8
5
6
7
4
2
3
1.
2.
3.
D
4.
5.
ECN #
MOUNTING: Mounts in a .312 .002 ( 7.92mm 0.051) panel hole on .500 (12.7mm) centers.
Panel thickness .031 (.8mm) to .125 (3.18mm). Panel hole shall be deburred, but not chamfered.
ASSEMBLY: Insert Litepipe through the panel hole, slide lock washer onto lens barrel on litepipe
and twist on retaining ring. Slide PCB into position aligning LED with the end of the Litepipe unit.
MATERIAL: Litepipe - Acrylic ( Clear optical grade) UL 94-HB
Lens - Polycarbonate UL 94-V2
Seal - EPDM
Lock washer - FH Steel, Nickel Plate
Retaining Nut - Thermoplastic (white) UL 94-V0
Meets NEMA 6P/IP 67 standards
U.S. & Foreign Pat. Issued
DESCRIPTION
REVISED PER ECR 111009AZ01
DATE
8/18/10
INITIALS
KH
CHK'D
DZ
002
MODIFIED GENERAL TOLERANCE .XX
11/29/11
KH
AZ
.344in
8.74mm
RETAINING
NUT
LOCK
WASHER
0.307in
7.8mm
C
C
.430
10.93mm
.432in
10.97mm
.200in
5.08mm
B
REV.
001
D
MOISTURE SEAL
.XXX
ORDERING CODE: LCS
LITEPIPE
XXX = LENGTH
032
.320"
052
.520"
072
.720"
092
.92"
112
1.12"
1.32"
132
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
8
B
.370
9.40mm
.150in
3.81mm
.034in±.003
0.86mm±0.08
A
1
REVISIONS
NOTES:
.016in
0.41mm
XXX XXX
LENS
XXX =
RTP
ATP
GTP
BTP
YTP
CTP
COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
MM
.508
.381
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
KHOWARD
8/18/10
CHECKED
DPZ
8/19/10
OPTOELECTRONICS
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
ASSEMBLY
7
INCHES
.020
.015
.005
ANGLE 1'
6
5
4
3
5MM THREADED
MOISTURE SEALED
LITEPIPE
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 5:1
DO NOT SCALE DRAWING
2
002
LCS XXX XXX
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“LCS_052_RTP”相匹配的价格&库存,您可以联系我们找货
