BXEN-40E-13H-9B-00-0-0
    BRIDGELUX(普瑞)
    发光二极管/LED 白色 2835 SMT
BXEN-40E-13H-9B-00-0-0 数据手册
Bridgelux Gen2 SMD 2835 1W 9V ® Product Data Sheet DS58 PRELIMINARY Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY | | | | | | BXEN-27E 30E 35E 40E 50E 57E 65E SMD 2835 Introduction The Bridgelux SMD 2835 high power LED is hot-color targeted which ensures that the LEDs fall within their specified color bin at the typical application conditions of 85°C. With its broad lumen coverage and wide range of CCT options, the SMD 2835 provides unparalleled design-in flexibility for indoor and outdoor lighting applications. The SMD 2835 is ideal as a drop in replacement for emitters with an industry standard 2.8mm x 3.5mm footprint. Features Benefits • Industry-standard 2835 footprint • Lower operating and manufacturing cost • 9 bin color control enables tight color control • Ease of design and rapid go-to-market • Hot-color targeting ensures that color is within the ANSI bin at the typical application conditions of 85°C • Uniform consistent white light • Enables 3- and 5-step MacAdam ellipse custom binning kits • RoHS compliant and lead free • Multiple CCT configurations for a wide range of lighting applications Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY • Reliable and constant white point • Environmentally friendly, complies with standards • Design flexibility Contents Product Feature Map 2 Product Nomenclature 2 Product Test Conditions 2 Product Selection Guide 3 Electrical Characteristics 4 Absolute Maximum Ratings 5 Product Bin Definitions 6 Performance Curves 9 Typical Radiation Pattern 10 Mechanical Dimensions 11 Reliability 12 Reflowing Characteristics 13 Packaging 14 Design Resources 16 Precautions 16 Disclaimers 16 About Bridgelux 17 Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 1 - Preliminary Product Feature Map Bridgelux SMD LED products come in industry standard package sizes and follow ANSI binning standards. These LEDs are optimized for cost and performance, helping to ensure highly competitive system lumen per dollar performance while addressing the stringent efficacy and reliability standards required for modern lighting applications. Cathode Mark Yellow phosphor Light Emitting Surface (LES) Product Nomenclature The part number designation for Bridgelux SMD 2835 is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 12 1314 15 16 BXEN – 30 E – 1 3 H – 9 B – 00 – 0 – 0 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Color Bin Options Forward Voltage Bins Flux Bins Product Version Minimum CRI E = 80 CRI Typical Forward Voltage High Power Die count in series Die count in parallel Product Test Conditions Bridgelux SMD 2835 LEDs are tested and binned with a 10ms pulse of 100mA at Tj (junction temperature)=Tsp (solder point temperature) =25°C. Forward voltage and luminous flux are binned at a Tj=Tsp=25°C, while color is hot targeted at a Tsp of 85°C. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 2 - Preliminary Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data at 100mA (Tj=Tsp=25°C) Part Number1,6 Nominal CCT2 (K) CRI3, 5 Nominal Drive Current (mA) Forward Voltage4, 5 (V) Min Typical Max Typical Pulsed Flux (lm)4, 5 Typical Power (W) Typical Efficacy (lm/W) BXEN-27E-13H-9B-00-0-0 2700 80 100 8.6 9.5 9.8 115 1.0 121 BXEN-30E-13H-9B-00-0-0 3000 80 100 8.6 9.5 9.8 120 1.0 126 BXEN-35E-13H-9B-00-0-0 3500 80 100 8.6 9.5 9.8 123 1.0 129 BXEN-40E-13H-9B-00-0-0 4000 80 100 8.6 9.5 9.8 127 1.0 134 BXEN-50E-13H-9B-00-0-0 5000 80 100 8.6 9.5 9.8 127 1.0 134 BXEN-57E-13H-9B-00-0-0 5700 80 100 8.6 9.5 9.8 127 1.0 134 BXEN-65E-13H-9B-00-0-0 6500 80 100 8.6 9.5 9.8 125 1.0 132 Typical DC Flux (lm)5 Typical Power (W) Typical Efficacy (lm/W) 110 Table 2: Selection Guide, Stabilized DC Performance (T­sp = 85°C)7,8 Forward Voltage5 (V) Part Number1,6 Nominal CCT2 (K) CRI3, 5 Nominal Drive Current (mA) Min Typical Max BXEN-27E-13H-9B-00-0-0 2700 80 100 8.3 9.2 9.5 101 0.9 BXEN-30E-13H-9B-00-0-0 3000 80 100 8.3 9.2 9.5 106 0.9 115 BXEN-35E-13H-9B-00-0-0 3500 80 100 8.3 9.2 9.5 108 0.9 118 BXEN-40E-13H-9B-00-0-0 4000 80 100 8.3 9.2 9.5 112 0.9 122 BXEN-50E-13H-9B-00-0-0 5000 80 100 8.3 9.2 9.5 112 0.9 122 BXEN-57E-13H-9B-00-0-0 5700 80 100 8.3 9.2 9.5 112 0.9 122 BXEN-65E-13H-9B-00-0-0 6500 80 100 8.3 9.2 9.5 110 0.9 120 Notes for Table 1 & 2: 1. The last 6 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-0-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEN-30E-13H-9B-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI, 1x3 die configuration, high power, 9.5V typical forward voltage. 2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011. 3. Listed CRIs are minimum values and include test tolerance. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where T­j=T­sp=25°C. 5. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI measurements for the SMD 2835. 6. Refer to Table 5 and Table 6 for Bridgelux SMD 2835 Luminous Flux Binning and Forward Voltage Binning information. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED emitter mounted onto a heat sink with thermal interface material and the solder point temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 3 - Preliminary Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage (V) 2,3 Part Number 1 BXEN-xxE-13H-9B-00-0-0 Drive Current (mA) 100 Minimum Typical Maximum 8.6 9.5 9.8 Typical Temperature Coefficient of Forward Voltage ∆Vf/∆T (mV/ºC) Typical Thermal Resistance Junction to Solder Point4 R j-sp (ºC/W) -5.2 10 Notes for Table 3: 1. The last 6 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-0-00” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEN-30E-13H-9B-00-0-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI, 1x3 die configuration, high power, 9.5V typical forward voltage. 2. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Voltage minimum and maximum values at the nominal drive current are guaranteed by 100% test. 3. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tsp = 25°C. 4. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 4 - Preliminary Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Solder Point Temperature (TSp) -40°C to +105°C Soldering Temperature 260°C or lower for a maximum of 10 seconds Maximum Drive Current 120mA Maximum Peak Pulsed Forward Current1 240mA Maximum Reverse Voltage Bridgelux LEDs are not designed to be driven in reverse bias Moisture Sensitivity Rating MSL 3 Electrostatic Discharge 2kV HBM. JEDEC-JS-001-HBM and JEDEC-JS-001-2012 Notes for Table 4: 1. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 10 ms when operating LED SMD at maximum peak pulsed current specified. Maximum peak pulsed current indicate values where LED SMD can be driven without catastrophic failures. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 5 - Preliminary Product Bin Definitions Table 5 lists the standard photometric luminous flux bins for Bridgelux SMD 2835 LEDs. Although several bins are listed, product availability in a particular bin varies by production run and by product performance. Not all bins are available in all CCTs. Table 5: Luminous Flux Bin Definitions at 100mA, Tsp=25°C Bin Code Minimum Maximum 5C 100 105 5D 105 110 5E 110 115 5F 115 120 5G 120 125 5H 125 130 5J 130 135 5K 135 140 Unit Condition lm IF=100mA Unit Condition V IF=100mA Note for Table 5: 1. Bridgelux maintains a tolerance of ± 7.5% on luminous flux measurements. Table 6: Forward Voltage Bin Definition at 100mA, Tsp=25°C Bin Code Minimum Maximum T 8.6 8.8 U 8.8 9.0 V 9.0 9.2 W 9.2 9.4 X 9.4 9.6 Y 9.6 9.8 Note for Table 6: 1. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 6 - Preliminary Product Bin Definitions Table 7: 3- and 5-step MacAdam Ellipse Color Bin Definitions CCT 2700K 3000K 3500K 4000K 5000K 5700K 6500K Color Space Center Point Major Axis Minor Axis Ellipse Rotation Angle Color Bin 0.00810 0.00420 53.70 1 0.4101 0.01350 0.00700 53.70 1/A/B/C/D 0.4030 0.00834 0.00408 53.22 1 0.4030 0.01390 0.00680 53.22 1/A/B/C/D 0.3961 0.00927 0.00414 54.00 1 X Y 3 SDCM 0.4578 0.4101 5 SDCM 0.4578 3 SDCM 0.4338 5 SDCM 0.4338 3 SDCM 0.4103 5 SDCM 0.4103 0.3961 0.01545 0.00690 54.00 1/A/B/C/D 3 SDCM 0.3818 0.3797 0.00939 0.00402 53.72 1 5 SDCM 0.3818 0.3797 0.01565 0.00670 53.72 1/A/B/C/D 3 SDCM 0.3447 0.3553 0.00822 0.00354 59.62 1 5 SDCM 0.3447 0.3553 0.01370 0.00590 59.62 1/A/B/C/D 3 SDCM 0.3287 0.3417 0.00746 0.00320 59.09 1 5 SDCM 0.3287 0.3417 0.01243 0.00533 59.09 1/A/B/C/D 3 SDCM 0.3123 0.3282 0.00669 0.00285 58.57 1 5 SDCM 0.3123 0.3282 0.01115 0.00475 58.57 1/A/B/C/D Notes for Table 7: 1. Color binning at Tsp=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 7 - Preliminary Product Bin Definitions Figure 1: C.I.E. 1931 Chromaticity Diagram (9 Color Bin Structure, hot-color targeted at Tsp=85°C) Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 8 - Preliminary Performance Curves Figure 2: Drive Current vs. Voltage (Tsp=25°C) 140 Forward Current (mA) 120 100 80 60 40 20 0 7.8 8 8.2 8.4 8.6 8.8 9 9.2 9.4 9.6 9.8 10 Forward Voltage (V) Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tsp=25°C) 140% Relative Luminous Flux 120% 100% 80% 60% 40% 20% 0% 0 20 40 60 80 100 120 140 Forward Current (mA) Note for Figure 3: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 9 - Preliminary Typical Radiation Pattern Figure 4: Typical Spatial Radiation Pattern at 100mA, Tsp=25°C 100% 90% 80% Relative Intensity 70% 60% 50% 40% 30% 20% 10% 0% -90 -75 -60 -45 -30 -15 0 15 30 45 60 75 90 Angular Displacement (⁰) Notes for Figure 4: 1. Typical viewing angle is 116⁰. 2. The viewing angle is defined as the off axis angle from the centerline where luminous intensity (Iv) is ½ of the peak value. Figure 5: Typical Polar Radiation Pattern at 100mA, Tsp=25°C Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 10 - Preliminary Mechanical Dimensions Figure 6: Drawing for SMD 2835 Cathode Mark Notes for Figure 6: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. Recommended PCB Soldering Pad Pattern Bridgelux Gen2 SMD 2835 1w 9V Product Data Sheet DS58 Rev. B (10/2016) - PRELIMINARY 11 - Preliminary Reliability Table 8: Reliability Test Items and Conditions No . Items R而非人eference Standard Test Conditions Drive Current Test Duration Units Failed/Tested 1 Moisture/Reflow Sensitivity J-STD-020E Tsld = 260°C, 10sec, Precondition: 60°C, 60%RH, 168hr - 3 reflows 0/22 2 Low Temperature Storage JESD22-A119 Ta=-40°C - 1000 hours 0/22 3 High Temperature Storage JESD22-A103D Ta= 100°C - 1000 hours 0/22 4 Low Temperature Operating Life JESD22-A108D Ta=-40°C 100mA 1000 hours 0/22 5 Temperature Humidity Operating Life JESD22-A101C Tsp=85°C℃, RH=85% 100mA 1000 hours 0/22 6 High Temperature Operating Life JESD22-A108D Tsp=105°C 120mA 1000 hours 0/22 7 Power switching IEC62717:2014 Tsp= 105°C 30 sec on, 30 sec off 120mA 30000 cycles 0/22 8 Thermal Shock JESD22-A106B Ta=-40°C ~100°C; Dwell : 15min; Transfer: 10sec - 200 cycles 0/22 9 Temperature Cycle JESD22-A104E Ta=-40°C ~100°C; Dwell at extreme temperature: 15min; Ramp rate < 105°C/min - 200 cycles 0/22 10 Electrostatic Discharge JS-001-2012 HBM, 2KV, 1.5kΩ, 100pF, Alternately positive or negative - - 0/22 Passing Criteria Item Symbol Test Condition Passing Criteria Forward Voltage Vf 100mA ΔΔVf
BXEN-40E-13H-9B-00-0-0 价格&库存
很抱歉,暂时无法提供与“BXEN-40E-13H-9B-00-0-0”相匹配的价格&库存,您可以联系我们找货
  • 17000+0.2964117000+0.03849
  • 34000+0.2789834000+0.03623
  • 51000+0.2700451000+0.03507
  • 85000+0.2599285000+0.03375
  • 119000+0.25392119000+0.03297
  • 170000+0.25001170000+0.03247
库存:17000
