8
7
5
6
4
2
3
1.
2.
D
3.
4.
5.
6.
7.
8.
1
REVISIONS
NOTES:
ROHS COMPLIANT
MATERIALS:
FIBER OPTIC: 1.5MM OPTICAL CORE, 2.2MM POLYETHYLENE
CABLE JACKET
LENS MOUNT: OPTICAL GRADE ACRYLIC
LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2
FOR THR 5 22 - NYLON 66, UL RATING 94-HB
LENS: POLYCARBONATE UL RATING 94-V2
LENS WASHER: FH STEEL, NICKLE PLATE
LENS RETAINING RING: THERMOPLASTIC UL RATING 94-V0
LENS SEAL: EPDM
OPTICAL CORE ENDS POLISHED TO 10 MICRONS
MOUNTS THROUGH FRONT OF PANEL. SECURED BY RETAINING RING
LENSES MOUNT THROUGH A 5/16" (7.94mm) HOLE ON 1/2" (6.35mm) CENTERS
PANEL THICKNESS 1/32" (0.79mm) TO 1/8" (3.18mm)
FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS
WITH OUTPUT POWER GREATER THAN 100mcd
U.S. AND FOREIGN PAT. ISSUED
LITE PIPE ASSEMBLY
ORDERING CODE (EXAMPLE): FLX
LENS TYPE CODE
CMC 441, STANDARD FRESNEL
CMS 442, MOISTURE-SEALED FRESNEL
CMC 443, PLAIN LENS
CMS 444, MOISTURE-SEALED PLAIN END
441
442
443
444
MOUNTING OPTIONS
(ORDER SEPARATELY)
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
001
INITIAL RELEASE
7/8/09
SMU
AZ
002
DWG FORMAT UPDATE
8/2/10
KH
AZ
003
REVISED PER ECR 092810AA01
10/4/10
KH
AZ
396
004
REVISED PER ECR 011812KH01
1/20/12
KH
AZ
D
44X XXX XX
LENS COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
RTP
ATP
GTP
BTP
YTP
CTP
CMS 442 & CMS 444; INCLUDES
LENS W/SEAL (MEETS NEMA 6P
RATING), CLW 441 LOCKWASHER,
AND RTN 441 RETAINING RING
C
ECN #
FIBER LENGTH
CODE
02
2.0"
04
4.0"
6.0"
06
08
8.0"
12
12.0"
CUSTOM LENGTHS
AVAILABLE UPON
REQUESTS
CMC 441 & CMC 443; INCLUDES
LENS, CLW 441 LOCKWASHER, AND
C
SMD 22
FIBER OPTIC
LENS MOUNT
LENS
B
B
.06in±.02
1.52mm±0.51
THR 22
FIBER OPTIC LENGTH XX .25
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
A
.X
.XX
.XXX
THR 5 22
63
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
KHOWARD
8/2/10
CHECKED
AZANELLI
8/2/10
OPTOELECTRONICS
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
TITLE:
MATERIAL
FLX 44X FLEXFIRE
FLEXIBLE LITEPIPE
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 2:1
DO NOT SCALE DRAWING
2
FLX 44X XXX XX
004
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“FLX_441_CTP_02”相匹配的价格&库存,您可以联系我们找货
