8
7
6
5
4
2
3
NOTES:
1.
2.
D
3.
4.
5.
6.
7.
8.
1
REVISIONS
ROHS COMPLIANT
MATERIALS:
FIBER OPTIC: 1.5MM OPTICAL CORE, 2.2MM POLYETHLENE
CABLE JACKET
LENS MOUNT: OPTICAL GRADE ACRYLIC
LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2
FOR THR 5 22 - NYLON 66, UL RATING 94-HB
LENS: POLYCARBONATE, UL RATING 94-V2
LENS SPACER: POLYPROPYLENE
OPTICAL CORE ENDS POLISHED TO 10 MICRONS
PANEL MOUNTING HOLE: .171" .002 (4.34mm 0.05) ON 1/4"(6.35mm) CENTERS
PANEL THICKNESS FOR SML 190: 1/32" (0.79mm) TO 1/16"(1.60mm);
SMB 200 AND SMQ 250: 1/16" (1.60mm) TO 1/8" (3.48mm)
FOR ADDED SECURITY FOR SMB 200 AND SMQ 250 USE SPC 040 SPACER
FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED
LEDS WITH OUTPUT POWER GREATER THAN 100mcd
U.S. AND FOREIGN PATENTS ISSUED
LITE PIPE ASSEMBLY
ORDERING CODE (EXAMPLE): FLX3 XX
LENGTH
ECN #
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
001
INITIAL RELEASE
2/4/10
KH
AZ
002
7/20/10
KH
AZ
003
REVISED PER ECR 092810AA01
10/4/10
KH
AZ
397
004
REVISED PER ECR 011812KH01
1/19/12
KH
AZ
MOD TO NOTE 4&5; CHG
.059 TO
.039
D
LENGTH ACTUAL
CODE LENGTH
02
2.0"
04
4.0"
06
6.0"
08
8.0"
12
12.0"
LENS
(ORDER SEPARATELY)
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
C
C
.450in
11.43mm
MOUNTING OPTIONS
(ORDER SEPARATELY)
TRIM FIBER
OPTIC JACKET
SMD 22
LENS MOUNT
FIBER OPTIC
.155in
3.94mm
.135in
3.43mm
.06in±.02
1.52mm±0.51
SML 190
.125in
3.18mm
.020in
0.51mm
B
SMB 200
B
FIBER OPTIC LENGTH XX±.25
SMQ 250
THR 22
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
A
63
THR 5 22
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
KHOWARD
2/4/10
CHECKED
AZANELLI
2/10/10
OPTOELECTRONICS
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
3MM FLEXFIRE FLEXIBLE
LITEPIPE
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 2:1
DO NOT SCALE DRAWING
2
FLX3 XX
004
SHEET 1 OF 2
1
A
很抱歉,暂时无法提供与“FLX3_02”相匹配的价格&库存,您可以联系我们找货
