LMS_113_CTP
LMS_113_CTP
    VCC
    SEALED LITEPIPE LENS ASSY
LMS_113_CTP 数据手册
8 5 6 7 4 2 3 NOTES: 1. 2. 3. D 4. 5. 1 REVISIONS ECN # MOUNTING: Mounts in a .281 .002 (7.14mm 0.051) panel hole on .375 (9.53mm) centers. Panel thickness .031 (.8mm) to .125 (3.18mm). Panel hole shall be deburred, but not chamfered. ASSEMBLY: Insert Litepipe through the panel hole and press on retaining ring to secure unit to panel. Slide PCB into position aligning LED with the end of the Litepipe unit. MATERIAL: Litepipe - Acrylic (Clear optical grade) UL 94-HB Lens - Polycarbonate UL 94-V2 Seal - TPE Retaining Ring - Polypropylene (Black) Meets NEMA 4/IP 56 standards U.S. & Foreign Pat. Issued MOISTURE SEAL .280 (7.112mm) REV. DESCRIPTION DATE INITIALS CHK'D 001 REVISED PER ECR 111009AZ01 8/18/10 KH DPZ 002 MODIFIED GENERAL TOLERANCE .XX 11/14/11 RL AZ D RETAINING RING .200 (5.080mm) C C .300 (7.620mm) .360 (9.144mm) .165 (4.191mm) .XXX B B ORDERING CODE: LMS XXX XXX A LITEPIPE XXX = LENGTH 033 .330" 053 .530" 073 .730" 093 0.93" 113 1.13" 133 1.33" CUSTOM LENGTHS AVAILABLE UPON REQUEST 8 LENS XXX = RTP ATP GTP BTP YTP CTP GLO COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT WHITE TRANSLUCENT DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED .X .XX .XXX 7 MM .508 .381 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX APPROVAL DATE DRAWN K HOWARD 8/18/10 CHECKED DPZ 8/19/10 OPTOELECTRONICS 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com TITLE: MATERIAL 5MM MOISTURE SEALED LITEPIPE SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. ASSEMBLY 6 INCHES .020 .015 .005 ANGLE 1' 5 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 6:1 DO NOT SCALE DRAWING 2 002 LMS XXX XXX SHEET 1 OF 1 1 A
LMS_113_CTP
1. 物料型号:文档中没有明确列出物料型号。 2. 器件简介:文档描述了一种名为Litepipe的光学器件,它由亚克力材料制成,具有清晰的光学等级,并且有一个聚碳酸酯的透镜和热塑性弹性体(TPE)的密封圈以及聚丙烯(黑色)的固定环。 3. 引脚分配:文档中没有提及引脚分配。 4. 参数特性:Litepipe的尺寸参数包括0.280英寸(5.080mm)的固定环直径,0.200英寸(7.112mm)和0.300英寸(7.620mm)的尺寸,以及0.360英寸(9.144mm)和0.165英寸(4.191mm)的其他尺寸。此外,它符合NEMA 4/IP 56标准。 5. 功能详解:Litepipe用于LED照明,通过面板孔插入并使用固定环固定。它还具有防潮密封功能。 6. 应用信息:文档提到Litepipe可以用于显示面板的精细高度调整。 7. 封装信息:Litepipe的订购代码和长度选项在文档中有说明,例如RTP 133 .330" ATP 033 053GTP,并且可以请求定制长度。
LMS_113_CTP 价格&库存
很抱歉,暂时无法提供与“LMS_113_CTP”相匹配的价格&库存,您可以联系我们找货
