ZFS-10504-RGB
ZFS-10504-RGB
    JKLCOMPONENTS
    ZFS-10504-RGB
ZFS-10504-RGB 数据手册
10mm X 5040mm RGB LIGHT RIBBON FEATURES VOLTAGE: 12V DC CURRENT: 3A LED VIEWING ANGLE (2 0 1/2): 100° STANDARD PACKAGING: 5 METER REEL (150 LED"S OPTIONAL PACKAGING: INDIVIDUAL 504mm SECTIONS (15 LED'S) ORDER AS ZFS-10504-RGB/SEC Note: Individual Sections ARE NOT supplied with insulated wire connections. 5040mm (198.42") 17.5mm (.69") 100mm (3.94") +12V G +12V G R B R B 33.0mm (1.30") +12V G R B +12V G R B 2.3mm REF. (.09") 10.0mm (.394") 0.53mm REF. (.02") ADHESIVE TAPE FOR MOUNTING + Electrical/Optical Characteristics at TA = 25ºC Parameter Forward Voltage DC Dominant Wavelength Luminous Flux Color Condition Min Typ Max Unit VF RGB IF = 3A -- 12 -- V R IF = 1A 621 624 -- G IF = 1A 515 518 -- λD φV IF = 1A 469 471 -- IF = 1A -- 95 -- G IF = 1A -- 330 -- B IF = 1A -- 95 -- -- -- -- 3 -- G R B nm Mating Components ZFS-CH0-RGB10J Im + IF(rec) B R DC 12V + Recommend Forward Current Symbol A Flex to Flex No Solder Connector 14.2mm (.56") 16.7mm (.66") ZCH-170-RGB-J Flex Ribbon Joiner Harness 14.4mm (.57") 15.8mm (.61") ATTENTION OBSERVE PRECAUTION FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES K MATING COMP. PART # TO ZFS-CH0-RGB10J J CHANGE SEQUENCE OF WIRE COLORS I ADD SEGMENT DIM LENGTH H CHANGE MATING COMPONENTS G ADD UL SYMBOL F ADD MATING COMPONENT RELEASE & CANCEL PL-0802-06 REV. NO. DESCRIPTION/ECO NUMBER E365522 JKL PART NO.: ZFS-10504-RGB DIMENSIONS ARE METRIC IN mm (INCHES) 8/9/16 TOLERANCE UNLESS 2/18/16 OTHERWISE SPECIFIED 4/9/15 1 PL +/- REF. 2 PL +/- REF. THIRD ANGLE 6/4/14 ANGLE +/PROJECTION 12/9/13 DRAWN BY APPV'D BY DATE 5/20/13 8/9/16 L. WENGSTROM L.R. 5/12/09 APPV'D DATE - CAD DRAWING - MANUAL REVISIONS NOT PERMITTED COMPONENTS CORPORATION TITLE RGB LED FLEX STRIP SIZE A SCALE FSCM NO. 55335 NONE DRAWING NO. ZFS-10504-RGB RELEASED DATE 5/12/09 REVISION DATE 8/9/16 REV. NO. K SHEET 1 OF 1
ZFS-10504-RGB 价格&库存
很抱歉,暂时无法提供与“ZFS-10504-RGB”相匹配的价格&库存,您可以联系我们找货
