8
5
6
7
4
2
3
NOTES:
D
1. ROHS COMPLIANT
2. MATERIALS:
FIBER OPTIC: 1.5MM OPTICAL CORE, 2.2MM POLYETHYLENE
CABLE JACKET
LENS MOUNT: OPTICAL GRADE ACRYLIC
LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2
FOR THR 5 22 - NYLON 66, UL RATING 94-HB
LENS: POLYCARBONATE, UL RATING 94-V2
LENS SPACER: POLYPROPYLENE
3. OPTICAL CORE ENDS POLISHED TO 10 MICRONS.
4. PANEL MOUNTING HOLE .250" (6.35mm) ON 3/8" (9.52mm)CENTERS
5. PANEL THICKNESS FOR CLF 280: 1/16" (1.60mm) TO 1/8" (3.18mm);
CLB 300, CLR 301 AND SQB 400: 1/32" (0.79mm) TO 1/4" (6.35mm).
6. FOR PANELS LESS THAN 3/16" (4.76mm) USE SPC 125 SPACER
7. FOR ADDED SECURITY USE RNG 268.
8. FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED
LEDS WITH OUTPUT POWER GREATER THAN 100mcd.
9. U.S. AND FOREIGN PATENS ISSUED.
1
REVISIONS
LIGHT PIPE ASSEMBLY
ORDERING CODE (EXAMPLE):
FLX XX
ECN #
REV.
DESCRIPTION
DATE
001
INITIAL RELEASE
7/8/10
SMU
DZ
396
002
003
004
CHG DWG FORMAT
REVISED PER ECR 092810AA01
REVISED PER ECR 011812KH01
8/2/10
10/4/10
1/19/12
KH
KH
KH
AZ
AZ
AZ
LENGTH
LENGTH ACTUAL
CODE LENGTH
02
2.0"
04
4.0"
06
6.0"
08
8.0"
C
C
.560in
14.22mm
SMD 22
.059in
1.50mm
CLF 280
.230in
5.84mm
FIBER OPTIC
D
LENS OPTIONS
(ORDER
SEPARATELY)
12.0"
12
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
MOUNTING OPTIONS
(ORDER SEPARATELY)
INITIALS CHK'D
.280in
7.11mm
CLB 300
.203in
5.16mm
.040in
1.02mm
.06in±.02
1.52mm±0.51
B
FIBER OPTIC LENGTH XX±.25
THR 22
CLR 301
B
LENS MOUNT
SQB 400
THR 5 22
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
A
63
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
KHOWARD
8/2/10
CHECKED
AZANELLI
8/2/10
OPTOELECTRONICS
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
FLX XX ASSEMBLY
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 1:1
DO NOT SCALE DRAWING
2
004
FLX XX
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“FLX_08”相匹配的价格&库存,您可以联系我们找货
