BXEP-50E-435-09A-00-00-0 数据手册
Bridgelux SMD 5050 5W 9V
Product Data Sheet DS63
Bridgelux SMD 5050 5w 9V Product Data Sheet DS63 Rev. B (10/2016)
BXEP-27E 30E 35E 40E 45E 50E 57E 65E
SMD 5050
Introduction
The Bridgelux SMD 5050 high power LED is hot-color targeted which ensures that the LEDs fall within their specified
color bin at the typical application conditions of 85°C. With its broad lumen coverage and wide range of CCT options, the
SMD 5050 provides unparalleled design-in flexibility for indoor and outdoor lighting applications. The SMD 5050 is ideal
as a drop in replacement for emitters with an industry standard 5.0mm x 5.0mm footprint.
Features
Benefits
• Industry-standard 5050 footprint
• Lower operating and manufacturing cost
• 3 bin color control enables tight color control
• Ease of design and rapid go-to-market
• Hot-color targeting ensures that color is within the
ANSI bin at the typical application conditions of 85°C
• Uniform consistent white light
• Enables 3- and 5-step MacAdam ellipse custom
binning kits
• RoHS compliant and lead free
• Multiple CCT configurations for a wide range of
• Reliable and constant white point
• Environmentally friendly, complies with standards
• Design flexibility
Contents
Product Feature Map
2
Product Nomenclature
2
Product Test Conditions
2
Product Selection Guide
3
Performance at Commonly Used Drive Currents
4
Electrical Characteristics
6
Absolute Maximum Ratings
7
Product Bin Definitions
8
Performance Curves
11
Typical Radiation Pattern
14
Typical Color Spectrum
15
Mechanical Dimensions
16
Reliability
17
Reflowing Characteristics
18
Packaging
19
Design Resources
21
Precautions
21
Disclaimers
21
About Bridgelux
22
1
Product Feature Map
Bridgelux SMD LED products come in industry standard package sizes and follow ANSI binning standards. These LEDs
are optimized for cost and performance, helping to ensure highly competitive system lumen per dollar performance
while addressing the stringent efficacy and reliability standards required for modern lighting applications.
Yellow phosphor Light
Emitting Surface (LES)
Cathode Mark
The part number designation for Bridgelux SMD 5050 is explained as follows:
1 2 3 4
5 6 7
8
9 10
11 12
1314
15
16
BXEP – 30 E – 4 3 5 – 09 A – 00 – 00 – 0
Product Family
Nominal CCT
27 = 2,700K
30 = 3,000K
35 = 3,500K
40 = 4,000K
45 = 4,500K
50 = 5,000K
57 = 5,700K
65 = 6,500K
Color Bin Options
Forward Voltage Bins
Flux Bins
Product Version
Minimum CRI
E = 80 CRI
Typical Forward Voltage
Power
5 = 4.7W
Die count in series
Die count in parallel
Bridgelux SMD 5050 LEDs are tested and binned with a 10ms pulse of 500mA at Tj (junction temperature)=Tsp (solder point
temperature) =25°C. Forward voltage and luminous flux are binned at a Tj=Tsp=25°C, while color is hot targeted at a Tsp of 85°C.
2
The following product configurations are available:
Table 1: Selection Guide, Pulsed Measurement Data at 500mA (Tj=Tsp=25°C)
Part Number1,6
Nominal CCT2
(K)
CRI3, 5
Forward Voltage4, 5
(V)
Nominal
Drive Current
(mA)
Min
Typical
Max
Typical Pulsed
Flux (lm)4, 5
Typical Power
(W)
Typical Efficacy
(lm/W)
BXEP-27E-435-09A-00-00-0
2700
80
500
8.5
9.3
10.2
579
4.7
125
BXEP-30E-435-09A-00-00-0
3000
80
500
8.5
9.3
10.2
600
4.7
129
BXEP-35E-435-09A-00-00-0
3500
80
500
8.5
9.3
10.2
614
4.7
132
BXEP-40E-435-09A-00-00-0
4000
80
500
8.5
9.3
10.2
626
4.7
135
BXEP-45E-435-09A-00-00-0
4500
80
500
8.5
9.3
10.2
629
4.7
135
5000
80
500
8.5
9.3
10.2
629
4.7
135
BXEP-57E-435-09A-00-00-0
5700
80
500
8.5
9.3
10.2
629
4.7
135
BXEP-65E-435-09A-00-00-0
6500
80
500
8.5
9.3
10.2
624
4.7
134
Typical DC Flux
(lm)5
Typical Power
(W)
Typical Efficacy
(lm/W)
Table 2: Selection Guide, Stabilized DC Performance (Tsp = 85°C)7,8
Part Number1,6
Nominal CCT2
(K)
CRI3, 5
Forward Voltage5
(V)
Nominal Drive
Current
(mA)
Min
Typical
Max
2700
80
500
8.2
9.0
9.9
504
4.5
111
3000
80
500
8.2
9.0
9.9
522
4.5
116
3500
80
500
8.2
9.0
9.9
534
4.5
118
4000
80
500
8.2
9.0
9.9
545
4.5
121
4500
80
500
8.2
9.0
9.9
547
4.5
121
5000
80
500
8.2
9.0
9.9
547
4.5
121
5700
80
500
8.2
9.0
9.9
547
4.5
121
6500
80
500
8.2
9.0
9.9
543
4.5
120
Notes for Table 1 & 2:
1. The last 7 characters (including hyphens ‘-’) refer to flux bins, forward voltage bins, and color bin options, respectively. “00-00-0” denotes the full
distribution of flux, forward voltage, and 7 SDCM color.
Example: BXEP-30E-435-09A-00-00-0 refers to the full distribution of flux, forward voltage, and color within a 3000K 7-step ANSI standard chromaticity
region with a minimum of 80CRI, 4x3 die configuration, 4.7w power, 9.3V typical forward voltage.
2. Product CCT is hot targeted at Tsp = 85°C. Nominal CCT as defined by ANSI C78.377-2011.
3. Listed CRIs are minimum values and include test tolerance.
4. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tj=Tsp=25°C.
5. Bridgelux maintains a ±7.5% tolerance on luminous flux measurements, ±0.1V tolerance on forward voltage measurements, and ±2 tolerance on CRI
measurements for the SMD 5050.
6. Refer to Table 6 and Table 7 for Bridgelux SMD 5050 Luminous Flux Binning and Forward Voltage Binning information.
7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
8. Typical performance is estimated based on operation under DC (direct current) with LED emitter mounted onto a heat sink with thermal interface
material and the solder point temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the
luminaire and/or the exposed environment to which the product is subjected.
3
SMD 5050 LEDs are tested to the specifications shown using the nominal drive currents in Table 1. SMD 5050 may also
be driven at other drive currents dependent on specific application design requirements. The performance at any drive
current can be derived from the current vs. voltage characteristics shown in Figure 2 and the relative luminous flux vs.
current characteristics shown in Figure 3. The performance at commonly used drive currents is summarized in Table 3.
Table 3: Performance at Commonly Used Drive Currents
Part Number
CRI
80
80
80
80
80
Drive
Current1
(mA)
Typical Vf
Tsp = 25°C
(V)
Typical Power
Tsp = 25°C
(W)
Typical Pulsed
Flux2
Tsp = 25°C
(lm)
Typical
DC Flux3
Tsp = 85°C
(lm)
Typical
Efficacy
Tsp = 25°C
(lm/W)
125
8.2
1.0
161
145
157
250
8.6
2.2
311
277
144
375
9.0
3.4
451
396
134
500
9.3
4.7
579
504
125
800
10.1
8.1
846
698
105
125
8.2
1.0
167
150
163
250
8.6
2.2
323
287
150
375
9.0
3.4
467
410
138
500
9.3
4.7
600
522
129
800
10.1
8.1
877
724
109
125
8.2
1.0
171
153
167
250
8.6
2.2
330
294
153
375
9.0
3.4
478
419
142
500
9.3
4.7
614
534
132
800
10.1
8.1
897
741
111
125
8.2
1.0
174
156
170
156
250
8.6
2.2
337
299
375
9.0
3.4
488
428
144
500
9.3
4.7
626
545
135
800
10.1
8.1
915
755
113
125
8.2
1.0
175
157
171
157
250
8.6
2.2
338
301
375
9.0
3.4
490
430
145
500
9.3
4.7
629
547
135
800
10.1
8.1
919
759
114
Notes for Table 3:
1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance.
2. Bridgelux maintains a ± 7.5% tolerance on flux measurements.
3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
4
Table 3: Performance at Commonly Used Drive Currents (Continued)
Part Number
CRI
80
80
80
Drive
Current1
(mA)
Typical Vf
Tsp = 25°C
(V)
Typical Power
Tsp = 25°C
(W)
Typical Pulsed
Flux2
Tsp = 25°C
(lm)
Typical
DC Flux3
Tsp = 85°C
(lm)
Typical
Efficacy
Tsp = 25°C
(lm/W)
125
8.2
1.0
175
157
171
250
8.6
2.2
338
301
157
375
9.0
3.4
490
430
145
500
9.3
4.7
629
547
135
800
10.1
8.1
919
759
114
125
8.2
1.0
175
157
171
250
8.6
2.2
338
301
157
375
9.0
3.4
490
430
145
500
9.3
4.7
629
547
135
800
10.1
8.1
919
759
114
125
8.2
1.0
174
156
169
156
250
8.6
2.2
336
298
375
9.0
3.4
486
426
144
500
9.3
4.7
624
543
134
800
10.1
8.1
912
753
113
Notes for Table 3:
5
Table 4: Electrical Characteristics
Forward Voltage
(V) 2,3
Part Number 1
BXEP-xxE-435-09A-00-00-0
Drive Current
(mA)
500
Minimum
Typical
Maximum
8.5
9.3
10.2
Typical
Temperature
Coefficient
of Forward
Voltage
∆Vf/∆T
(mV/ºC)
Typical
Thermal
Resistance
Junction
to Solder Point4
R j-sp (ºC/W)
-4.4
1.9
Notes for Table 4:
2. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements. Voltage minimum and maximum values at the nominal drive current are
guaranteed by 100% test.
3. Products tested under pulsed condition (10ms pulse width) at nominal drive current where Tsp = 25°C.
4. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power.
6
Table 5: Maximum Ratings
Parameter
Maximum Rating
LED Junction Temperature (Tj)
125°C
Storage Temperature
-40°C to +105°C
Operating Solder Point Temperature (TSp)
-40°C to +105°C
Soldering Temperature
260°C or lower for a maximum of 10 seconds
Maximum Drive Current2
800mA
Maximum Peak Pulsed Forward Current1
960mA
Maximum Reverse Voltage
Bridgelux LEDs are not designed to be driven in reverse bias
Moisture Sensitivity Rating
MSL 3
Electrostatic Discharge
2kV HBM. JEDEC-JS-001-HBM and JEDEC-JS-001-2012
Notes for Table 5:
1. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 10 ms when operating LED SMD at maximum peak pulsed current specified.
Maximum peak pulsed current indicate values where LED SMD can be driven without catastrophic failures.
2. The maximum drive current for LM80 test results is at 640mA.
7
Table 6 lists the standard photometric luminous flux bins for Bridgelux SMD 5050 LEDs. Although several bins are listed,
product availability in a particular bin varies by production run and by product performance. Not all bins are available in
all CCTs.
Table 6: Luminous Flux Bin Definitions at 500mA, Tsp=25°C
Bin Code
Minimum
Maximum
A8
505
545
A9
545
590
B1
590
635
B2
635
685
B3
685
740
B4
740
800
B5
800
865
Unit
Condition
lm
IF=500mA
Unit
Condition
V
IF=500mA
Note for Table 6:
1. Bridgelux maintains a tolerance of ± 7.5% on luminous flux measurements.
Table 7: Forward Voltage Bin Definition at 500mA, Tsp=25°C
Bin Code
Minimum
Maximum
CD
8.5
9.0
CE
9.0
9.5
CF
9.5
10.0
CG
10.0
10.5
Note for Table 7:
1. Bridgelux maintains a tolerance of ± 0.1V on forward voltage measurements.
8
Table 8: 3- and 5-step MacAdam Ellipse Color Bin Definitions
CCT
2700K
3000K
3500K
4000K
4500K
5000K
5700K
6500K
Color Space
Center Point
Major Axis
Minor Axis
Ellipse
Rotation Angle
Color Bin
X
Y
3 SDCM
0.4578
0.4101
0.00810
0.00420
53.70
3
5 SDCM
0.4578
0.4101
0.01350
0.00700
53.70
5
3 SDCM
0.4338
0.4030
0.00834
0.00408
53.22
3
5 SDCM
0.4338
0.4030
0.01390
0.00680
53.22
5
3 SDCM
0.4103
0.3961
0.00927
0.00414
54.00
3
5 SDCM
0.4103
0.3961
0.01545
0.00690
54.00
5
3 SDCM
0.3818
0.3797
0.00939
0.00402
53.72
3
5 SDCM
0.3818
0.3797
0.01565
0.00670
53.72
5
3 SDCM
0.3611
0.3658
0.00756
0.00338
57.58
3
5 SDCM
0.3611
0.3658
0.01260
0.00563
57.58
5
3 SDCM
0.3447
0.3553
0.00822
0.00354
59.62
3
5 SDCM
0.3447
0.3553
0.01370
0.00590
59.62
5
3 SDCM
0.3287
0.3417
0.00746
0.00320
59.09
3
5 SDCM
0.3287
0.3417
0.01243
0.00533
59.09
5
3 SDCM
0.3123
0.3282
0.00669
0.00285
58.57
3
5 SDCM
0.3123
0.3282
0.01115
0.00475
58.57
5
Notes for Table 8:
1. Color binning at Tsp=85°C
2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space.
9
Figure 1: C.I.E. 1931 Chromaticity Diagram (3 Color Bin Structure, hot-color targeted at Tsp=85°C)
10
Performance Curves
Figure 2: Drive Current vs. Voltage (Tsp=25°C)
900
800
Forward Current (mA)
700
600
500
400
300
200
100
7.8
8
8.2
8.4
8.6
8.8
9
9.2
9.4
9.6
9.8
10
Forward Voltage (V)
Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tsp=25°C)
160%
140%
120%
100%
80%
60%
40%
20%
0%
200
300
400
500
600
700
800
900
Note for Figure 3:
1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation
(PWM) is recommended for dimming effects.
11
Performance Curves
Figure 4: Typical Relative DC Flux vs. Solder Point Temperature
100%
Warm White
Neutral White
Cool White
25°C Pulsed
95%
90%
85%
80%
75%
50
75
100
125
Solder Point Temperature (°C)
Figure 5: Typical DC ccx Shift vs. Solder Point Temperature
50
75
100
125
0.000
-0.002
ccx Shift
-0.004
-0.006
-0.008
-0.010
-0.012
Warm White
Neutral White
Cool White
25°C Pulsed
Notes for Figures 4 & 5:
1. Characteristics shown for warm white based on 3000K and 80 CRI.
2. Characteristics shown for neutral white based on 4000K and 80 CRI.
3. Characteristics shown for cool white based on 5000K and 80 CRI.
4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information.
12
Performance Curves
Figure 6: Typical DC ccy Shift vs. Solder Point Temperature
50
75
100
125
0.000
-0.002
ccy Shift
-0.004
-0.006
-0.008
-0.010
-0.012
-0.014
-0.016
Warm White
Neutral White
Cool White
25°C Pulsed
Notes for Figure 6:
13
Figure 7: Typical Spatial Radiation Pattern at 500mA, Tsp=25°C
100%
90%
80%
Relative Intensity
70%
60%
50%
40%
30%
20%
10%
0%
-90
-75
-60
-45
-30
-15
30
45
60
75
90
Angular Displacement (⁰)
Notes for Figure 7:
1. Typical viewing angle is 116⁰.
2. The viewing angle is defined as the off axis angle from the centerline where luminous intensity (Iv) is ½ of the peak value.
Figure 8: Typical Polar Radiation Pattern at 500mA, Tsp=25°C
14
Figure 9: Typical Color Spectrum
1.0000
2700K
3000K
4000K
Relative Spectral Power Distribution
0.8000
5000K
6500K
0.6000
0.4000
0.2000
0.0000
400
450
500
550
600
650
700
750
800
Wavelength (nm)
Notes for Figure 9:
1. Color spectra measured at nominal current for Tsp = 25°C
2. Color spectra shown for warm white is 2700K and 80 CRI.
3. Color spectra shown for warm white is 3000K and 80 CRI.
4. Color spectra shown for neutral white is 4000K and 80 CRI.
5. Color spectra shown for cool white is 5000K and 80 CRI.
6. Color spectra shown for cool white is 6500K and 80 CRI.
15
Figure 10: Drawing for SMD 5050
Notes for Figure 10:
1. Drawings are not to scale.
2. Drawing dimensions are in millimeters.
3. Unless otherwise specified, tolerances are ± 0.10mm.
Recommended PCB Soldering Pad Pattern
16
Reliability
Table 9: Reliability Test Items and Conditions
No .
Items
R而非人eference
Standard
Test Conditions
Drive
Current
Test Duration
Units
Failed/Tested
1
Moisture/Reflow Sensitivity
J-STD-020E
Tsld = 260°C, 10sec,
Precondition: 60°C, 60%RH, 168hr
3 reflows
0/22
2
Low Temperature Storage
JESD22-A119
Ta=-40°C
1000 hours
0/22
3
High Temperature Storage
JESD22-A103D
Ta= 105°C
1000 hours
0/22
4
Low Temperature Operating Life
JESD22-A108D
Ta=-40°C
500mA
1000 hours
0/22
5
Temperature Humidity Operating Life
JESD22-A101C
Tsp=85°C℃, RH=85%
500mA
1000 hours
0/22
6
High Temperature Operating Life
JESD22-A108D
Tsp=105°C
640mA
1000 hours
0/22
7
Power switching
IEC62717:2014
Tsp= 105°C
30 sec on, 30 sec off
640mA
30000 cycles
0/22
8
Thermal Shock
JESD22-A106B
Ta=-40°C ~100°C;
Dwell : 15min; Transfer: 10sec
200 cycles
0/22
9
Temperature Cycle
JESD22-A104E
Ta=-40°C ~100°C;
Dwell at extreme temperature: 15min;
Ramp rate < 105°C/min
200 cycles
0/22
10
JS-001-2012
HBM, 2KV, 1.5kΩ, 100pF,
Alternately positive or negative
0/22
Passing Criteria
Item
Symbol
Test Condition
Passing Criteria
Forward Voltage
Vf
500mA
ΔΔVf
