spectrum Figure 8: Typical Color Spectrum Note for Figure 8: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown for warm white is 3000K and 80 CRI. 3. Color spectra shown for neutral white is 4000K and 80 CRI. 4. Color spectra shown for cool white is 5000K and 70 CRI. 12 Mechanical Dimensions Figure 9: Drawing for V13 LED Array Notes for Figure 9: 1. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 2. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 3. Drawings are not to scale. 4. Drawing dimensions are in millimeters. 5. Unless otherwise specified, tolerances are ± 0.10mm. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.45 mm 7. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN40 and AN41 for product handling, mounting and heat sink recommendations. 13 Color Binning Information Figure 10: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 03 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 02 (2SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 11: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5600K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) 04 (4SDCM) (4801K - 5282K) (5475K - 5830K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) 14 Packaging Figure 12: Drawing for V13 Packaging Tray Notes for Figure 12: 1. Dimensions are in millimeters 2. Tolerances: X.X = ± 0.25, X.XX = ± 0.13, X°0’ = ±0°30’ 3. Trays are stackable without interference and will not stick together during unstacking operation 15 Packaging Figure 13: V Series Packaging and Labeling Notes for Figure 13: 1. Each tray holds 84 LEDs, 10 trays are stacked and one empty tray placed on top to cover the top tray. 2. Stacked trays are to contain only 1 part number and be vacuum sealed in an anti-static bag and placed in its own individual box. 3. Each bag and box is to be labeled as shown above. 16 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For a list of of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both SAT and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN41 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. V Series LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the V Series LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the V Series LED array or yellow resin area during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 17 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid state lighting (SSL), expanding the market for light emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. For more information about the company, please visit bridgelux.com. 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2015 Bridgelux, Inc. All rights reserved 2015. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and V Series are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V13 Array Series Product Data Sheet DS44 Rev. B (03/2015) 18
BXRE-50C2000-C-24 价格&库存
很抱歉,暂时无法提供与“BXRE-50C2000-C-24”相匹配的价格&库存,您可以联系我们找货
