LCS_112_GTP
LCS_112_GTP
    VCC
    LITEPIPE ASSY GRN 5MM THR 1.12"L
LCS_112_GTP 数据手册
8 5 6 7 4 2 3 1. 2. 3. D 4. 5. ECN # MOUNTING: Mounts in a .312 .002 ( 7.92mm 0.051) panel hole on .500 (12.7mm) centers. Panel thickness .031 (.8mm) to .125 (3.18mm). Panel hole shall be deburred, but not chamfered. ASSEMBLY: Insert Litepipe through the panel hole, slide lock washer onto lens barrel on litepipe and twist on retaining ring. Slide PCB into position aligning LED with the end of the Litepipe unit. MATERIAL: Litepipe - Acrylic ( Clear optical grade) UL 94-HB Lens - Polycarbonate UL 94-V2 Seal - EPDM Lock washer - FH Steel, Nickel Plate Retaining Nut - Thermoplastic (white) UL 94-V0 Meets NEMA 6P/IP 67 standards U.S. & Foreign Pat. Issued DESCRIPTION REVISED PER ECR 111009AZ01 DATE 8/18/10 INITIALS KH CHK'D DZ 002 MODIFIED GENERAL TOLERANCE .XX 11/29/11 KH AZ .344in 8.74mm RETAINING NUT LOCK WASHER 0.307in 7.8mm C C .430 10.93mm .432in 10.97mm .200in 5.08mm B REV. 001 D MOISTURE SEAL .XXX ORDERING CODE: LCS LITEPIPE XXX = LENGTH 032 .320" 052 .520" 072 .720" 092 .92" 112 1.12" 1.32" 132 CUSTOM LENGTHS AVAILABLE UPON REQUEST 8 B .370 9.40mm .150in 3.81mm .034in±.003 0.86mm±0.08 A 1 REVISIONS NOTES: .016in 0.41mm XXX XXX LENS XXX = RTP ATP GTP BTP YTP CTP COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED .X .XX .XXX MM .508 .381 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX APPROVAL DATE DRAWN KHOWARD 8/18/10 CHECKED DPZ 8/19/10 OPTOELECTRONICS 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com TITLE: MATERIAL SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. ASSEMBLY 7 INCHES .020 .015 .005 ANGLE 1' 6 5 4 3 5MM THREADED MOISTURE SEALED LITEPIPE REV SIZE DWG. NO. SEE NOTES B SCALE: 5:1 DO NOT SCALE DRAWING 2 002 LCS XXX XXX SHEET 1 OF 1 1 A
LCS_112_GTP
1. 物料型号:文档中没有明确列出物料型号,但提到了LCS订购代码,可能与物料型号相关。 2. 器件简介:Litepipe是一款具有防水密封特性的LED灯组件,适用于面板安装,材质包括亚克力、聚碳酸酯、EPDM密封圈、镍镀钢锁垫圈和热塑性白色固定螺母。 3. 引脚分配:文档中没有提供具体的引脚分配信息。 4. 参数特性:Litepipe的尺寸参数包括长度、直径等,具体数值如7.8mm、10.97mm、8.74mm等。还提到了符合NEMA 6P/IP 67标准。 5. 功能详解:Litepipe具有防水密封功能,通过插入面板孔、安装锁垫圈和固定环来组装。 6. 应用信息:适用于需要防水密封的LED照明应用。 7. 封装信息:Litepipe的封装材料包括亚克力、聚碳酸酯等,固定螺母为热塑性材料。
LCS_112_GTP 价格&库存
很抱歉,暂时无法提供与“LCS_112_GTP”相匹配的价格&库存,您可以联系我们找货
