LSS_024_GTP
LSS_024_GTP
    VCC
    3MMSEALEDLITEPIPELENSASSY
LSS_024_GTP 数据手册
8 D 5 6 7 4 MOISTURE SEAL C 2 3 NOTES: 1. ROHS COMPLIANT 2. MATERIAL: LIGHTPIPE - ACRYLIC (CLEAR OPTICAL GRADE), UL 94-HB LENS - POLYCARBONATE, UL 94-V2 SEAL - EPDM RETAINING RING - POLYPROPYLENE (BLACK) 3. MOUNTING: MOUNTS IN A .171" .002 [ 4.34mm .05] PANEL HOLE ON .250" [6.35mm] CENTER 4. PANEL HOLE SHALL BE DEBURRED, BUT NOT CHAMFERED 5. PANEL THICKNESS: .031" [.8mm] TO .094" [2.39mm] 6. ASSEMBLY: A.) INSERT LITEPIPE THROUGH PANEL HOLE B.) PRESS ON RETAINING RING TO SECURE UNIT TO PANEL C.) SLIDE PCB INTO POSITION ALIGNING LED WITH END OF LITEPIPE UNIT 7. U.S AND FOREIGN PATENTS ISSUED 1 REVISIONS ECN # REV. DESCRIPTION DATE INITIALS CHK'D 391 000 INITIAL RELEASE 2/20/12 KH AZ D .170in 4.32mm RETAINING RING .125in 3.16mm .193in 4.91mm C .240in 6.10mm B B .080in 2.03mm .XXX ORDERING CODE: LSS XXX XXX LITEPIPE A LENS XXX = LENGTH XXX = COLOR 024 .240" (6.10mm) RTP RED TRANSPARENT 044 .440" (11.18mm) ATP AMBER TRANSPARENT 064 .640" (16.26mm) 084 .840" (21.34mm) 104 1.04" (26.4mm) 124 1.24" (31.5mm) CUSTOM LENGTHS AVAILABLE UPON REQUEST 8 GTP BTP GREEN TRANSPARENT BLUE TRANSPARENT YTP YELLOW TRANSPARENT CTP 7 LENS LITEPIPE LED DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED DISPLAY PANEL GAP .050" PCB RNG 132 RETAINING RING INCHES .020 .010 .005 ANGLE 1' MM .508 .254 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX DATE KHOWARD 2/20/12 CHECKED AZANELLI 3/6/12 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: MATERIAL ASSY, 3MM MOISTURE SEALED LITEPIPE THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 5 APPROVAL DRAWN SEE NOTES ASSEMBLY CLEAR TRANSPARENT 6 .X .XX .XXX 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 8:1 DO NOT SCALE DRAWING 2 000 LSS XXX XXX SHEET 1 OF 1 1 A
LSS_024_GTP
1. 物料型号:文档中没有明确列出物料型号,但提到了“LSS XXX”,这可能是一个型号或系列号。 2. 器件简介:文档描述了一种名为“Litepipe”的器件,它是一种光导器件,由透明光学级丙烯酸材料制成,带有聚碳酸酯透镜和三元乙丙橡胶密封圈,以及黑色聚丙烯保持环。 3. 引脚分配:文档中没有提供引脚分配信息。 4. 参数特性:文档提供了Litepipe的尺寸参数,例如长度、透镜颜色选项,以及安装要求,如面板厚度和安装孔尺寸。 5. 功能详解:文档解释了Litepipe的功能,即通过LED与光导器件的配合使用,实现显示面板的背光照明。 6. 应用信息:Litepipe可以用于显示面板的背光照明,支持多种颜色的透镜选项,并且可以根据需要定制长度。 7. 封装信息:文档提供了Litepipe的封装细节,包括材料、尺寸和安装说明。
LSS_024_GTP 价格&库存
很抱歉,暂时无法提供与“LSS_024_GTP”相匹配的价格&库存,您可以联系我们找货
LSS_024_GTP
  • 50+15.3864550+1.97452
  • 250+10.00841250+1.28436
  • 500+9.62057500+1.23459
库存:750
