SIT5000AI-2E-18E0-26.000000Y 数据手册
SiT5000
Standard Frequency MEMS (VC)TCXO
The Smart Timing Choice
Features
Applications
27 standard frequencies between 10 MHz and 40 MHz
WiFi, 3G, LTE, SDI, Ethernet, SONET, DSL
100% pin-to-pin drop-in replacement to quartz-based (VC)TCXO
Telecom, networking, smart meter, wireless, test instrumentation
Frequency stability as low as ±5 ppm. Contact SiTime for tighter
stability options
Low phase jitter: 0.5 ps (12 kHz to 20 MHz)
LVCMOS compatible output with SoftEdge™ option for EMI reduction
Voltage control, standby, output enable or no connect modes
Standard 4-pin packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm
Outstanding silicon reliability of 2 FIT, 10 times better than quartz
Pb-free, RoHs and REACH compliant
Electrical Characteristics
Parameter
Output Frequency Range
Symbol
f
Min.
Typ.
Max.
Refer to the frequency list (page 6)
Unit
Condition
MHz
Initial Tolerance
F_init
-1.5
+1.5
ppm
At 25°C after two reflows
Stability Over Temperature
F_stab
-5
+5
ppm
Over operating temperature range at rated nominal power
supply voltage and load. (see ordering codes on page 6)
Supply Voltage
F_vdd
50
ppb
±10% Vdd (±5% for Vdd = 1.8V)
Output Load
F_load
0.1
ppm
15 pF ±10% of load
First year Aging
F_aging
Contact SiTime for tighter stability options.
10-year Aging
Operating Temperature Range
Supply Voltage
Pull Range
T_use
Vdd
-2.5
+2.5
ppm
25°C
-4.0
+4.0
ppm
25°C
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
1.71
1.8
1.89
V
Contact SiTime for any other supply voltage options.
2.25
2.5
2.75
V
2.52
2.8
3.08
V
2.70
3.0
3.3
V
2.97
3.3
3.63
V
PR
±12.5
ppm
Upper Control Voltage
VC_U
Vdd-0.1
V
Control Voltage Range
VC_L
0.1
V
Control Voltage Input Impedance
Z_vc
100
k
Frequency Change Polarity
Control Voltage -3dB Bandwidth
Current Consumption
8
kHz
Idd
31
33
mA
No load condition, f = 20 MHz, Vdd = 2.5V, 2.8V or 3.3V.
29
31
mA
No load condition, f = 20 MHz, Vdd = 1.8V.
31
mA
Vdd = 2.5V, 2.8V or 3.3V, OE = GND, output is Weakly Pulled
Down
30
mA
Vdd = 1.8 V. OE = GND, output is Weakly Pulled Down
70
µA
Vdd = 2.5V, 2.8V or 3.3V, ST = GND, output is Weakly Pulled Down.
10
µA
Vdd = 1.8V. ST = GND, output is Weakly Pulled Down.
45
55
All Vdds
1.5
2
I_OD
Standby Current
I_std
LVCMOS Rise/Fall Time
V_BW
OE Disable Current
Duty Cycle
Positive slope
All Vdds. Voltage at which maximum deviation is guaranteed.
DC
Tr, Tf
SoftEdge™ Rise/Fall Time Table
ns
LVCMOS option. Default rise/fall time, All Vdds, 10% - 90% Vdd.
ns
SoftEdge™ option. Frequency and supply voltage dependent.
Output Voltage High
VOH
90%
Vdd
Output Voltage Low
VOL
10%
Vdd
Input Voltage High
VIH
70%
Vdd
Pin 1, OE or ST
Input Voltage Low
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
100
250
k
SiTime Corporation
Rev. 1.0
990 Almanor Avenue
Sunnyvale, CA 94085
OH = -7 mA, IOL = 7 mA, (Vdd = 3.3V, 3.0V)
IOH = -4 mA, IOL = 4 mA, (Vdd = 2.8V, 2.5V)
IOH = -2 mA, IOL = 2 mA, (Vdd = 1.8V)
(408) 328-4400
www.sitime.com
Revised November 12, 2015
SiT5000
Electrical Characteristics (continued)
Parameter
Startup Time
OE Enable/Disable Time
Symbol
Min.
Typ.
Max.
Unit
Condition
T_start
10
ms
Measured from the time Vdd reaches its rated minimum value
f = 80 MHz. For other frequencies, T_oe = 100 ns + 3 cycles
T_oe
150
ns
T_resume
6
10
ms
Measured from the time ST pin crosses 50% threshold
RMS Period Jitter
T_jitt
1.7
2
ps
f = 10 MHz, Vdd = 2.5V, 2.8V or 3.3V
1.7
2
ps
f = 10 MHz, Vdd = 1.8V
RMS Phase Jitter (random)
T_phj
0.5
1
ps
f = 10 MHz, Integration bandwidth = 12 kHz to 20 MHz, All Vdds
Resume Time
Note:
1. All electrical specifications in the above table are measured with 15pF output load, Contact SiTime for higher drive options.
Pin Configuration
Pin
Symbol
Functionality
V control
1
Voltage control
Top View
Output
Enable
H or Open[2]: specified frequency output
L: output is high impedance. Only output driver is disabled.
Standby
L: output is low (weak pull down). Device goes to sleep mode. Supply
current reduces to I_std.
VC/OE/ST/NC
NC
VC/OE/ST
1
4
VDD
GND
2
3
OUT
No connect (input receiver off)
2
GND
Power
Electrical and case ground
3
CLK
Output
Oscillator output
4
VDD
Power
Power supply voltage
Note:
2. A pull-up resistor of
