GWJDSMS1.PC-FSFU-5R8T-L1N2
    AMSOSRAM(艾迈斯半导体)
    SMD-4P
    LEDDURISE5WARMWHT3000K
GWJDSMS1.PC-FSFU-5R8T-L1N2 数据手册
2013-11-22 DURIS® E 5 Datasheet Draft Version 0.0 GW JDSMS1.PC The DURIS® E 5 combines high efficacy and a wide beam angle into a compact format (5.6 mm x 3.0 mm). This is key to homogeneous illumination applications where the DURIS® E 5 never fails to impress with its performance on system level. DURIS® E 5 在一个紧凑的封装尺寸 (5.6 毫米 x3.0 毫米)内同时具备高发光效率和宽发光角度,这是 DURIS® E 5 实现高性能系统设计和均匀照明应用的 关键。 Features: 性能 : • Package: white SMT package, colored diffused silicone resin • Viewing angle at 50 % IV: 120° • Color: 3000 K - 6500 K ( white ) • CRI: min. 70 • Luminous Flux: typ. 48 lm @ 5000 K • Luminous efficacy: typ. 127 lm/W @ 5000 K • 封装 : 白色贴片式,色散硅树脂 Applications 应用 • • • • • • Retrofits and fixtures • Task lights 2013-11-22 DRAFT – For Reference only. Subject to change. 视角 at 50 % IV: 120° 色温 : 3000 K - 6500 K ( 白色 ) 显色指数 : min. 70 典型光通量 : typ. 48 lm @ 5000 K 发光效率 : typ. 127 lm/W @ 5000 K • 替换灯和灯具 • 工作灯 1 Draft Version 0.0 GW JDSMS1.PC Ordering Information 订购信息 Type: Color Temperature Luminous Intensity 1) page 24 Ordering Code 类型 : 色温 发光强度 1) 第 24 订购代码 IF = 120 mA [K] IV [mcd] GW JDSMS1.PC-FTGP-5C8E-L1N2 6500 15000 ... 19400 Q65111A5428 GW JDSMS1.PC-FTGP-5E8G-L1N2 5700 15000 ... 19400 in process GW JDSMS1.PC-FTGP-5H7I-L1N2 5000 15000 ... 19400 Q65111A5427 GW JDSMS1.PC-FTGP-5L7N-L1N2 4000 15000 ... 19400 Q65111A5431 GW JDSMS1.PC-FSFU-5L7N-L1N2 4000 14000 ... 18000 Q65111A5377 GW JDSMS1.PC-FTGP-5R8T-L1N2 3000 15000 ... 19400 Q65111A5430 GW JDSMS1.PC-FSFU-5R8T-L1N2 3000 14000 ... 18000 Q65111A5429 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page ). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW JDSMS1.PC-FTGP-5H7I-L1N2 means that only one group FT, FU, GP will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. GW JDSMS1.PC-FTGP-5H7I-L1N2 means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity groups groups will not be orderable (see page ). In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing unit. E. g. GW JDSMS1.PC-FTGP-5H7I-L1N2 means that only one forward voltage group L1,L2,M1,M2,N1,N2 will be shippable. In order to ensure availability, single forward voltage groups will not be orderable (see page ). 注释 : 上述类型编号代表仅包含几个亮度组的订购组 (参见第 页) 。每个卷盘上仅装运一个亮度组 (一个卷盘上不会混装两个亮度组) 。例如, GW JDSMS1.PC-FTGP-5H7I-L1N2 表示任何一个卷盘上仅可装运一个亮度组: FT, FU, GP 。为了确保可用性,单个亮度组将不接受订购。 类似地, 对于需要测量和分选色度坐标组的颜色, 每个卷盘上将仅装运单个色度坐标组。例如, GW JDSMS1.PC-FTGP-5H7I-L1N2 表示仅可装运特 定范围内的一个色度坐标组 (参见第 页)。为了确保可用性,单个色度坐标组将不接受订购。 同样,对于需要测量和分选正向电压组的 LED,每个卷盘上将仅装运一个正向电压组。例如,GW JDSMS1.PC-FTGP-5H7I-L1N2 表示每卷盘上仅可 装运正向电压组 L1,L2,M1,M2,N1,N2 中的一个。为了确保可用性,单个正向电压组将不接受订购 (参见第 页)。 2013-11-22 DRAFT – For Reference only. Subject to change. 2 Draft Version 0.0 GW JDSMS1.PC Maximum Ratings 最大额定值 Parameter Symbol 参数 符号 Operating temperature range 工作温度范围 Top -40 ... 85 °C Storage temperature range 储存温度范围 Tstg -40 ... 100 °C Junction temperature 结点温度 Tj 110 °C Forward current 正向电流 (TS = 25 °C) IF 180 mA Surge current 冲击电流 (t
GWJDSMS1.PC-FSFU-5R8T-L1N2 价格&库存
很抱歉,暂时无法提供与“GWJDSMS1.PC-FSFU-5R8T-L1N2”相匹配的价格&库存,您可以联系我们找货
