ZM-3537-CW
ZM-3537-CW
    JKLCOMPONENTS
    ZM-3537-CW
ZM-3537-CW 数据手册
WIDE BEAM LED CHANNEL MODULE FEATURES WIDE BEAM ANGLE (160°) LONG LIFE 50,000 HOURS TO L70 EASY INSTALLATION WATER RESISTANT IP67 LOW WORKING VOLTAGE 12 VDC 5 YEAR WARRANTY OPERATING TEMPERATURE -20°C TO +70°C STANDARD PACKAGING: 30 MODULES PER STRAND / 6 METERS Ø2.98mm (.12") 13mm (.50") 5.6mm (.22") 35mm (1.38") 35mm (1.38") 8.08mm (.32") 200mm (7.87") NOTES: 1. 2. 3. 4. 5. 6. 7.28mm (.29") 37mm (1.47") Double Sided Tape on Backside of Modules. Use a Number 3 Screw for Mounting. Wire with Red Stripe is Positive Input 20 AWG Wire. Use no more than 50 Modules in Series. Can be used with a ZPS-1260 Power Supply. SPECIFICATIONS JKL Module Part Number ZM-3537-CW ATTENTION Input Voltage 12 VDC Power Per Module 1 Watt CCT 6500K Beam Angle 160 o CRI Luminus Flux Per Module 80 100 lm JKL PART NUMBER: ZM-3537-CW METRIC OBSERVE PRECAUTION FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES B A REV. NO. ADD CANADIAN-US SYMBOL ADD UL CERTIFICATION RELEASE DESCRIPTION/ECO NUMBER DIMENSIONS ARE IN mm (INCHES) TOLERANCE UNLESS OTHERWISE SPECIFIED THIRD ANGLE PROJECTION 1 PL +/2 PL +/ANGLE +/- REF. 9/16/19 DRAWN BY APPV'D BY DATE 8/12/15 L. WENGSTROM S.N. 9/16/19 7/21/15 APPV'D DATE - CAD DRAWING - MANUAL REVISIONS NOT PERMITTED COMPONENTS CORPORATION TITLE WIDE BEAM LED CHANNEL MODULE SIZE A SCALE FSCM NO. 55335 NONE DRAWING NO. ZM-3537-CW RELEASED DATE 7/21/15 REVISION DATE 9/16/19 REV. NO. B SHEET 1 OF 1
ZM-3537-CW 价格&库存
很抱歉,暂时无法提供与“ZM-3537-CW”相匹配的价格&库存,您可以联系我们找货
