BXEP-30E-1C5-36A-00-00-0
    BRIDGELUX(普瑞)
    SMD5050
    发光二极管/LED 白色,暖色 SMD5050 SMT
BXEP-30E-1C5-36A-00-00-0 数据手册
Bridgelux SMD 5050 5W 36V ® Product Data Sheet DS64 Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) | | | | | | | | BXEP-27E 30E 35E 40E 45E 50E 57E 65E SMD 5050 Introduction The Bridgelux SMD 5050 high power LED is hot-color targeted which ensures that the LEDs fall within their specified color bin at the typical application conditions of 85°C. With its broad lumen coverage and wide range of CCT options, the SMD 5050 provides unparalleled design-in flexibility for indoor and outdoor lighting applications. The SMD 5050 is ideal as a drop in replacement for emitters with an industry standard 5.0mm x 5.0mm footprint. Features Benefits • Industry-standard 5050 footprint • Lower operating and manufacturing cost • 3 bin color control enables tight color control • Ease of design and rapid go-to-market • Hot-color targeting ensures that color is within the ANSI bin at the typical application conditions of 85°C • Uniform consistent white light • Enables 3- and 5-step MacAdam ellipse custom binning kits • RoHS compliant and lead free • Multiple CCT configurations for a wide range of lighting applications Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) • Reliable and constant white point • Environmentally friendly, complies with standards • Design flexibility Contents Product Feature Map 2 Product Nomenclature 2 Product Test Conditions 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 6 Absolute Maximum Ratings 7 Product Bin Definitions 8 Performance Curves 11 Typical Radiation Pattern 14 Typical Color Spectrum 15 Mechanical Dimensions 16 Reliability 17 Reflowing Characteristics 18 Packaging 19 Design Resources 21 Precautions 21 Disclaimers 21 About Bridgelux 22 Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 1 Product Feature Map Bridgelux SMD LED products come in industry standard package sizes and follow ANSI binning standards. These LEDs are optimized for cost and performance, helping to ensure highly competitive system lumen per dollar performance while addressing the stringent efficacy and reliability standards required for modern lighting applications. Yellow phosphor Light Emitting Surface (LES) Cathode Mark Product Nomenclature The part number designation for Bridgelux SMD 5050 is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 12 1314 15 16 BXEP – 30 E – 1 C 5 – 36 A – 00 – 00 – 0 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 45 = 4,500K 50 = 5,000K 57 = 5,700K 65 = 6,500K Color Bin Options Forward Voltage Bins Flux Bins Product Version Minimum CRI E = 80 CRI Typical Forward Voltage Power 5 = 4.7W Die count in series C = 12 Die count in parallel Product Test Conditions Bridgelux SMD 5050 LEDs are tested and binned with a 10ms pulse of 125mA at Tj (junction temperature)=Tsp (solder point temperature) =25°C. Forward voltage and luminous flux are binned at a Tj=Tsp=25°C, while color is hot targeted at a Tsp of 85°C. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data at 125mA (Tj=Tsp=25°C) Part Number1,6 Nominal CCT2 (K) CRI3, 5 Forward Voltage4, 5 (V) Nominal Drive Current (mA) Min Typical Max Typical Pulsed Flux (lm)4, 5 Typical Power (W) Typical Efficacy (lm/W) BXEP-27E-1C5-36A-00-00-0 2700 80 125 34 37.2 40.8 579 4.7 125 BXEP-30E-1C5-36A-00-00-0 3000 80 125 34 37.2 40.8 600 4.7 129 BXEP-35E-1C5-36A-00-00-0 3500 80 125 34 37.2 40.8 614 4.7 132 BXEP-40E-1C5-36A-00-00-0 4000 80 125 34 37.2 40.8 626 4.7 135 BXEP-45E-1C5-36A-00-00-0 4500 80 125 34 37.2 40.8 629 4.7 135 BXEP-50E-1C5-36A-00-00-0 5000 80 125 34 37.2 40.8 629 4.7 135 BXEP-57E-1C5-36A-00-00-0 5700 80 125 34 37.2 40.8 629 4.7 135 BXEP-65E-1C5-36A-00-00-0 6500 80 125 34 37.2 40.8 624 4.7 134 Typical DC Flux (lm)5 Typical Power (W) Typical Efficacy (lm/W) Table 2: Selection Guide, Stabilized DC Performance (T­sp = 85°C)7,8 Part Number1,6 Nominal CCT2 (K) CRI3, 5 Forward Voltage5 (V) Nominal Drive Current (mA) Min Typical Max BXEP-27E-1C5-36A-00-00-0 2700 80 125 32.9 36.1 39.7 504 4.5 111 BXEP-30E-1C5-36A-00-00-0 3000 80 125 32.9 36.1 39.7 522 4.5 116 BXEP-35E-1C5-36A-00-00-0 3500 80 125 32.9 36.1 39.7 534 4.5 118 BXEP-40E-1C5-36A-00-00-0 4000 80 125 32.9 36.1 39.7 545 4.5 121 BXEP-45E-1C5-36A-00-00-0 4500 80 125 32.9 36.1 39.7 547 4.5 121 BXEP-50E-1C5-36A-00-00-0 5000 80 125 32.9 36.1 39.7 547 4.5 121 BXEP-57E-1C5-36A-00-00-0 5700 80 125 32.9 36.1 39.7 547 4.5 121 BXEP-65E-1C5-36A-00-00-0 6500 80 125 32.9 36.1 39.7 543 4.5 120 Notes for Table 1 & 2: 1. The last 7 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-00-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEP-30E-1C5-36A-00-00-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI, 1x12 die configuration, 4.7w power, 37.2V typical forward voltage. 2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011. 3. Listed CRIs are minimum values and include test tolerance. 4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where T­j=T­sp=25°C. 5. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI measurements for the SMD 5050. 6. Refer to Table 6 and Table 7 for Bridgelux SMD 5050 Luminous Flux Binning and Forward Voltage Binning information. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED emitter mounted onto a heat sink with thermal interface material and the solder point temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 3 Performance at Commonly Used Drive Currents SMD 5050 LEDs are tested to the specifications shown using the nominal drive currents in Table 1. SMD 5050 may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 2 and the relative luminous flux vs. current characteristics shown in Figure 3. The performance at commonly used drive currents is summarized in Table 3. Table 3: Performance at Commonly Used Drive Currents Part Number BXEP-27E-1C5-36A-00-00-0 BXEP-30E-1C5-36A-00-00-0 BXEP-35E-1C5-36A-00-00-0 BXEP-40E-1C5-36A-00-00-0 BXEP-45E-1C5-36A-00-00-0 CRI 80 80 80 80 80 Drive Current1 (mA) Typical Vf Tsp = 25°C (V) Typical Power Tsp = 25°C (W) Typical Pulsed Flux2 Tsp = 25°C (lm) Typical DC Flux3 Tsp = 85°C (lm) Typical Efficacy Tsp = 25°C (lm/W) 31 32.8 1.0 161 145 157 63 34.5 2.2 311 277 145 94 35.9 3.4 451 396 134 125 37.2 4.7 579 504 125 200 39.8 8.0 846 698 106 31 32.8 1.0 167 150 163 63 34.5 2.2 323 287 150 94 35.9 3.4 467 410 139 125 37.2 4.7 600 522 129 200 39.8 8.0 877 724 110 31 32.8 1.0 171 153 167 153 63 34.5 2.2 330 294 94 35.9 3.4 478 419 142 125 37.2 4.7 614 534 132 200 39.8 8.0 897 741 113 31 32.8 1.0 174 156 170 156 63 34.5 2.2 337 299 94 35.9 3.4 488 428 145 125 37.2 4.7 626 545 135 200 39.8 8.0 915 755 115 31 32.8 1.0 175 157 171 63 34.5 2.2 338 301 157 94 35.9 3.4 490 430 145 125 37.2 4.7 629 547 135 200 39.8 8.0 919 759 116 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7.5% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 4 Performance at Commonly Used Drive Currents Table 3: Performance at Commonly Used Drive Currents (Continued) Part Number BXEP-50E-1C5-36A-00-00-0 BXEP-57E-1C5-36A-00-00-0 BXEP-65E-1C5-36A-00-00-0 CRI 80 80 80 Drive Current1 (mA) Typical Vf Tsp = 25°C (V) Typical Power Tsp = 25°C (W) Typical Pulsed Flux2 Tsp = 25°C (lm) Typical DC Flux3 Tsp = 85°C (lm) Typical Efficacy Tsp = 25°C (lm/W) 31 32.8 1.0 175 157 171 63 34.5 2.2 338 301 157 94 35.9 3.4 490 430 145 125 37.2 4.7 629 547 135 200 39.8 8.0 919 759 116 31 32.8 1.0 175 157 171 63 34.5 2.2 338 301 157 94 35.9 3.4 490 430 145 125 37.2 4.7 629 547 135 200 39.8 8.0 919 759 116 31 32.8 1.0 174 156 169 156 63 34.5 2.2 336 298 94 35.9 3.4 486 426 144 125 37.2 4.7 624 543 134 200 39.8 8.0 912 753 115 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7.5% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 5 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage (V) 2,3 Part Number 1 BXEP-xxE-1C5-36A-00-00-0 Drive Current (mA) Minimum Typical Maximum 34.0 37.2 40.8 125 Typical Temperature Coefficient of Forward Voltage ∆Vf/∆T (mV/ºC) Typical Thermal Resistance Junction to Solder Point4 R j-sp (ºC/W) -17.6 1.9 Notes for Table 4: 1. The last 7 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-00-0” denotes the full distribution of flux, forward voltage, and 7 SDCM color. Example: BXEP-30E-1C5-36A-00-00-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity region with a minimum of 80CRI, 1x12 die configuration, 4.7w power, 37.2V typical forward voltage. 2. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Voltage minimum and maximum values at the nominal drive current are guaranteed by 100% test. 3. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tsp = 25°C. 4. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 6 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Solder Point Temperature (TSp) -40°C to +105°C Soldering Temperature 260°C or lower for a maximum of 10 seconds Maximum Drive Current 200mA Maximum Peak Pulsed Forward Current1 240mA Maximum Reverse Voltage Bridgelux LEDs are not designed to be driven in reverse bias Moisture Sensitivity Rating MSL 3 Electrostatic Discharge 2kV HBM. JEDEC-JS-001-HBM and JEDEC-JS-001-2012 Notes for Table 5: 1. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 10 ms when operating LED SMD at maximum peak pulsed current specified. Maximum peak pulsed current indicate values where LED SMD can be driven without catastrophic failures. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 7 Product Bin Definitions Table 6 lists the standard photometric luminous flux bins for Bridgelux SMD 5050 LEDs. Although several bins are listed, product availability in a particular bin varies by production run and by product performance. Not all bins are available in all CCTs. Table 6: Luminous Flux Bin Definitions at 125mA, Tsp=25°C Bin Code Minimum Maximum A8 505 545 A9 545 590 B1 590 635 B2 635 685 B3 685 740 B4 740 800 B5 800 865 Unit Condition lm IF=125mA Unit Condition V IF=125mA Note for Table 6: 1. Bridgelux maintains a tolerance of ± 7.5% on luminous flux measurements. Table 7: Forward Voltage Bin Definition at 125mA, Tsp=25°C Bin Code Minimum Maximum MD 33.5 35.0 ME 35.0 36.5 MF 36.5 38.0 MG 38.0 39.5 MH 39.5 41.0 Note for Table 7: 1. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 8 Product Bin Definitions Table 8: 3- and 5-step MacAdam Ellipse Color Bin Definitions CCT 2700K 3000K 3500K 4000K 4500K 5000K 5700K 6500K Color Space Center Point Major Axis Minor Axis Ellipse Rotation Angle Color Bin X Y 3 SDCM 0.4578 0.4101 0.00810 0.00420 53.70 3 5 SDCM 0.4578 0.4101 0.01350 0.00700 53.70 5 3 SDCM 0.4338 0.4030 0.00834 0.00408 53.22 3 5 SDCM 0.4338 0.4030 0.01390 0.00680 53.22 5 3 SDCM 0.4103 0.3961 0.00927 0.00414 54.00 3 5 SDCM 0.4103 0.3961 0.01545 0.00690 54.00 5 3 SDCM 0.3818 0.3797 0.00939 0.00402 53.72 3 5 SDCM 0.3818 0.3797 0.01565 0.00670 53.72 5 3 SDCM 0.3611 0.3658 0.00756 0.00338 57.58 3 5 SDCM 0.3611 0.3658 0.01260 0.00563 57.58 5 3 SDCM 0.3447 0.3553 0.00822 0.00354 59.62 3 5 SDCM 0.3447 0.3553 0.01370 0.00590 59.62 5 3 SDCM 0.3287 0.3417 0.00746 0.00320 59.09 3 5 SDCM 0.3287 0.3417 0.01243 0.00533 59.09 5 3 SDCM 0.3123 0.3282 0.00669 0.00285 58.57 3 5 SDCM 0.3123 0.3282 0.01115 0.00475 58.57 5 Notes for Table 8: 1. Color binning at Tsp=85°C 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 9 Product Bin Definitions Figure 1: C.I.E. 1931 Chromaticity Diagram (3 Color Bin Structure, hot-color targeted at Tsp=85°C) Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 10 Performance Curves Figure 2: Drive Current vs. Voltage (Tsp=25°C) 225 200 Forward Current (mA) 175 150 125 100 75 50 25 0 30 31 32 33 34 35 36 37 38 39 40 41 Forward Voltage (V) Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tsp=25°C) 160% 140% Relative Luminous Flux 120% 100% 80% 60% 40% 20% 0% 0 25 50 75 100 125 150 175 200 225 Forward Current (mA) Note for Figure 3: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 11 Performance Curves Figure 4: Typical Relative DC Flux vs. Solder Point Temperature 100% Warm White Neutral White Cool White 25°C Pulsed Relative Luminous Flux 95% 90% 85% 80% 75% 0 25 50 75 100 125 Solder Point Temperature (°C) Figure 5: Typical DC ccx Shift vs. Solder Point Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 -0.010 -0.012 Warm White Neutral White Cool White 25°C Pulsed Solder Point Temperature (°C) Notes for Figures 4 & 5: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 80 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 12 Performance Curves Figure 6: Typical DC ccy Shift vs. Solder Point Temperature 0 25 50 75 100 125 0.000 -0.002 ccy Shift -0.004 -0.006 -0.008 -0.010 -0.012 -0.014 -0.016 Warm White Neutral White Cool White 25°C Pulsed Solder Point Temperature (°C) Notes for Figure 6: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 80 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 13 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern at 125mA, Tsp=25°C 100% 90% 80% Relative Intensity 70% 60% 50% 40% 30% 20% 10% 0% -90 -75 -60 -45 -30 -15 0 15 30 45 60 75 90 Angular Displacement (⁰) Notes for Figure 7: 1. Typical viewing angle is 116⁰. 2. The viewing angle is defined as the off axis angle from the centerline where luminous intensity (Iv) is ½ of the peak value. Figure 8: Typical Polar Radiation Pattern at 125mA, Tsp=25°C Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 14 Typical Color Spectrum Figure 9: Typical Color Spectrum 1.0000 2700K 3000K 4000K Relative Spectral Power Distribution 0.8000 5000K 6500K 0.6000 0.4000 0.2000 0.0000 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 9: 1. Color spectra measured at nominal current for Tsp = 25°C 2. Color spectra shown for warm white is 2700K and 80 CRI. 3. Color spectra shown for warm white is 3000K and 80 CRI. 4. Color spectra shown for neutral white is 4000K and 80 CRI. 5. Color spectra shown for cool white is 5000K and 80 CRI. 6. Color spectra shown for cool white is 6500K and 80 CRI. Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 15 Mechanical Dimensions Figure 10: Drawing for SMD 5050 Notes for Figure 10: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. Recommended PCB Soldering Pad Pattern Bridgelux SMD 5050 5w 36V Product Data Sheet DS64 Rev. B (10/2016) 16 Reliability Table 9: Reliability Test Items and Conditions No . Items R而非人eference Standard Test Conditions Drive Current Test Duration Units Failed/Tested 1 Moisture/Reflow Sensitivity J-STD-020E Tsld = 260°C, 10sec, Precondition: 60°C, 60%RH, 168hr - 3 reflows 0/22 2 Low Temperature Storage JESD22-A119 Ta=-40°C - 1000 hours 0/22 3 High Temperature Storage JESD22-A103D Ta= 105°C - 1000 hours 0/22 4 Low Temperature Operating Life JESD22-A108D Ta=-40°C 125mA 1000 hours 0/22 5 Temperature Humidity Operating Life JESD22-A101C Tsp=85°C℃, RH=85% 125mA 1000 hours 0/22 6 High Temperature Operating Life JESD22-A108D Tsp=105°C 160mA 1000 hours 0/22 7 Power switching IEC62717:2014 Tsp= 105°C 30 sec on, 30 sec off 160mA 30000 cycles 0/22 8 Thermal Shock JESD22-A106B Ta=-40°C ~100°C; Dwell : 15min; Transfer: 10sec - 200 cycles 0/22 9 Temperature Cycle JESD22-A104E Ta=-40°C ~100°C; Dwell at extreme temperature: 15min; Ramp rate < 105°C/min - 200 cycles 0/22 10 Electrostatic Discharge JS-001-2012 HBM, 2KV, 1.5kΩ, 100pF, Alternately positive or negative - - 0/22 Passing Criteria Item Symbol Test Condition Passing Criteria Forward Voltage Vf 125mA ΔΔVf
BXEP-30E-1C5-36A-00-00-0 价格&库存
很抱歉,暂时无法提供与“BXEP-30E-1C5-36A-00-00-0”相匹配的价格&库存,您可以联系我们找货
  • 3000+2.486943000+0.32317
