XHP35A-00-0000-0D0BE20E3
    WOLFSPEED
    LEDXLAMPXHP35COOLWHT5000K
XHP35A-00-0000-0D0BE20E3 数据手册
Cree® XLamp® XHP35 LEDs XHP35 High Density LED XHP35 High Intensity LED Product Description FEATURES Table of Contents The XLamp® XHP35 LED brings the • Available in white in high‑density and Characteristics...............................................2 performance of Cree’s Extreme High high‑intensity versions for design Flux Characteristics, High Density Power LEDs to the XP footprint, setting a flexibility EasyWhite® Order Codes and Bins................3 new standard for performance delivered Flux Characteristics, High Density ANSI • XHP35 High Intensity LED is by a 3.45  x  3.45  mm LED. Leveraging the optimized to deliver maximum White Order Codes and Bins.........................5 breakthrough 12‑V monolithic power die candela through secondary optics Flux Characteristics, High Intensity built on Cree’s innovative architecture and • Available in 5-step EasyWhite bins uniquely enabled by the SC5 Technology® at 2700 K to 5700 K CCT and 3-step Flux Characteristics, High Intensity ANSI Platform, the XHP35 LED allows the EasyWhite bins at 2700 K to 3500 K White Order Codes and Bins...................... 11 use of readily available cost‑-optimized CCT Relative Spectral Power Distribution......... 15 drivers to unleash the capabilities of Cree’s high‑power LEDs. Available in both CLD-DS130 Rev 2A Product family data sheet ® • Available in ANSI white bins at 2700 K to 7000 K CCT EasyWhite® Order Codes and Bins................8 Relative Flux vs. Junction Temperature..... 15 Electrical Characteristics............................ 16 high‑density and high‑intensity versions, • Available in standard, 70-, 80-, 85- Relative Flux vs. Current............................. 16 the XHP35 LED is application optimized and 90‑minimum CRI options Relative Chromaticity vs. Current............... 17 to enable new designs and radically lower • Binned at 85 °C Relative Chromaticity vs. Temperature...... 18 system costs. • Maximum drive current: 1050 mA Typical Spatial Distribution......................... 19 • Low thermal resistance: 1.8 °C/W Thermal Design........................................... 20 • Wide viewing angle: 115° for high Performance Groups – Luminous Flux..... 20 intensity, 125° for high density Performance Groups – Chromaticity......... 21 • Unlimited floor life at ≤ 30 ºC/85% RH • Reflow solderable - JEDEC J‑STD‑020C Cree’s EasyWhite® Chromaticity Regions Plotted on the 1931 CIE Curve................... 24 Cree’s Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions... 27 • RoHS and REACh compliant Cree’s Standard Warm and Neutral White • UL recognized component Kits Plotted on ANSI Standard ® (E349212) Chromaticity Regions................................. 28 www.cree.com/Xlamp Bin and Order Code Formats...................... 29 Reflow Soldering Characteristics............... 30 Notes........................................................... 31 Mechanical Dimensions............................. 33 Tape and Reel.............................................. 35 Packaging.................................................... 37 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp ® XHP35 LED Characteristics Characteristics Unit Thermal resistance, junction to solder point °C/W 1.8 Viewing angle (FWHM) - High Density degrees 125 Viewing angle (FWHM) - High Intensity degrees 115 mV/°C -8 Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) Minimum Typical Maximum V 8000 mA 1050 Reverse voltage V -5 Forward voltage (@ 350 mA, 85 °C) V LED junction temperature °C DC forward current 11.3 11.9 150 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® XHP35 LED Flux Characteristics, High Density EasyWhite® Order Codes and Bins (TJ = 85 °C) The following table provides order codes for XLamp XHP35 High Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 29). Min 70 5700 K 80 90 70 5000 K 80 90 70 4500 K Minimum Luminous Flux @350 mA CRI Nominal CCT 80 90 Typ 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* E4 635 706 E2 590 656 D4 550 612 D4 550 612 D2 510 567 C4 475 528 C2 440 489 B4 410 456 XHP35A-00-0000-0D0UB457E E4 635 706 XHP35A-00-0000-0D0BE450E E2 590 656 D4 550 612 D4 550 612 D2 510 567 C4 475 528 C2 440 489 B4 410 456 E2 590 656 D4 550 612 D4 550 612 D2 510 567 C2 440 489 B4 410 456 Group Order Code Group Order Code XHP35A-00-0000-0D0BE457E 57E XHP35A-00-0000-0D0BE257E XHP35A-00-0000-0D0BD457E 57E XHP35A-00-0000-0D0HD457E XHP35A-00-0000-0D0HD257E XHP35A-00-0000-0D0UC457E 57E 50E XHP35A-00-0000-0D0UC257E XHP35A-00-0000-0D0BE250E XHP35A-00-0000-0D0BD450E 50E XHP35A-00-0000-0D0HD450E XHP35A-00-0000-0D0HD250E XHP35A-00-0000-0D0UC450E 50E XHP35A-00-0000-0D0UC250E XHP35A-00-0000-0D0UB450E 45E 45E 45E XHP35A-00-0000-0D0BE245E XHP35A-00-0000-0D0BD445E XHP35A-00-0000-0D0HD445E XHP35A-00-0000-0D0HD245E XHP35A-00-0000-0D0UC245E XHP35A-00-0000-0D0UB445E Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® XHP35 LED Flux Characteristics, High Density EasyWhite® Order Codes and Bins (TJ = 85 °C) - Continued Min 70 4000 K 80 90 70 3500 K 80 90 70 3000 K Minimum Luminous Flux @350 mA CRI Nominal CCT 80 90 80 2700 K 90 Typ Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* E2 590 656 D4 550 612 D2 510 567 D4 550 612 D2 510 567 C2 440 489 B4 410 456 E2 590 656 D4 550 612 D2 510 567 D4 550 612 D2 510 567 C4 475 528 C2 440 489 B4 410 456 D4 550 612 D2 510 567 D2 510 567 C4 475 528 C2 440 489 B4 410 456 B2 380 423 C4 475 528 C2 440 489 B4 410 456 B2 380 423 3-Step Group Order Code 5-Step Group Order Code XHP35A-00-0000-0D0BE240E 40E XHP35A-00-0000-0D0BD440E XHP35A-00-0000-0D0BD240E 40E 40E XHP35A-00-0000-0D0HD440E XHP35A-00-0000-0D0HD240E XHP35A-00-0000-0D0UC240E XHP35A-00-0000-0D0UB440E XHP35A-00-0000-0D0BE235E 35E XHP35A-00-0000-0D0BD435E XHP35A-00-0000-0D0BD235E XHP35A-00-0000-0D0HD435G 35G XHP35A-00-0000-0D0HD235G XHP35A-00-0000-0D0HD435E 35E XHP35A-00-0000-0D0HC435G 35G XHP35A-00-0000-0D0UC235G XHP35A-00-0000-0D0UB435G XHP35A-00-0000-0D0HC435E 35E 30E 30G XHP35A-00-0000-0D0HD230G XHP35A-00-0000-0D0HC430G 30E XHP35A-00-0000-0D0UC230G 30G XHP35A-00-0000-0D0UB430G 27G XHP35A-00-0000-0D0HC427G XHP35A-00-0000-0D0HC227G XHP35A-00-0000-0D0UB427G XHP35A-00-0000-0D0UB227G XHP35A-00-0000-0D0UC235E XHP35A-00-0000-0D0UB435E XHP35A-00-0000-0D0BD430E XHP35A-00-0000-0D0BD230E XHP35A-00-0000-0D0HD230E XHP35A-00-0000-0D0HC430E XHP35A-00-0000-0D0UC230E 30E XHP35A-00-0000-0D0UB230G 27G XHP35A-00-0000-0D0HD235E XHP35A-00-0000-0D0UB430E XHP35A-00-0000-0D0UB230E 27E 27E XHP35A-00-0000-0D0HC427E XHP35A-00-0000-0D0HC227E XHP35A-00-0000-0D0UB427E XHP35A-00-0000-0D0UB227E Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® XHP35 LED Flux Characteristics, High Density ANSI White Order Codes and Bins (TJ = 85 °C) The following table provides order codes for XLamp XHP35 High Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 29). Nomimal CCT 7000 K Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Min Typ 0 68 70 80 90 0 68 70 6500 K 1A, 1B, 1C, 1D 80 90 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 70 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code E4 635 706 XHP35A-00-0000-0D00E40DT E2 590 656 XHP35A-00-0000-0D00E20DT D4 550 612 XHP35A-00-0000-0D00D40DT E4 635 706 XHP35A-00-0000-0D0BE40DT E2 590 656 XHP35A-00-0000-0D0BE20DT D4 550 612 XHP35A-00-0000-0D0BD40DT D4 550 612 XHP35A-00-0000-0D0HD40DT D2 510 567 XHP35A-00-0000-0D0HD20DT C4 475 528 XHP35A-00-0000-0D0UC40DT C2 440 489 XHP35A-00-0000-0D0UC20DT B4 410 456 XHP35A-00-0000-0D0UB40DT E4 635 706 XHP35A-00-0000-0D00E40E1 E2 590 656 XHP35A-00-0000-0D00E20E1 D4 550 612 XHP35A-00-0000-0D00D40E1 E4 635 706 XHP35A-00-0000-0D0BE40E1 E2 590 656 XHP35A-00-0000-0D0BE20E1 D4 550 612 XHP35A-00-0000-0D0BD40E1 D4 550 612 XHP35A-00-0000-0D0HD40E1 D2 510 567 XHP35A-00-0000-0D0HD20E1 C4 475 528 XHP35A-00-0000-0D0UC40E1 C2 440 489 XHP35A-00-0000-0D0UC20E1 B4 410 456 XHP35A-00-0000-0D0UB40E1 E4 635 706 XHP35A-00-0000-0D00E40DV E2 590 656 XHP35A-00-0000-0D00E20DV D4 550 612 XHP35A-00-0000-0D00D40DV E4 635 706 XHP35A-00-0000-0D0BE40DV E2 590 656 XHP35A-00-0000-0D0BE20DV D4 550 612 XHP35A-00-0000-0D0BD40DV D4 550 612 XHP35A-00-0000-0D0HD40DV D2 510 567 XHP35A-00-0000-0D0HD20DV C4 475 528 XHP35A-00-0000-0D0UC40DV C2 440 489 XHP35A-00-0000-0D0UC20DV B4 410 456 XHP35A-00-0000-0D0UB40DV Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® XHP35 LED Flux Characteristics, High Density ANSI Order Codes and Bins (TJ = 85 °C) - Continued Nomimal CCT Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions Min Typ 0 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 70 4500 K 4A, 4B, 4C, 4D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code E4 635 706 E2 590 656 XHP35A-00-0000-0D00E40E2 XHP35A-00-0000-0D00E20E2 D4 550 612 XHP35A-00-0000-0D00D40E2 E4 635 706 XHP35A-00-0000-0D0BE40E2 E2 590 656 XHP35A-00-0000-0D0BE20E2 D4 550 612 XHP35A-00-0000-0D0BD40E2 D4 550 612 XHP35A-00-0000-0D0HD40E2 D2 510 567 XHP35A-00-0000-0D0HD20E2 C4 475 528 XHP35A-00-0000-0D0UC40E2 C2 440 489 XHP35A-00-0000-0D0UC20E2 B4 410 456 XHP35A-00-0000-0D0UB40E2 E4 635 706 XHP35A-00-0000-0D00E40E3 E2 590 656 XHP35A-00-0000-0D00E20E3 D4 550 612 XHP35A-00-0000-0D00D40E3 E4 635 706 XHP35A-00-0000-0D0BE40E3 E2 590 656 XHP35A-00-0000-0D0BE20E3 D4 550 612 XHP35A-00-0000-0D0BD40E3 D4 550 612 XHP35A-00-0000-0D0HD40E3 D2 510 567 XHP35A-00-0000-0D0HD20E3 C4 475 528 XHP35A-00-0000-0D0UC40E3 C2 440 489 XHP35A-00-0000-0D0UC20E3 B4 410 456 XHP35A-00-0000-0D0UB40E3 E2 590 656 XHP35A-00-0000-0D00E20E4 D4 550 612 XHP35A-00-0000-0D00D40E4 E2 590 656 XHP35A-00-0000-0D0BE20E4 D4 550 612 XHP35A-00-0000-0D0BD40E4 D4 550 612 XHP35A-00-0000-0D0HD40E4 D2 510 567 XHP35A-00-0000-0D0HD20E4 C4 475 528 XHP35A-00-0000-0D0UC40E4 C2 440 489 XHP35A-00-0000-0D0UC20E4 B4 410 456 XHP35A-00-0000-0D0UB40E4 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® XHP35 LED Flux Characteristics, High Density ANSI Order Codes and Bins (TJ = 85 °C) - Continued Nomimal CCT 4000 K Chromaticity Regions 5A, 5B, 5C, 5D Group E2 590 656 XHP35A-00-0000-0D00E20E5 0 68 D4 550 612 XHP35A-00-0000-0D00D40E5 D2 510 567 XHP35A-00-0000-0D00D20E5 70 70 80 90 70 3000 K 7A, 7B, 7C, 7D 80 90 80 2700 K Order Code Typ 90 6A, 6B, 6C, 6D Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Min 80 3500 K Minimum Luminous Flux @ 350 mA CRI 8A, 8B, 8C, 8D 90 E2 590 656 XHP35A-00-0000-0D0BE20E5 D4 550 612 XHP35A-00-0000-0D0BD40E5 D2 510 567 XHP35A-00-0000-0D0BD20E5 D4 550 612 XHP35A-00-0000-0D0HD40E5 D2 510 567 XHP35A-00-0000-0D0HD20E5 C2 440 489 XHP35A-00-0000-0D0UC20E5 B4 410 456 XHP35A-00-0000-0D0UB40E5 E2 590 656 XHP35A-00-0000-0D0BE20E6 D4 550 612 XHP35A-00-0000-0D0BD40E6 D2 510 567 XHP35A-00-0000-0D0BD20E6 D4 550 612 XHP35A-00-0000-0D0HD40E6 D2 510 567 XHP35A-00-0000-0D0HD20E6 C4 475 528 XHP35A-00-0000-0D0HC40E6 XHP35A-00-0000-0D0UC20E6 C2 440 489 B4 410 456 XHP35A-00-0000-0D0UB40E6 D4 550 612 XHP35A-00-0000-0D0BD40E7 D2 510 567 XHP35A-00-0000-0D0BD20E7 D2 510 567 XHP35A-00-0000-0D0HD20E7 C4 475 528 XHP35A-00-0000-0D0HC40E7 C2 440 489 XHP35A-00-0000-0D0UC20E7 B4 410 456 XHP35A-00-0000-0D0UB40E7 B2 380 423 XHP35A-00-0000-0D0UB20E7 C4 475 528 XHP35A-00-0000-0D0HC40E8 C2 440 489 XHP35A-00-0000-0D0HC20E8 B4 410 456 XHP35A-00-0000-0D0UB40E8 B2 380 423 XHP35A-00-0000-0D0UB20E8 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® XHP35 LED Flux Characteristics, High Intensity EasyWhite® Order Codes and Bins (TJ = 85 °C) The following table provides order codes for XLamp XHP35 High Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 29). Min 70 5700 K 80 90 70 5000 K Minimum Luminous Flux @350 mA CRI Nominal CCT 80 90 Typ 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* D4 550 612 D2 510 567 C4 475 528 XHP35A-H0-0000-0D0BC457E D2 510 567 XHP35A-H0-0000-0D0HD257E C4 475 528 C2 440 489 XHP35A-H0-0000-0D0HC257E C2 440 489 XHP35A-H0-0000-0D0UC257E B4 410 456 B2 380 423 A4 355 395 XHP35A-H0-0000-0D0UA457E D4 550 612 XHP35A-H0-0000-0D0BD450E D2 510 567 C4 475 528 XHP35A-H0-0000-0D0BC450E D2 510 567 XHP35A-H0-0000-0D0HD250E C4 475 528 C2 440 489 XHP35A-H0-0000-0D0HC250E C2 440 489 XHP35A-H0-0000-0D0UC250E B4 410 456 B2 380 423 A4 355 395 Group Order Code Group Order Code XHP35A-H0-0000-0D0BD457E 57E 57E 57E 50E 50E 50E XHP35A-H0-0000-0D0BD257E XHP35A-H0-0000-0D0HC457E XHP35A-H0-0000-0D0UB457E XHP35A-H0-0000-0D0UB257E XHP35A-H0-0000-0D0BD250E XHP35A-H0-0000-0D0HC450E XHP35A-H0-0000-0D0UB450E XHP35A-H0-0000-0D0UB250E XHP35A-H0-0000-0D0UA450E Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® XHP35 LED Flux Characteristics, High Intensity EasyWhite® Order Codes and Bins (TJ = 85 °C) - Continued Min 70 4500 K 80 90 70 4000 K 80 90 70 3500 K Minimum Luminous Flux @350 mA CRI Nominal CCT 80 90 Typ 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* D4 550 612 D2 510 567 C4 475 528 XHP35A-H0-0000-0D0BC445E D2 510 567 XHP35A-H0-0000-0D0HD245E C4 475 528 C2 440 489 XHP35A-H0-0000-0D0HC245E B4 410 456 XHP35A-H0-0000-0D0UB445E B2 380 423 Group Order Code Group Order Code XHP35A-H0-0000-0D0BD445E 45E 45E 45E XHP35A-H0-0000-0D0BD245E XHP35A-H0-0000-0D0HC445E XHP35A-H0-0000-0D0UB245E A4 355 395 XHP35A-H0-0000-0D0UA445E D4 550 612 XHP35A-H0-0000-0D0BD440E D2 510 567 C4 475 528 C2 440 489 C4 475 528 C2 440 489 B4 410 456 B2 380 423 A4 355 395 XHP35A-H0-0000-0D0UA440E D2 510 567 XHP35A-H0-0000-0D0BD235E C4 475 528 C2 440 489 C4 475 528 C2 440 489 B4 410 456 B2 380 423 A4 355 395 40E XHP35A-H0-0000-0D0BD240E XHP35A-H0-0000-0D0BC440E XHP35A-H0-0000-0D0BC240E 40E XHP35A-H0-0000-0D0HC440E XHP35A-H0-0000-0D0HC240E XHP35A-H0-0000-0D0UB440E 40E 35E XHP35A-H0-0000-0D0UB240E XHP35A-H0-0000-0D0BC435E XHP35A-H0-0000-0D0BC235E XHP35A-H0-0000-0D0HC435G 35G XHP35A-H0-0000-0D0HC235G XHP35A-H0-0000-0D0HC435E 35E XHP35A-H0-0000-0D0HB435G 35G XHP35A-H0-0000-0D0UB235G XHP35A-H0-0000-0D0UA435G XHP35A-H0-0000-0D0HC235E XHP35A-H0-0000-0D0HB435E 35E XHP35A-H0-0000-0D0UB235E XHP35A-H0-0000-0D0UA435E Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLamp ® XHP35 LED Flux Characteristics, High Intensity EasyWhite® Order Codes and Bins (TJ = 85 °C) - Continued Min 70 3000 K Minimum Luminous Flux @350 mA CRI Nominal CCT 80 90 80 2700 K 90 Typ 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* D2 510 567 C4 475 528 C2 440 489 C2 440 489 B4 410 456 B2 380 423 A4 355 395 A2 330 367 XHP35A-H0-0000-0D0UA230G XHP35A-H0-0000-0D0UA230E C2 440 489 XHP35A-H0-0000-0D0HC227G XHP35A-H0-0000-0D0HC227E B4 410 456 B2 380 423 A4 355 395 A2 330 367 Group Order Code Group Order Code XHP35A-H0-0000-0D0BD230E 30E XHP35A-H0-0000-0D0BC430E XHP35A-H0-0000-0D0BC230E 30G XHP35A-H0-0000-0D0HC230G XHP35A-H0-0000-0D0HB430G 30E XHP35A-H0-0000-0D0UB230G 30G 27G XHP35A-H0-0000-0D0UA430G XHP35A-H0-0000-0D0HB427G XHP35A-H0-0000-0D0UA427G XHP35A-H0-0000-0D0UA227G XHP35A-H0-0000-0D0HB430E XHP35A-H0-0000-0D0UB230E 30E 27E XHP35A-H0-0000-0D0HB227G 27G XHP35A-H0-0000-0D0HC230E XHP35A-H0-0000-0D0UA430E XHP35A-H0-0000-0D0HB427E XHP35A-H0-0000-0D0HB227E 27E XHP35A-H0-0000-0D0UA427E XHP35A-H0-0000-0D0UA227E Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® XHP35 LED Flux Characteristics, High Intensity ANSI White Order Codes and Bins (TJ = 85 °C) The following table provides order codes for XLamp XHP35 High Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 29). Nomimal CCT 7000 K Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Min Typ 0 68 70 80 90 0 70 6500 K 1A, 1B, 1C, 1D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code D4 550 612 XHP35A-H0-0000-0D00D40DT D2 510 567 XHP35A-H0-0000-0D00D20DT C4 475 528 XHP35A-H0-0000-0D00C40DT D4 550 612 XHP35A-H0-0000-0D0BD40DT D2 510 567 XHP35A-H0-0000-0D0BD20DT C4 475 528 XHP35A-H0-0000-0D0BC40DT D2 510 567 XHP35A-H0-0000-0D0HD20DT C4 475 528 XHP35A-H0-0000-0D0HC40DT C2 440 489 XHP35A-H0-0000-0D0HC20DT B4 410 456 XHP35A-H0-0000-0D0UB40DT B2 380 423 XHP35A-H0-0000-0D0UB20DT A4 355 395 XHP35A-H0-0000-0D0UA40DT D4 550 612 XHP35A-H0-0000-0D00D40E1 D2 510 567 XHP35A-H0-0000-0D00D20E1 C4 475 528 XHP35A-H0-0000-0D00C40E1 D4 550 612 XHP35A-H0-0000-0D0BD40E1 D2 510 567 XHP35A-H0-0000-0D0BD20E1 C4 475 528 XHP35A-H0-0000-0D0BC40E1 D2 510 567 XHP35A-H0-0000-0D0HD20E1 C4 475 528 XHP35A-H0-0000-0D0HC40E1 C2 440 489 XHP35A-H0-0000-0D0HC20E1 B4 410 456 XHP35A-H0-0000-0D0UB40E1 B2 380 423 XHP35A-H0-0000-0D0UB20E1 A4 355 395 XHP35A-H0-0000-0D0UA40E1 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® XHP35 LED Flux Characteristics, High Intensity ANSI Order Codes and Bins (TJ = 85 °C) - Continued Nomimal CCT Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions Min Typ 0 68 70 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 80 90 0 70 5700 K 2A, 2B, 2C, 2D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code D4 550 612 XHP35A-H0-0000-0D00D40DV D2 510 567 XHP35A-H0-0000-0D00D20DV C4 475 528 XHP35A-H0-0000-0D00C40DV D4 550 612 XHP35A-H0-0000-0D0BD40DV D2 510 567 XHP35A-H0-0000-0D0BD20DV C4 475 528 XHP35A-H0-0000-0D0BC40DV D2 510 567 XHP35A-H0-0000-0D0HD20DV C4 475 528 XHP35A-H0-0000-0D0HC40DV C2 440 489 XHP35A-H0-0000-0D0HC20DV C2 440 489 XHP35A-H0-0000-0D0UC20DV B4 410 456 XHP35A-H0-0000-0D0UB40DV B2 380 423 XHP35A-H0-0000-0D0UB20DV A4 355 395 XHP35A-H0-0000-0D0UA40DV D4 550 612 XHP35A-H0-0000-0D00D40E2 D2 510 567 XHP35A-H0-0000-0D00D20E2 C4 475 528 XHP35A-H0-0000-0D00C40E2 D4 550 612 XHP35A-H0-0000-0D0BD40E2 D2 510 567 XHP35A-H0-0000-0D0BD20E2 C4 475 528 XHP35A-H0-0000-0D0BC40E2 D2 510 567 XHP35A-H0-0000-0D0HD20E2 C4 475 528 XHP35A-H0-0000-0D0HC40E2 C2 440 489 XHP35A-H0-0000-0D0HC20E2 C2 440 489 XHP35A-H0-0000-0D0UC20E2 B4 410 456 XHP35A-H0-0000-0D0UB40E2 B2 380 423 XHP35A-H0-0000-0D0UB20E2 A4 355 395 XHP35A-H0-0000-0D0UA40E2 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLamp ® XHP35 LED Flux Characteristics, High Intensity ANSI Order Codes and Bins (TJ = 85 °C) - Continued Nomimal CCT Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions Min Typ 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 70 4500 K 4A, 4B, 4C, 4D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code D4 550 612 XHP35A-H0-0000-0D00D40E3 D2 510 567 XHP35A-H0-0000-0D00D20E3 C4 475 528 XHP35A-H0-0000-0D00C40E3 D4 550 612 XHP35A-H0-0000-0D0BD40E3 D2 510 567 XHP35A-H0-0000-0D0BD20E3 C4 475 528 XHP35A-H0-0000-0D0BC40E3 D2 510 567 XHP35A-H0-0000-0D0HD20E3 C4 475 528 XHP35A-H0-0000-0D0HC40E3 C2 440 489 XHP35A-H0-0000-0D0HC20E3 C2 440 489 XHP35A-H0-0000-0D0UC20E3 B4 410 456 XHP35A-H0-0000-0D0UB40E3 B2 380 423 XHP35A-H0-0000-0D0UB20E3 A4 355 395 XHP35A-H0-0000-0D0UA40E3 D4 550 612 XHP35A-H0-0000-0D00D40E4 D2 510 567 XHP35A-H0-0000-0D00D20E4 C4 475 528 XHP35A-H0-0000-0D00C40E4 D4 550 612 XHP35A-H0-0000-0D0BD40E4 D2 510 567 XHP35A-H0-0000-0D0BD20E4 C4 475 528 XHP35A-H0-0000-0D0BC40E4 D2 510 567 XHP35A-H0-0000-0D0HD20E4 C4 475 528 XHP35A-H0-0000-0D0HC40E4 C2 440 489 XHP35A-H0-0000-0D0HC20E4 B4 410 456 XHP35A-H0-0000-0D0UB40E4 B2 380 423 XHP35A-H0-0000-0D0UB20E4 A4 355 395 XHP35A-H0-0000-0D0UA40E4 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® XHP35 LED Flux Characteristics, High Intensity ANSI Order Codes and Bins (TJ = 85 °C) - Continued Nomimal CCT Chromaticity Regions Min 0 4000 K 5A, 5B, 5C, 5D 70 80 90 70 3500 K 6A, 6B, 6C, 6D 80 90 70 3000 K 7A, 7B, 7C, 7D 80 90 80 2700 K Minimum Luminous Flux @ 350 mA CRI 8A, 8B, 8C, 8D 90 Typ 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code D4 550 612 XHP35A-H0-0000-0D00D40E5 D2 510 567 XHP35A-H0-0000-0D00D20E5 C4 475 528 XHP35A-H0-0000-0D00C40E5 C2 440 489 XHP35A-H0-0000-0D00C20E5 D4 550 612 XHP35A-H0-0000-0D0BD40E5 D2 510 567 XHP35A-H0-0000-0D0BD20E5 C4 475 528 XHP35A-H0-0000-0D0BC40E5 C2 440 489 XHP35A-H0-0000-0D0BC20E5 C4 475 528 XHP35A-H0-0000-0D0HC40E5 C2 440 489 XHP35A-H0-0000-0D0HC20E5 B4 410 456 XHP35A-H0-0000-0D0UB40E5 B2 380 423 XHP35A-H0-0000-0D0UB20E5 A4 355 395 XHP35A-H0-0000-0D0UA40E5 D2 510 567 XHP35A-H0-0000-0D0BD20E6 C4 475 528 XHP35A-H0-0000-0D0BC40E6 C2 440 489 XHP35A-H0-0000-0D0BC20E6 C4 475 528 XHP35A-H0-0000-0D0HC40E6 C2 440 489 XHP35A-H0-0000-0D0HC20E6 B4 410 456 XHP35A-H0-0000-0D0HB40E6 B2 380 423 XHP35A-H0-0000-0D0UB20E6 A4 355 395 XHP35A-H0-0000-0D0UA40E6 D2 510 567 XHP35A-H0-0000-0D0BD20E7 C4 475 528 XHP35A-H0-0000-0D0BC40E7 C2 440 489 XHP35A-H0-0000-0D0BC20E7 C2 420 489 XHP35A-H0-0000-0D0HC20E7 B4 410 456 XHP35A-H0-0000-0D0HB40E7 B2 380 423 XHP35A-H0-0000-0D0UB20E7 A4 355 395 XHP35A-H0-0000-0D0UA40E7 A2 330 367 XHP35A-H0-0000-0D0UA20E7 C2 420 489 XHP35A-H0-0000-0D0HC20E8 B4 410 456 XHP35A-H0-0000-0D0HB40E8 B2 380 423 XHP35A-H0-0000-0D0HB20E8 A4 355 395 XHP35A-H0-0000-0D0UA40E8 A2 330 367 XHP35A-H0-0000-0D0UA20E8 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 31). • Cree XLamp XHP35 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and are for reference only. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® XHP35 LED Relative Spectral Power Relative Spectral Power Distribution Relative Radiant Power 100% 80% 60% 6000 K, 70 CRI 5000 K, 70 CRI 40% 3000 K, 80 CRI 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature Relative Flux vs. Junction Temperature (IF = 350 mA) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLamp ® XHP35 LED Electrical Characteristics (Tj = 85°C) Electrical Characteristics (TJ = 85 °C) 1050 Forward Current (mA) 875 700 525 350 175 10.5 11.0 11.5 12.0 12.5 Forward Voltage (V) Relative Intensity vs. Current (Tj = 85°C) Relative Flux vs. Current (TJ = 85 °C) 240% Relative Luminous Flux 200% 160% 120% 80% 40% 0% 0 175 350 525 700 875 1050 Forward Current (mA) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 XLamp ® XHP35 LED Relative Chromaticity Current, WW - High Density Relative Chromaticity vs. Vs. Current (Warm White) 0.020 0.016 High Density 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 175 350 525 700 875 1050 Current (mA) Relative Chromaticity Vs. Current, WW - High Intensity 0.020 0.016 High Intensity 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 175 350 525 700 875 1050 Current (mA) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 XLamp ® XHP35 LED Relative Chromaticity vs. Temperature (Warm White) Relative Chromaticity Vs. Temperature WW - High Density 0.020 0.016 High Density 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Relative Chromaticity Vs. Temperature WW - High Intensity Tsp (°C) 0.020 0.016 High Intensity 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tsp (°C) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLamp ® XHP35 LED Typical Spatial Distribution 100% Relative Luminous Intensity 80% 60% High Density 40% 20% 0% Typical Spatial Radiation Pattern -90 -70 -50 -30 -10 10 30 50 70 90 Angle (º) 100% Relative Luminous Intensity 80% 60% High Intensity 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 19 XLamp ® XHP35 LED Thermal Design The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life Thermal and optical characteristics. Design - High Intensity 1200 Maximum Current (mA) 1000 800 600 400 Rj-a = 2°C/W Rj-a = 4°C/W 200 0 Rj-a = 6°C/W Rj-a = 8°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) XHP35 High Intensity Performance Groups – Luminous Flux (TJ = 85 °C) XLamp XHP35 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups. Group Code Minimum Luminous Flux Maximum Luminous Flux A2 330 355 A4 355 380 B2 380 410 B4 410 440 C2 440 475 C4 475 510 D2 510 550 D4 550 590 E2 590 635 E4 635 680 F2 680 730 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 20 XLamp ® XHP35 LED Performance Groups – Chromaticity XLamp XHP35 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 3-Step Ellipse Center Point Major Axis Minor Axis x y a b Rotation Angle (°) 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 Rotation Angle (°) Bin Code CCT 35G EasyWhite Color Temperatures – 5-Step Ellipse Bin Code Center Point CCT x Major Axis Minor Axis y a b 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 45E 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 27E 2700 K 0.4577 0.4099 0.01350 0.00700 48.5 ANSI White Bins CCT Bin Code 0A0 0B0 7000 K 0C0 0D0 ANSI White Bins x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 0.3042 0.2920 0.3060 0.2895 0.3135 0.2962 0.3220 0.2984 0.3133 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 CCT Bin Code 0R0 0S0 7000 K 0T0 x y 0.2980 0.2880 0.2950 0.2970 0.3009 0.3042 0.3037 0.2937 0.2895 0.3135 0.2870 0.3210 0.2937 0.3312 0.2962 0.3220 0.2962 0.3220 0.2937 0.3312 0.3005 0.3415 0.3048 0.3207 0.3028 0.3304 0.2984 0.3133 0.3037 0.2937 0.3048 0.3207 0.3009 0.3042 0.3068 0.3113 0.3068 0.3113 0.3009 0.3042 0.3093 0.2993 0U0 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 21 XLamp ® XHP35 LED Performance Groups – Chromaticity (Continued) ANSI White Bins CCT Bin Code 1A0 1B0 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 CCT 1R0 1S0 6500 K 1T0 Bin Code 2A0 2B0 5700 K 2C0 2D0 x y 0.3068 0.3113 0.3144 0.3186 0.3161 0.3059 0.3093 0.2993 0.3005 0.3415 0.3099 0.3509 0.3115 0.3391 0.3028 0.3304 0.3099 0.3509 0.3196 0.3602 0.3205 0.3481 0.3130 0.3290 0.3115 0.3391 0.3130 0.3290 0.3144 0.3186 0.3213 0.3373 0.3221 0.3261 0.3221 0.3261 0.3231 0.3120 0.3144 0.3186 0.3161 0.3059 1U0 ANSI White Bins CCT Bin Code ANSI White Bins x y 0.3215 0.3290 0.3290 0.3300 CCT Bin Code x y 0.3350 0.3222 0.3243 0.3417 0.3290 0.3300 0.3290 0.3180 2R0 0.3222 0.3243 0.3231 0.3120 0.3207 0.3462 0.3196 0.3602 0.3290 0.3538 0.3290 0.3690 0.3290 0.3417 0.3290 0.3538 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 2S0 0.3207 0.3462 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3417 0.3290 0.3538 0.3290 0.3417 0.3290 0.3300 0.3371 0.3490 0.3366 0.3369 0.3366 0.3369 0.3361 0.3245 0.3290 0.3300 0.3290 0.3180 5700 K 2T0 2U0 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 22 XLamp ® XHP35 LED Performance Groups – Chromaticity (Continued) ANSI White Bins CCT Bin Code 3A0 3B0 5000 K 3C0 3D0 ANSI White Bins x y 0.3371 0.3490 CCT 0.3451 0.3554 0.3440 0.3427 0.3366 0.3369 0.3515 0.3487 0.3376 0.3616 0.3548 0.3736 0.3463 0.3687 0.3641 0.3804 0.3451 0.3554 0.3530 0.3597 0.3371 0.3490 0.3533 0.3620 0.3463 0.3687 0.3641 0.3804 0.3551 0.3760 0.3736 0.3874 0.3533 0.3620 0.3702 0.3722 4A0 4B0 4500 K 4C0 Bin Code 5A0 5B0 4000 K 5C0 5D0 x y 0.3530 0.3597 0.3615 0.3659 0.3512 0.3465 0.3451 0.3554 0.3615 0.3659 0.3451 0.3554 0.3615 0.3659 0.3533 0.3620 0.3702 0.3722 0.3515 0.3487 0.3670 0.3578 0.3440 0.3427 0.3590 0.3521 4D0 ANSI White Bins CCT Bin Code ANSI White Bins x y 0.3670 0.3702 0.3825 0.3798 CCT Bin Code x y 0.3578 0.3889 0.3690 0.3722 0.3941 0.3848 0.4080 0.3916 6A0 0.3783 .3646 0.4017 0.3751 0.3702 0.3722 0.3941 0.3848 0.3736 0.3874 0.3996 0.4015 0.3869 0.3958 .04146 0.4089 0.3825 0.3798 .04080 0.3916 0.3825 0.3798 0.4080 0.3916 0.3869 0.3958 0.4146 0.4089 .04006 0.4044 0.4299 0.4165 0.3950 0.3875 0.4221 0.3984 0.3783 0.3646 0.4017 0.3751 0.3825 0.3798 0.4080 0.3916 0.3950 0.3875 0.4221 0.3984 0.3898 0.3716 0.4147 0.3814 6B0 3500 K 6C0 6D0 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 23 XLamp ® XHP35 LED Performance Groups – Chromaticity (Continued) ANSI White Bins CCT Bin Code 7A0 7B0 3000 K 7C0 7D0 ANSI White Bins x y 0.4147 0.3814 CCT Bin Code 0.4221 0.3984 0.4342 0.4028 0.4259 0.3853 0.4483 0.3919 0.4221 0.3984 0.4465 .04071 0.4299 0.4165 0.4562 0.4260 0.4430 0.4212 0.4687 0.4289 0.4342 .04028 .04582 0.4099 0.4342 0.4028 0.4582 0.4099 0.4430 0.4212 0.4687 0.4289 0.4562 0.4260 0.4813 0.4319 8A0 8B0 2700 K 8C0 x y 0.4373 0.3893 0.4465 0.4071 0.4582 0.4099 0.4465 0.4071 0.4700 0.4126 0.4259 0.3853 0.4483 0.3919 0.4342 0.4028 0.4582 0.4099 0.4465 0.4071 0.4700 0.4126 0.4373 0.3893 0.4593 0.3944 8D0 Cree’s EasyWhite® Chromaticity Regions Plotted on the 1931 CIE Curve ANSI Cool White 0.40 5000 K 0.39 5700 K 0.38 0.37 6500 K 2T 0.36 2S CCy 8000 K 2B 1S 0.34 0T 0.33 0S 0.32 2C 1T 0.35 0B 0.31 1D 2U 2R 1A 0D 0A 0.30 2A 1B 0C 2D 1C ANSI C78.377A 1U 1R 0U 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 24 XLamp ® XHP35 LED Cree’s EasyWhite® Chromaticity Regions Plotted on the 1931 CIE Curve - Continued ANSI Neutral White and ANSI Warm White 0.45 0.44 2700 K 3000 K 0.43 0.42 3500 K 4000 K CCy 0.40 6C 4500 K 6B 5C 0.39 0.37 5700 K 0.36 3C 3B 3D 0.35 4C 4B 7D 7A 8A 8C 8D 6D 5B 5000 K 0.38 7C 7B 0.41 8B 5D 6A 5A 4D 4A 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 25 XLamp ® XHP35 LED Cree’s EasyWhite® Chromaticity Regions Plotted on the 1931 CIE Curve - Continued 0.44 ANSI C78.377 Quadrangle 0.43 2700 K 3000 K EasyWhite 5-Step 0.42 3500 K EasyWhite 3-Step 0.41 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 26 XLamp ® XHP35 LED Cree’s Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 5700 K DV 0.37 0.37 6500 K 6500 K 2T 0.36 0.36 2S DT 0.34 1D ANSI C78.377A 1U 0D 0A 0.31 1R 0C 0B 1D 0A ANSI C78.377A 1R 0U 0.36 0.35 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.34 0R 0.29 CCx CCx 0.40 0.40 5000 K 0.39 0.38 0.38 3S 6500 K 0.35 1T 0T 0.33 0S 0.32 0C 0.31 3R 2A 1D 0T 0S 1R 0C 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 3A 2B 1S 0.31 1U 1R 0U 0.30 0U 0.30 8000 K 0.34 0.32 ANSI C78.377A 2R 1U 2C 1T 0.33 2U 1A 0D 0A 2D 1C 1B 0B 3A 2B 1S 3B 2S 0.35 2C 3S 2T 0.36 3B 2S 8000 K 0.34 6500 K 2T E1 5700 K E2 0.37 CCy 0.36 5000 K 0.39 5700 K 0.37 0R 0R 0.29 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 CCx 0.29 0.28 0.28 0.28 CCy 2U 2R 1U 0D 0R 0.29 2A 1A 0.30 0.29 0.28 2D 1C 1B 0S 0.32 0U 0.30 1S 0T 0.33 2U 2R 1A 0.34 2B 0.33 0.31 2A 1B 0C 0B 2D 1C 2C 1T 8000 K 0.32 0S 0.32 0.35 2B 1S 0T 0.33 2C 1T 2T 2S 0.31 8000 K CCy 0.35 CCy 5000 K 0.39 CCx Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 27 XLamp ® XHP35 LED Cree’s Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions 0.45 0.44 E7 0.42 3500 K 4000 K 0.40 0.39 5000 K 0.38 4500 K E4 4B 3C 0.36 3B 3D 0.35 2700 K 8C 7B 6C 6B 8A 7D 7A 5C 8D 6D 5B 4C E3 0.37 E5 8B 7C E6 0.41 CCy E8 3000 K 0.43 6A ANSI C78.377A 5D 5A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 28 XLamp ® XHP35 LED Bin and Order Code Formats Bin codes and order codes for XHP35 LEDs are configured in the following manner: Order Code SSSSSS-BD-GGGG-HJKLMMNNN Bin Code Series XHP35A = XHP35 Series XHP35A = XHP35 Internal code Chromaticity group Minimum luminous flux group Luminous flux group Chromaticity group Voltage performance group CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum Vf class Configuration B: Version 0 = High density H = High intensity D: Reel size SSSSSS-B-NNN-MMM-JK-L-PP Internal code Vf class Version 0 = High density H = High intensity Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 29 XLamp ® XHP35 LED Reflow Soldering Characteristics In testing, Cree has found XLamp XHP35 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tS Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) IPC/JEDEC J-STD-020C Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 30 XLamp ® XHP35 LED Notes Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XHP35 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of the Cree website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 31 XLamp ® XHP35 LED Notes - Continued UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 32 XLamp ® XHP35 LED Mechanical Dimensions 6 5 6 5 Thermal vias, if present, are not shown on these drawings. 4 NOTICE NOTICE ENTIAL. THIS PLOT AND THE INFORMATION CONFIDENTIAL. THIS PLOT AND THE INFORMATION WITHIN ARE THEARE PROPRIETARY AND AINED WITHIN THE PROPRIETARY AND AL INFORMATION OF CREE, INC. THIS PLOT IDENTIAL INFORMATION OF CREE, INC. THIS PLOT COPIED, REPRODUCED OR DISCLOSED TO ANY TO ANY NOT BE COPIED, REPRODUCED OR DISCLOSED ED PERSON THE WITHOUT WRITTEN CONSENT UTHORIZED PERSON THEWITHOUT WRITTEN CONSENT REE INC. 3 4 2 3 2 REVISON REVotherwise REV indicated. DESCRIPTION DESCR All dimensions are ±.13 mm unless XHP35 High Density XHP35A-0x-xxxx-xxxxxxxxx XHP35 High Density 3.30 3.45 2.80 3.45 2.80 2.30 .58 .50 3.30 3.45 4 3 1.30 3 Side View 1.30 BottomREV View 2 REV 3.30 2 REVISO DESCRIPTION DESC XHP35A-Hx-xxxx-xxxxxxxxx .50 XHP35 High Intensity .50 .64 .50 .64 3.30 3.30 2.30 3.45 3.45 3.30 3.30 .25 3.30 .75 3.451.30 3.451.30 3.30 6 .50 2.30 Anode OPTICAL REFERENCE R1.85 OPTICAL REFERENCE R1.85 6 6 5 5 4 NOTICENOTICE DENTIAL. CONFIDENTIAL. THIS PLOT THIS AND PLOT THE AND INFORMATION THE INFORMATION Top View TAINED WITHIN WITHIN ARE THE ARE PROPRIETARY THE PROPRIETARY AND AND FIDENTIAL AL INFORMATION INFORMATION OF CREE, OFINC. CREE, THIS INC. PLOT THIS PLOT NOT COPIED, BE COPIED, REPRODUCED REPRODUCED OR DISCLOSED OR DISCLOSED TO ANYTO ANY .50 .50 UTHORIZED ZED PERSON THE PERSON WITHOUT WRITTEN THEIntensity WITHOUT WRITTEN CONSENT CONSENT XHP35 High REE INC. .50 .50 .58 OPTICAL OPTICAL REFERENCE REFERENCE 3.45 3.30 .50 3.30 OPTICAL OPTICAL REFERENCE REFERENCE 1.01 1.01 2.30 2.30 3.30 3.30 .25 .50 .50 2.30 .50 .50 .75Anode 3.30 3.30 ALL DIMENSIONS ARE ± .13mm NO ALL DIMENSIONS ARE UNLESS ± .13mmOTHERWISE UNLESS OTHE DATE BY DRAWN BY DATE DRAWN UNLESS OTHERWISE SPECIFIED UNLESS OTHERWISE SPECIFIED D. CRONIN 5/11/15 D. CRONIN5/11/15 DIMENSIONS ARE IN DIMENSIONS ARE IN CHECK DATE CHECK DATE MILLIMETERS AND AFTER FINISH. MILLIMETERS AND AFTER FINISH. RECOMMENDED STENCIL PATTERN RECOMMENDED STENCIL PATTERN TOLERANCE UNLESS SPECIFIED: TOLERANCE UNLESS SPECIFIED: .XX ± .25 (HATCHED(HATCHED AREA IS OPEN) DATE APPROVED .XX ± .25 AREA IS OPEN) DATE APPROVED RECOMMENDED PCB SOLDER TITLE RECOMMENDED PCBPAD SOLDER PAD .XXX± .125 T .XXX± .125 X° ± 1.30 .5° X° ± 1.30 .5° OPTICAL OPTICAL THIRD ANGLE THIRDPROJECTION ANGLE PROJECTION OUTLIN MATERIAL MATERIAL FOR SHEET METAL PARTS ONLY FOR SHEET METAL PARTS ONLY REFERENCE REFERENCE 1.0 1.0 .X ± 1.5.X ± 1.5 D SIZE S .XX ± .75.XX ± .75 .XXX± .25.XXX±FINAL FINISH .25 PROTECTIVE FINAL PROTECTIVE C Side View Top View X°Bottom ± .5° XView ° ± .5° SCALE 1.6 1.6 SURFACE FINISH: 22.000S SURFACE FINISH: 6 5 5 4 4 3 3 2 2 Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 33 .56 OPTICAL REFERENCE OPTICAL REFERENCE 3.45 XLamp ® XHP35 LED 3.45 Mechanical Dimensions - Continued R1.85 1.30 1.30 OPTICAL REFERENCE 3.30 3.50 .30 .30 .30 3.30 .50 .50 .30 .56 .50 .50 .56 .56 .56 .43 .83 .43 3.30 3.50 3.30 3.30 3.50 .29 .56 .18 .18 3.30 .18 .18 .29 .83 .56 .09 .09 .50 .18 .50 .70 1.50 .70 1.50 Recommended Copper Layout 3.30 R1.85 XHP35 High Density and XHP35 High Intensity OPTICAL REFERENCE 3.50 3 1.30 .50 1.30 Recommended Solder Pad (Solder Resist Pattern) .50 .50 .18 .50 .18 .18 3.30 3.30 Recommended Stencil Openings* Notes: • Cree recommends using thermal pad kickouts to maximize component thermal performance. • Cree recommends using white solder mask material to minimize system optical loss. * This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET® P30 Maxrel solder paste. For other solder pastes, a “window pane” design for the thermal pad stencil may result in a lower voiding percentage. Contact your local Cree Field Applications Engineer for consultation regarding your specific application. Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 34 A XLamp ® XHP35 LED B Tape and Reel A All Cree carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. 6 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. 66 XHP35 High Density 5 4 55 44 NOTICE NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND 6 CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT NOTICE MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION D UNAUTHORIZED UNAUTHORIZED PERSONWITHOUT WITHOUT THE THE WRITTEN CONSENT PERSON WRITTEN CONSENT CONTAINED WITHIN ARE THE PROPRIETARY AND OF CREE INC. OF CREE INC. CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT XHP35A-0x-xxxx-xxxxxxxxx 2.00 [.079] P2 DD 4.00 [.157] 2.00 [.079] [.079] 2.00 Po P2 P2 MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. 4 1.75 [.069] [.069] 1.75 E1 E1 CATHODESIDE SIDE CATHODE 1.75 [.069] E1 CATHODE SIDE C Ø1.50 5.50 [.217]F 5.50 [.217]F [.059] D1 MIN Ø1.50 Ø1.50 [.059] [.059] D1 D1 MIN MIN C CC ANODE SIDE 8.00 [.315] P ANODESIDE SIDE ANODE B 8.00 [.315] P 8.00 [.315] [.315] 8.00 4.0±.1 PP 1.75±.10 3.0 ° +.3 12.0 .0 3.60 [.142] Ao END 10.25 [.404] E2 12.30 [.484] 12.00 [.472] 12.00 [.472] MAX 5.50 [.217]F NOMINAL NOMINAL W 10.25 10.25 [.404] [.404] E2 E2 12.30[.484] [.484] 12.30 Ø1.50 MAX MAX [.059] W W D1 Bo - Bo C 3.60 [.142] [.142] 3.60 3.0 ° Bo Bo 3.0 °° 3.0 12.00 [.472] NOMINAL 10.25 [.404] E2 3.60 mm [.142"] 3.60 [.142] Bo C CC 12.30 [.484] MAX W 3.00 [.118] Ko 1.5±.1 8.0±.1 .30 [.012] T Anode Side .30 [.012] [.012] .30 TT 2.5±.1 3.00 [.118] Ko B B Cathode Side BB 3.0 °° 3.0 3.60 [.142] Ao Anode Side (denoted by + UNLESS andOTHERWISE circle) SPECIFIED DRAWN BY DATE UNLESS OTHERWISE SPECIFIED D. CRONIN 5/16/14 ARE IN DIMENSIONS DIMENSIONS ARE IN MILLIMETERS CHECK DATE AND AFTER FINISH. MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XX ± .25 DATE APPROVED .XXX ± .125 TITLE .XXX ± .125 X° ± .5 ° ANGLE X° THIRD ± .5 ° PROJECTION User Feed Direction User Feed Direction END THIRD ANGLE PROJECTION 6 5 5 4 Trailer 160mm (min) of 160 mm (min.) 55 emptyof pockets empty pockets sealed with tape sealed with tape (20 pockets min.) (20 pockets min.) 4 3 THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION Loaded Pockets Trailer 66 [.142] 3.00 mm [.118"] 3.00 mm Ko3.60 -[.118"] 3.00 mm [.118"] 3.0 ° .30 [.012] T AA 6 Ko-Ko MIN 3.00 [.118] [.118] 3.00 3.0 ° Ko Ko A 3.60 [.142] [.142] 3.60 Ao Ao 3.60mm mm[.142"] [.142"] 3.60 3.00 mm Ao -[.118"] 3.60 mm [.142"] 3.60mm mm[.142"] [.142"] 3.60 ANODE SIDE BB A Ao-Ao Ko Bo-Bo 12.00 [.472] NOMINAL 5.50 [.217]F B Ao 3.60 SECTION A-A mm [.142"] SCALE POCKET 2POCKET :1 SIZE Bo 3.60 mmSIZE [.142"] POCKET SIZE Ø1.50 +.10 -.00 SCALE 2 : 1 4.00 [.157] Po POCKET SIZE 3 Ø1.50 +.10 -.00 1.75 [.069] Ø1.50 Ø1.50 E1 +.10 +.10 DETAIL B -.00 -.00 2.00 [.079] CATHODE P2 SIDE 4.00 [.157] [.157] 4.00 Po Po Except as noted, all dimensions in mm [inches] 33 5 XHP35 High Density D 3 Loaded Pockets (1,000 Lamps) (500 Lamps) 44 33 FOR SHEET METAL PARTS ONLY FOR SHEET METAL PARTS ONLY .X.X ± ± 1.51.5 .XX ± ± .75.75 .XX .XXX ± ± .25.25 .XXX X°X° ± ± .5 .5° ° SURFACE FINISH: 1.61.6 SURFACE FINISH: D. CRONIN DATE START FINAL PROTECTIVE FINISH SURFACE FINISH: DATE DATE APPROVED APPROVED 3 MATERIAL MATERIAL 5/16/14 DATE APPROVED START FOR SHEET METAL PARTS ONLY MATERIAL DATE DRAWN DATE DRAWN BYBY .X ± 1.5 .XX ± .75 CRONIN 5/16/14 D.D. CRONIN 5/16/14 .XXX ± SIZE .25 CHECK DATE CHECK DATE X° ± .5 ° FOR SHEET METAL PARTS ONLY UNLESS OTHERWISE SPECIFIED UNLESS OTHERWISE SPECIFIED .X ± ARE IN 1.5 DIMENSIONS DIMENSIONS ARE IN .XX ± .75 MILLIMETERS AND AFTER FINISH. MILLIMETERS AND .XXX AFTER ± FINISH. .25 TOLERANCE SPECIFIED: TOLERANCE UNLESS X°UNLESS ± SPECIFIED: .5 ° .XX ± .25 .XX ± .25 1.6 SURFACE FINISH: .XXX .125 .XXX ± ± .125 X°X° ± ± .5 .5° ° DATE DRAWN BY CHECK 1.6 SCALE TITLE TITLE C 4600 Silicon Drive Durham, N.C 27703 4600 Silicon Drive Durham, N.C 27703 Phone (919) 313-5300 Phone (919) 313-5300 Fax (919) 313-5558 Fax (919) 313-5558 Carrier Tape, XPL MATERIAL SIZE DRAWING NO. FINAL PROTECTIVE FINISH Carrier Tape, XPL 2402-00040 SCALE Fax (919) 313-5558 2 SHEET REV. DRAWING NO. C 4600 Silicon Drive 4600 Silicon Drive Durham, N.C 27703 REV. Durham, N.C 27703 Phone (919) 313-5300 Phone (919) 313-5300 2402-00040 Fax 1.000 (919) 313-5558 A 1.000 A A TITLE OF SHEET A 1 /1 A A OF 1 /1 1 1 CarrierTape, Tape,XPL XPL Carrier 2 SIZE SIZE Leader CC Leader 400mm (min) of1.000 1.000 400empty mm22(min.) of with pockets emptyatpockets with least 100mm at least 100 mm sealed by tape sealed by tape (50 empty pockets min.) FINAL PROTECTIVE FINISH FINAL PROTECTIVE FINISH SCALE SCALE REV. REV. DRAWING NO. DRAWING NO. 2402-00040 2402-00040 SHEET SHEET AA OFOF 1 1/1/1 11 (50 empty pockets min.) User Feed Direction Cover Tape Pocket Tape 13mm 7" Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 35 B XLamp ® XHP35 LED A Tape and Reel - Continued POCKET SIZE XHP35 High Intensity SECTION A-AmmSIZE POCKET SIZE Ao - POCKET 3.70 [.146"] SCALE 2 : 1 XHP35A-Hx-xxxx-xxxxxxxxx XHP35 High Intensity 4.00 [.157] Po 4.00 [.157] [.157] 4.00 Po Po 2.00 [.079] P2 2.00 [.079] [.079] 2.00 P2 P2 Ø 1.50 +.10 +.0039 -.00[.0591-.0000]Do DETAIL B +.10 +.0039 : 1 -.00[.0591-.0000]Do 1.50+.102+.0039 -.00[.0591-.0000]Do ØØSCALE 1.50 Ao Bo -Ao 3.70 mm mm [.146"] [.146"] 3.70 Bo Ko-Bo 3.70 mm [.146"] [.146"] 1.20mm [.047"] POCKET SIZE 3.70 Ko -Ko 1.20 mm mm [.047"] [.047"] 1.20 Ao - 3.70 mm [.146"] 1.75 [.069] E1 1.75 [.069] 1.75 [.069] 2.00 [.079] E1 E1 +.10 +.0039 Ø 1.50 -.00[.0591-.0000]Do P2 CATHODE SIDE CATHODESIDE SIDE CATHODE 4.00 [.157] Po 5.50 [.217]F CATHODE SIDE 5.50 [.217]F [.217]F 5.50 Ø 1.50 [.059] 1.50 ØØD1 1.50 MIN [.059] [.059] D1 D1 MIN MIN ANODE SIDE ANODE SIDE ANODE SIDE 8.00 [.315] P 8.00 [.315] [.315] 4.0±.1 8.00 PP 1.75±.10 ANODE SIDE 8.00 [.315] P 3.0° +.3 12.0 .0 10.25 [.404] E2 10.25 10.25 [.404] [.404] E2 E2 1.75 [.069] 12.00 [.472] E1 NOMINAL 12.00 [.472] [.472] 12.00 12.30 [.484] NOMINAL NOMINAL MAX 12.30W [.484] 12.30 [.484] MAX MAX 5.50 [.217]F W W Ø 1.50 [.059] D1 MIN 8.0±.1 1.20 [.047] Ko 1.20 [.047] [.047] 1.20 Ko Ko 3.0° 3.0° 3.70 [.146] Ao 3.70 [.146] [.146] 3.70 Ao Ao 10.25 [.404] E2 Bo - 3.70 mm [.146"] Ko - 1.20 mm [.047"] 3.0° 3.0° 3.0° 12.00 [.472] NOMINAL 3.70 [.146] Bo 3.70 [.146] [.146] 3.0° 3.70 Bo Bo 3.70 [.146] Bo 12.30 [.484] MAX W 1.5±.1 .30 [.012] T .30 [.012] [.012] .30 TT 2.5±.1 Cathode Side Anode Side .30 [.012] T 1.20 [.047] Ko Anode Side 3.0° (denoted by + and circle) User Feed Direction END START 3.70 [.146] Ao Trailer 160mm (min) of empty pockets sealed with tape (20 pockets min.) Loaded Pockets (1,000 Lamps) Leader 400mm (min) of empty pockets with at least 100mm sealed by tape (50 empty pockets min.) User Feed Direction Cover Tape Pocket Tape 13mm 7" Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 36 XLamp ® XHP35 LED Packaging Unpackaged Reel Vacuum-Sealed Vacuum-Sealed Moisture Barrier Bag Moisture Barrier Bag Label CREE Binwith Code Cree Bin & Barcode LabelLot # Code, Qty, Label with Cree Bin Code, Quantity, Reel ID Label with Cree Bin Label with Customer P/N, Qty,Qty, Lot #, Lot PO # # Code, Packaged Reel Patent Label Label with Customer Order Label with Cree Order Code, Code, Qty, Reel ID, PO # Quantity, Reel ID, PO # Label with Cree Bin Code, Quantity, Reel ID Boxed Reel Label with Cree Order Code, Quantity, Reel ID, PO # Label with Cree Bin Code, Quantity, Reel ID Patent Label (on bottom of box) Copyright © 2015-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 37
XHP35A-00-0000-0D0BE20E3 价格&库存
很抱歉,暂时无法提供与“XHP35A-00-0000-0D0BE20E3”相匹配的价格&库存,您可以联系我们找货
