LFB075CTP
LFB075CTP
    VCC
    LIGHT PIPE ROUND 3MM
LFB075CTP 数据手册
LFB Series 3mm Press Fit, Low Profile Diffused Rigid Light Pipe LFB Series litepipeTM features diffused round 3mm surface for super wide viewing angle at 120 degrees Applications • • • • audio/video communication darkroom equipment electrical panels • • • • • • • entertainment industrial medical IoT security studio control transportation Key features • for use with surface-mount or through-hole • press fit (front panel mount) with crushable ribs • • • • LEDs optical grade polycarbonate for maximum light transmission low profile, flush panel design wide viewing angle at 120 degrees frosted surface diffuses light and provides uniform brightness and a soft glow that simplifies installation • no physical connection between light pipe and LED provides versatility for assembly • standard lengths from 0.125” to 1.000” • custom lengths available • optional RTN112 retainer provides a reliable solution for high-vibration environments Dimensions 0.030+0.020 [0.76+0.51] +0.002 -0.003 [Ø2.84 +0.05 -0.08 Ø0.112 +0.003 -0.002 +0.08 [Ø3.00 -0.05 Ø0.130+0.020 [Ø3.30+0.51] ] Ø0.118 ] LENGTH±0.010 “SEE ORDERING DATA” mounting hole size Dimensions in inches [mm] the first call for illuminated components www.vcclite.com 1.800.522.5546 10/15 Rev 1 Product Specifications Material Polycarbonate, clear, UL 94-V0 Installation Specification mounting hole 0.118” +0.003/-0.002 (3.00mm +0.08/-0.05) panel thickness 0.040” (1.02mm) to 0.093”(2.36mm) Recommendation: Maximum air gap (clearance) between LED and light pipe for best performance: • 0.020” for wide viewing angle LED • 0.050” for narrow viewing angle LED Ordering Data LFB Optional Accessory CTP 012 025 035 037 050 063 075 100 Length 0.125” (3.2mm) 0.250” (6.4mm) 0.350” (8.9mm) 0.375” (9.5mm) 0.500” (12.7mm) 0.625” (15.9mm) 0.750” (19.0mm) 1.000” (25.4mm) Retainer for LFB Series 3mm Light Pipe (order separately) Ordering Number: RTN112 • • recommended for high vibration applications secure and uniform placement of the light pipe to the panel • field-proven design panel retainer light pipe Please see datasheet RTN112 for more details Compliance & Approvals the first call for illuminated components www.vcclite.com 1.800.522.5546 10/15 Rev 1
LFB075CTP 价格&库存
很抱歉,暂时无法提供与“LFB075CTP”相匹配的价格&库存,您可以联系我们找货
LFB075CTP
  • 1+8.950831+1.05983
  • 10+6.2281910+0.73745
  • 100+4.57053100+0.54118
  • 500+3.82923500+0.45340
  • 1000+3.586401000+0.42465
  • 2000+3.380112000+0.40023
  • 5000+3.154735000+0.37354
  • 10000+3.0142510000+0.35691
  • 25000+2.8611425000+0.33878
库存:44964
