SBT-16-B-M11-EPC
SBT-16-B-M11-EPC
    LUMINUS(朗明纳斯)
    LED SBT16 BLUE 460NM 4SMD
SBT-16-B-M11-EPC 数据手册
PRODUCT DATA SHEET PhlatLight™ SBT16 Projection Chipset Technology Overview Features Luminus Devices’ Projection Technology (PT) is an innovative solid-state light source created to replace arc lamps in projection systems, enabling a new category of lamp-free projectors. Enabled by unique use of Photonic Lattice technology, PhlatLight chipsets represent a major breakthrough in brightness that delivers all the benefits of solid state light sources in projections applications: • Matched RGB Chipset with 1.6mm2 emitting area designed - Wide color gamut for vivid colors, exceeds NTSC. - Environmentally friendly technology - Mercury-fre. - Instant start and re-start - no more wait time. for small, pico projector and “value” pocket projector applications • Photonic lattice technology for very high surface brightness • Wide color gamut: RED 623 nm, GREEN 525 nm, BLUE 460 nm typical dominant wavelength • Single emitting area per color allows for collection with single lens for simplified optics • 16:10 aspect ratio optimized for WVGA, WXGA or other wide aspect ratio micro-displays - High reliability; no more lamp replacement. • Uniform surface emission - Electronic control of color points and light intensity on a frame by frame basis • Compact, small footprint surface mount (SMT) package, with PhlatLight products benefit from numerous innovations in the domain of packaging, thermal management and optical coupling that allow designers to achieve efficient light engine designs and deliver high screen brightness. Angular Intensity Distribution -Example Applications • Large dynamic range allows optimum performance in both battery-powered and AC powered systems • Optimized for Micro-Display diagonal sizes ranging from 0.2” 1.2 to 0.4”. GR EEN , B LU E R ED Optical Power (Arbitrary Unit) built-in alignment features • RoHS compliant (EU-2002/95/EC Directive) 1.0 • Compatible with all micro-display technologies including DLP™ and LCoS. 0.8 0.6 0.4 0.2 0.0 -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (degrees) Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved Updated 05/17/11 PDS-001478 Rev 04 SBT16 - Product Datasheet Rev 04 • SBT-16 Ordering Part Numbers Ordering Part Number1 Color Min Flux or Power Bin2 Availability Description 1A Now SBT-16-R-J11-MPC 1B Now Red Bin Kit, PhlatLight SBT16 surface mount device consisting of a 1.6mm2 LED, mounted on a ceramic substrate. SBT-16-G-J11-MPA 1A Now 1B Now SBT-16-G-J11-MPC 1C Now SBT-16-G-J11-MPD 1D Now 1A Now 1B Now SBT-16-R-J11-MPB Red SBT-16-G-J11-MPB Green SBT-16-B-J11-EPA Blue SBT-16-B-J11-EPB Note 1: Note 2: Green Bin Kit, PhlatLight SBT16 surface mount device consisting of a 1.6mm2 LED, mounted on a ceramic substrate Blue Bin Kit, PhlatLight SBT16 surface mount device consisting of a 1.6mm2 LED, mounted on a ceramic substrate Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) See Bin Kit and Flux / Power bin definitions on page 3 • PhlatLight Ordering Part Number Nomenclature SBT Product Family SBT: Surface mount SBR: SBT device soldered to a starboard - NN Chip Area 16: 1.6mm2 - X Color R=Red G=Green B=Blue - J11 Package Configuration J11: 9.0mm X 7.25mm - XYZ - TR1 Bin Kit 2 Packaging Option See page 3 for Bin Kit definition TR= tape & reel blank=tray/pack Note 1: For Tape and Reel Packaging option, please add -TR to end of ordering part number. E.g. SBT-16-R-J11-MPB-TR Note 2: A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. In order to ensure availability, individual flux or power bins are not orderable. EXAMPLES: SBT-16-R-J11-MPB is comprised of Red Flux Bins 1A, 1B, 1C and 1D (Packaging option: trays / packs) SBT-16-R-J11-MPB-TR is comprised of Red Flux Bins 1A, 1B, 1C and 1D (Packaging option: tape and reel) SBR-16-R-J11-MPB is SBT-16 Red device soldered to a starboard (see p.10). Note: Available in sample quantities only for prototyping. Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 2 SBT16 - Product Datasheet Rev 04 • SBT-16 Bin Kit1 and Flux / Power Bin2,3 ,4 Definitions Note: Please refer to ordering part number table on page 2 for Bin Kit availability Red Flux Bins Bin 1A Bin 1B Bin 1C Bin 1D Bin 1E Bin 1F Bin 1G Bin 1H Bin 1J Red Bin Flux Range (lm) 155-180 180-215 215-245 245-275 275-300 300-330 330-360 nd nd SBT-16-R-J11-MPB ; SBT-16-R-J11-MPC ; ; ; ; ; ; ; Green Flux Bins Bin 1A Bin 1B Bin 1C Bin 1D Bin 1E Bin 1F Bin 1G Bin 1H Bin 1J Green Bin Flux Range (lm) 315-355 355-395 395-430 430-470 470-510 510-550 550-600 600-660 660-725 SBT-16-G-J11-MPA ; SBT-16-G-J11-MPB ; ; ; ; ; ; ; ; ; ; ; ; ; ; SBT-16-G-J11-MPC SBT-16-G-J11-MPD ; Blue Power Bins Bin 1A Bin 1B Bin 1C Bin 1D Bin 1E Bin 1F Bin 1G Bin 1H Bin 1J Blue Bin Power Range (W) 1.54-1.75 1.75-1.95 1.95-2.10 2.10-2.30 2.30-2.50 2.50-2.75 2.75-3.00 3.00-3.30 nd SBT-16-B-J11-EPA SBT-16-B-J11-EPB ; ; ; ; ; ; ; ; ; ; Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux bin will be shipped in each individual pack or reel. A shipment will contain packs or reels of different allowed flux or power bins for a particular ordering part number. In order to ensure availability, individual Flux or Power bins are not ordereable. Note 2: Luminus maintains a tolerance of +/-6% on flux and power measurements Note 3: SBT-16 LEDs are tested for luminous flux and radiometric at 4A, single pulse (20mS) and placed into one of the above flux or power bins. Flux and power bins have been defined, but not all defined bins are currently populated. Note 4: Flux bin limits for Red and Green and power bin limits for Blue devices apply across the entire dominant wavelength range for each color. (See dominant wavelength range for each color on page 4) Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 3 SBT16 - Product Datasheet Rev 04 Optical and Electrical Characteristics Symbol Emitting Area Emitting Area Dimensions Red Green Blue Unit 1.6 1.6 1.6 mm2 1.6x1.0 1.6x1.0 1.6x1.0 mmxmm Characteristics at Test Drive Current, IF1 Test Peak Drive Current1 typ IF 4.0 4.0 4.0 A 1,2 ,3 typ Φv 220 470 90 lm typ Φr 1.3 1.0 2.0 W min λdmin 619 516 450 nm typ λd 623 525 460 nm max λdmax 630 535 468 nm typ Δλd 18 40 20 nm typ x 0.699 0.162 0.149 typ y 0.301 0.711 0.031 min VFmin 2.0 3.9 3.2 V typ VF 2.4 4.9 3.9 V max VFmax 3.2 5.9 5.2 V typ Ωdyn 0.08 0.09 0.07 Ω 25 50 25 % 4.0 4.0 4.0 A Peak Luminous Flux Radiometric Flux 1, 2, 3 Dominant Wavelength1 FWHM - Spectral bandwidth at 50% of Φv Chromaticity Coordinates 4,5 Forward Voltage Dynamic Resistance Characteristics at Pulsed Drive Current, IF (for information only) 6 Reference Duty Cycle Reference Peak Drive Current typ IF Peak Luminuous Flux2 typ 215 400 80 lm Thermal Coefficient of Photometric Flux typ -1.1 -0.2 ~0 % / ºC Thermal Coefficient of Radiometric Flux typ -0.6 -0.3 -0.1 % / ºC Forward Voltage Temperature Coefficient typ -3 -8 -4 mV / ºC Device Thermal Characteristics Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Test conditions: 4A, single pulse, 20ms, test temperature not controlled. Total flux from emitting area Luminus maintains a tolerance of +/-6% on flux and power measurements In CIE 1931 chromaticity diagram coodinates, normalized to X+Y+Z=1 For reference only Typical performance based on SBT-16 mounted on Al coreboard. Operation at 720Hz, 4A, pulsed at the specified duty cycles and at constant heat sink temperature Ths = 40ºC. ( See Thermal Resistance section for Ths definition.) Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 4 SBT16 - Product Datasheet Rev 04 Absolute Maximum Ratings Symbol Minimum Current (CW or Pulsed) 1 Maximum Current (CW) 2 Red Green EP-Blue Unit Min 200 200 200 mA Max 2.4 2.4 2.4 A 4.8 4.8 4.8 A 110 150 150 ºC -40/+100 -40/+100 -40/+100 ºC Maximum Current (pulsed) 1,3 (t 240Hz, duty cycle 240Hz, duty cycle < 60%). Please refer to absolute maximum rating table above for specific absolute maximum currents for the products covered in this datasheet. Product lifetime data is specified at recommended forward drive currents. Sustained operation at absolute maximum currents will result in a reduction of device lifetime compared to recommended forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the lifetime derating curves for further information. Note 3: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds. Note 4: Sustained operation at or above the Absolute Maximum Junction Temperature (Tjmax) will result in reduced device life time. Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 5 SBT16 - Product Datasheet Rev 04 Luminous Flux variation with Wavelength: Φv = f (λd) at Test Drive Current IF 200 150 100 700 150 600 125 3.5 500 0 400 620 625 630 λd (nm) 635 2.0 1.5 1.0 75 Blue Flux, lm 515 520 525 530 λd (nm) 450 535 0.5 Blue Power, W 50 200 615 3.0 2.5 100 300 50 4.0 Фr (W) 300 250 Фv (lm) Фv (lm) 350 Фv (lm) 400 455 460 465 λd (nm) 0.0 470 See note 1,3 on page 7. 150 700 250 600 125 200 500 100 150 400 Фv (lm) 300 Фv (lm) Фv (lm) Luminous Flux variation with Drive Current - Φv = f (IF) - Typical 300 100 200 50 1 2 3 IF (A) 4 0 0 5 50 25 100 0 75 1 2 3 IF (A) 4 1 5 2 3 IF (A) 4 5 See notes 1, 2, 3 on page 7. 540 628 535 626 624 622 530 525 620 520 618 515 1 2 3 IF (A) 4 5 λd (nm) 630 λd (nm) λd (nm) Dominant Wavelength variation with Forward Current - λd = f(IF) - Typical 1 2 3 IF (A) 4 5 468 466 464 462 460 458 456 454 452 450 1 2 3 IF (A) 4 5 See notes 1, 2 on page 7. Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 6 SBT16 - Product Datasheet Rev 04 Forward Voltage variation with Drive current - VF = f(IF) - Typical 3 VF (V) 2 1.5 1 5 4.0 4 3.0 VF (V) 2.5 VF (V) 5.0 6 3 2.0 2 0.5 1 0 0 1 2 3 4 5 1.0 0.0 1 2 3 4 5 IF (A) IF (A) 1 2 3 4 5 IF (A) See notes 1,2 on page 7. Optical Spectrum (Typical) Normalized radiometric power 1.2 1 0.8 0.6 0.4 0.2 0 400 450 500 550 600 650 700 Wavelength (nm ) See note 4 on page 7. Chart Notes Note 1: Test conditions: single pulse , 20mS, test temperature not controlled. Data below 1.5A is extrapolated. Note 2: Yellow square indicate device operating point under test conditions: 4A, single 20mS pulse, test temperature not controlled. Note 3: Luminus maintains a tolerance of +/-6% on flux and power measurements. Note 4: Typical Spectrum at recommended peak drive current. Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 7 SBT16 - Product Datasheet Rev 04 Thermal Resistance Window Tj Die Junction Rj-c1 6.0 oC/W Tc Window Frame Rj-hs 2 7.4 oC/W Ceramic Substrate Al coreboard Note 1: Ths Note 2: Heat sink Thermal resistance values are based on finite element analysis model results For information only. Thermal resistance is measured using a SAC305 solder, an Alclad MCPCB (Bergquist p/n 803949-1), and eGraf 1205 thermal interface material. Confidential © 2011 Luminus Devices, Inc. - All Rights Reserved PDS-001478 Rev 04 Page 8 SBT16 - Product Datasheet Rev 04 Mechanical Dimensions 6(&7,21$$     $ [  %  $  (0,77,1* $5($ “ %$&.2)68%675$7( 5(&200(1'('/$
SBT-16-B-M11-EPC 价格&库存
很抱歉,暂时无法提供与“SBT-16-B-M11-EPC”相匹配的价格&库存,您可以联系我们找货
