8
5
6
7
4
2
3
NOTES:
1.
2.
3.
D
4.
5.
1
REVISIONS
ECN #
MOUNTING: Mounts in a .281 .002 (7.14mm 0.051) panel hole on .375 (9.53mm) centers.
Panel thickness .031 (.8mm) to .125 (3.18mm). Panel hole shall be deburred, but not chamfered.
ASSEMBLY: Insert Litepipe through the panel hole and press on retaining ring to secure unit to
panel. Slide PCB into position aligning LED with the end of the Litepipe unit.
MATERIAL: Litepipe - Acrylic (Clear optical grade) UL 94-HB
Lens - Polycarbonate UL 94-V2
Seal - TPE
Retaining Ring - Polypropylene (Black)
Meets NEMA 4/IP 56 standards
U.S. & Foreign Pat. Issued
MOISTURE
SEAL
.280
(7.112mm)
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
001
REVISED PER ECR 111009AZ01
8/18/10
KH
DPZ
002
MODIFIED GENERAL TOLERANCE .XX
11/14/11
RL
AZ
D
RETAINING
RING
.200
(5.080mm)
C
C
.300
(7.620mm)
.360
(9.144mm)
.165
(4.191mm)
.XXX
B
B
ORDERING CODE: LMS XXX XXX
A
LITEPIPE
XXX = LENGTH
033
.330"
053
.530"
073
.730"
093
0.93"
113
1.13"
133
1.33"
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
8
LENS
XXX =
RTP
ATP
GTP
BTP
YTP
CTP
GLO
COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
WHITE TRANSLUCENT
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
7
MM
.508
.381
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
K HOWARD
8/18/10
CHECKED
DPZ
8/19/10
OPTOELECTRONICS
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
5MM MOISTURE SEALED
LITEPIPE
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
ASSEMBLY
6
INCHES
.020
.015
.005
ANGLE 1'
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 6:1
DO NOT SCALE DRAWING
2
002
LMS XXX XXX
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“LMS_133_ATP”相匹配的价格&库存,您可以联系我们找货
