LZP-00H100-0000
LZP-00H100-0000
    AMSOSRAM(艾迈斯半导体)
    LEDLUXIGENHORTICULTURERGBSMD
LZP-00H100-0000 数据手册
PRELIMINARY LuxiGen Horticulture Emitter Series LZP Multi-Wavelength Horticulture LED Emitter LZP-00H100 Key Features  Ultra-high Photosynthetic Photon Flux (PPF) surface mount ceramic package LED with integrated glass lens  Blue 450nm, Deep Red 660nm, Far Red 740nm and Green 520nm in a single LED package for optimum overall plant growth  70W power dissipation in a compact 12.0mm x 12.0mm emitter footprint  Industry lowest thermal resistance per package footprint (0.5°C/W)  In-source mixing based on smart die positioning for optimum wavelength uniformity  Electrically neutral thermal path  JEDEC Level 1 for Moisture Sensitivity Level  Lead (Pb) free and RoHS compliant  Emitter available on 4-channel Star and Connectorized MCPCB (optional)  Full suite of TIR secondary optics family available Typical Applications  Horticulture lighting Description The LZP-00H100 horticulture LED emitter incorporates multiple wavelengths critical for optimum plant growth: Blue 450nm, Deep Red 660nm, Far Red 740nm and Green 520nm. From a compact 12.0mm x 12.0mm footprint, it produces an ultra-high Photosynthetic Photon Flux (PPF) value of 106umol/s, maximizing the Photosynthetic Photon Flux Density (PPFD) in a given area. The emitter’s smart die positioning pre-mixes the colors in the emitter level for optimum wavelength uniformity on the plant surface. The ultra-low thermal resistance of the package dissipates 70W of heat efficiently resulting in excellent flux output and flux maintenance over time. The glass primary lens and other high quality materials used in the package are designed to deliver monumental robustness in challenging grow environment with high ambient temperature and humidity. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED LZP-00H100 (Pre – 10/24/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Part Number Options Base part number Part number Description LZP-00H100-xxxx LZP Horticulture emitter LZP-L0H100-xxxx LZP Horticulture emitter on 4 channel Star MCPCB LZP-W0H100-xxxx LZP Horticulture emitter on 4 channel Connectorized MCPCB Bin kit option codes: H1, Horticulture Kit number suffix Min flux Bin Color Bin Ranges Description Full distribution flux; full distribution wavelength 0000 Notes: 1. Default bin kit option is -0000 COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED 2 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Absolute Maximum Ratings Table 4: Parameter DC Forward Current [1] Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature Soldering Temperature [4] Symbol IF IFP VR Tstg TJ Tsol Value 1000 1500 See Note 3 -40 ~ +150 125 260 Unit mA mA V °C °C °C Notes for Table 4: 1. Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 11 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 5. 5. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZP-00H100 in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 5: Parameter Symbol PPF 280-800nm (@ IF = 700mA) PPF 280-800nm (@ IF = 1000mA) Radiant Flux (@ IF = 700mA) Radiant Flux (@ IF = 1000mA) Peak Wavelength Viewing Angle [2] Total Included Angle [3] Φ Φ ΛP 2Θ½ Θ0.9 8 Deep Red 33 46 5.4 7.6 660 Typical 8 Blue [1] 25 33 7.7 10.3 450 125 140 4 Far Red 13 19 1.9 2.7 740 4 Green 6 8 1.3 1.6 520 Total 77 106 16.3 22.2 Unit umol/s umol/s W W nm Degrees Degrees Notes for Table 5: 1. When operating the Blue LED, observe IEC 62471 Risk Group 2 rating. Do not stare into the beam. 2. Viewing Angle is the off axis angle from emitter centerline where the luminous intensity is ½ of the peak value. 3. Total Included Angle is the total angle that includes 90% of the total luminous flux. Electrical Characteristics @ TC = 25°C Table 6: Parameter Symbol Forward Voltage (@ IF = 700mA) [1] Forward Voltage (@ IF = 1000mA) [1] Temperature Coefficient of Forward Voltage Thermal Resistance (Junction to Case) VF VF 8 Deep Red 18.8 20.0 ΔVF/ΔTJ -36.8 Typical 4 Far Red 8 Blue 8.2 25.6 8.8 26.4 RΘJ-C -8.0 -16.0 0.5 4 Green 14.4 15.0 -11.6 Unit V V mV/°C °C/W Notes for Table 6: 1. Forward Voltage typical value is for all LED dice from the same color dice connected in series. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED 3 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com IPC/JEDEC Moisture Sensitivity Level Table 7 – IPC/JEDEC J-STD-20 MSL Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 unlimited ≤ 30°C/ 60% RH 168 +5/-0 85°C/ 60% RH n/a n/a Notes for Table 7: 1. The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and includes the maximum time allowed out of the bag at the distributor’s facility. Mechanical Dimensions (mm) Ch. Die Color Function 18 B Deep Red Anode + I Deep Red K Deep Red na na R Deep Red T Far Red na 2 U Far Red Cathode - 17 E Blue Anode + F Blue H Blue na na 1 2 na Blue Q Green na 3 X Green Cathode - 15 A Deep Red Cathode - C Deep Red J Deep Red na na na L Deep Red S Far Red na 5 V Far Red Anode + 14 D Blue G Blue Anode + na M Blue N Blue P Green na W Green Y N/A na Cathode - 4 Notes: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. Thermal slug is electrically isolated 3. Ts is a thermal reference point na O 3 Figure 1: Package outline drawing. Pin Out Pad 6 na na DNC pins: 1,4,7,8,9,10,11,12,13,16,19,20,21,22,23,24. Note: DNC = Do Not Connect (Electrically Non Isolated) COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED 4 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Relative Spectral Power Distribution 1.00 0.90 Relative Spectral Power 0.80 0.70 Deep Red 0.60 Far Red Blue 0.50 Green 0.40 0.30 0.20 0.10 0.00 400 450 500 550 600 650 Wavelength (nm) 700 750 800 850 Figure 5: Typical relative spectral power vs. wavelength @ TC = 25°C. Typical Radiation Pattern 100% 90% 80% Relative Intensity 70% 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 Angular Displacement (Degrees) 40 50 60 70 80 90 Figure 4: Typical representative spatial radiation pattern COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED 5 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZP-Lxxxxx 4-Channel MCPCB Mechanical Dimensions (mm) Note: • Unless otherwise noted, the tolerance = ± 0.20 mm. • Slots in MCPCB are for M3 or #4-40 mounting screws. • The thermal resistance of the MCPCB is: RΘC-B 0.1°C/W Components used MCPCB: ESD chips: NTC: MHE-301 copper BZX884-B39 NCP15XH103F03RC Ch. 1 (D. Red + F. Red) 2 (Blue + Green) 3 (D. Red + F. Red) 4 (Blue + Green) NTC Pad layout MCPCB String/die Pad 8 1/ BIKRTU 1 7 2/ EFHOQX 2 3 3/ ACJLSV 6 5 4/ DGMNPWY 4 1-RT 10kohm NTC 2-RT COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED (Rayben) (NXP, for 6-7 LED dies in series) (Murata) Function Anode + Cathode Anode + Cathode Anode + Cathode Anode + Cathode NTCA NTCB 6 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZP-Wxxxxx 4-Channel 50mm Connectorized MCPCB Mechanical Dimensions (mm) Note: • • • • Unless otherwise noted, the tolerance = ± 0.20 mm. Mating connector: ZHR-8 (JST) for the 8-pin connector and ZHR-2 (JST) for the 2-pin connector. It is recommended to strain relief the mating connector. LED Engin standard screw refers to M3 or #4-40 screw. The thermal resistance of the MCPCB is: RΘC-B 0.1°C/W Components used MCPCB: Connectors1: MHE-301 copper S8B-ZR-SM4A-TF S2B-ZR-SM4A-TF RC1206JR-070RL SPHV36-01ETG NCP15XH103F03RC Jumper: ESD/TVS diode: Thermistor: Note: 1. Max connector temp is 105°C. MCPCB Pin-Out (at J1 connector) Connector Pin String/die 1 1 1/ BIKRTU (D. Red + F. Red) 2 Ch. 2 (Blue + Green) 3 (D. Red + F. Red) 4 (Blue + Green) Ch. NTC 3 4 5 6 8 7 2/ EFHOQX 3/ ACJLSV 4/ DGMNPWY MCPCB Pin-Out (at J2 connector) Connector Pin String 1 10kohm NTC 2 COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED (Rayben) (JST) (JST) (Yageo) (Littelfuse) (Murata) Function Anode + Cathode Anode + Cathode Anode + Cathode Anode + Cathode Function NTCA NTCB 7 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Company Information LED Engin, Inc., based in California’s Silicon Valley, specializes in ultra-bright, ultra compact solid state lighting solutions allowing lighting designers & engineers the freedom to create uncompromised yet energy efficient lighting experiences. The LuxiGen™ Platform — an emitter and lens combination or integrated module solution, delivers superior flexibility in light output, ranging from 3W to 90W, a wide spectrum of available colors, including whites, multi-color and UV, and the ability to deliver upwards of 5,000 high quality lumens to a target. The small size combined with powerful output allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin’s packaging technologies lead the industry with products that feature lowest thermal resistance, highest flux density and consummate reliability, enabling compact and efficient solid state lighting solutions. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions. LED Engin reserves the right to make changes to improve performance without notice. Please contact sales@ledengin.com or (408) 922-7200 for more information. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED 8 LZP-00H100 (1.2 – 03/01/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com
LZP-00H100-0000 价格&库存
很抱歉,暂时无法提供与“LZP-00H100-0000”相匹配的价格&库存,您可以联系我们找货
