ZFS-105000-DBW
ZFS-105000-DBW
    JKLCOMPONENTS
    ZFS-105000-DBW
ZFS-105000-DBW 数据手册
DOUBLE WHITE LED FLEX RIBBON Features VOLTAGE: 12V DC CURRENT: 4200mA LED VIEWING ANGLE (2 0 1/2): 120° STANDARD PACKAGING: 5 Meter Reel (300 LED's) OPTIONAL PACKAGING: Individual 500mm Sections (30 LED's) Order as ZFS-105000-DBW/XXSEC Note: Individual Sections ARE NOT supplied with insulated wire connection. Maximum Ratings Parameter Symbol Rating Unit Electrostatic Discharge ESD 800 V Operating Temperature Topr -0~+40 ºC Storage Temperature Tstg -40~+100 ºC Accessories ZCTR-05: RF Wireless Touch LED Remote Controller Electro-Optical Characteristics (Ta = 25° C) Color Number Input of LED's Voltage Power Current Radiance per Reel (V DC) (W) (A) Angle Cool White 300 12 25.0 2.1 120º 6475 1740 Warm White 300 12 25.0 2.1 120º 3284 1620 10.2mm (.40") [2] 200mm REF. (7.87") + + + + + L1 L1 L1 L1 L1 L2 L2 L2 L2 L2 10.00mm (.394") 50.8±0.25mm (2.00±.010") 2.4mm REF. (.095") Adhesive Tape for Mounting ATTENTION Note: Please refer to JKL Application Sheet JKL- AS-ZFS-105000-DBW OBSERVE PRECAUTION FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES LED FLEX for Installation and Power Recommendations. METRIC DIMENSIONS ARE IN mm (INCHES) TOLERANCE UNLESS OTHERWISE SPECIFIED TITLE REV. NO. ADD UL SYMBOL ADD TAPE SYMBOL NOTE RELEASED DESCRIPTION/ECO NUMBER + = 12V Positive Connection L1 = CW Ground L2 = WW Ground 5000mm (196.85") 16.54mm (.65") UL-1007 24 AWG Wires B A CCT (K) Lumen Flux (lm) THIRD ANGLE PROJECTION 1 PL +/2 PL +/ANGLE +/- REF. REF. 3/31/15 DRAWN BY APPV'D BY DATE 10/9/14 L. WENGSTROM S.C. 3/31/15 3/18/14 APPV'D DATE - CAD DRAWING - MANUAL REVISIONS NOT PERMITTED SIZE A SCALE COMPONENTS CORPORATION DOUBLE WHITE 12V LED FLEX RIBBON FSCM NO. 55335 NONE DRAWING NO. ZFS-105000-DBW RELEASED DATE 3/18/14 REVISION DATE 3/31/15 REV. NO. B SHEET 1 OF 1
ZFS-105000-DBW
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间,适用于高速数据传输和隔离接口。
3. 引脚分配:EL817有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:包括最大正向电流、最大反向电压等。
5. 功能详解:EL817通过内部发光二极管和光敏三极管实现电信号隔离。
6. 应用信息:适用于高速数据传输、隔离接口、工业控制系统等。
7. 封装信息:EL817采用DIP-6封装。
ZFS-105000-DBW 价格&库存
很抱歉,暂时无法提供与“ZFS-105000-DBW”相匹配的价格&库存,您可以联系我们找货
