FLX_322_YTP_12
FLX_322_YTP_12
    VCC
    LITEPIPEFLEXYELLOWTRANSP12"
FLX_322_YTP_12 数据手册
8 7 5 6 4 1. 2. D 3. 4. 5. 6. 7. 8. 2 3 1 REVISIONS NOTES: ROHS COMPLIANT MATERIALS: FIBER OPTIC: 1.5MM OPTICAL CORE, 2.2MM POLYETHYLENE CABLE JACKET LENS MOUNT: OPTICAL GRADE ACRYLIC LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2 FOR THR 5 22 - NYLON 66, UL RATING 94-HB LENS: POLYCARBONATE UL RATING 94-V2 LENS RETAINING RING: POLYPROPYLENE LENS SEAL: TPE OPTICAL CORE ENDS POLISHED TO 10 MICRONS MOUNTS THROUGH FRONT OF PANEL. COMPRESSION OF THE SEAL IS ACCOMPLISHED BY PRESSING THE RETAINING RING IN PLACE LENSES MOUNT THROUGH A 9/32" (7.12mm) HOLE ON 3/8" (9.52mm) CENTERS PANEL THICKNESS 1/32" (0.79mm)TO 1/8" (3.18mm) FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS WITH OUTPUT POWER GREATER THAN 100mcd U.S. AND FOREIGN PAT. ISSUED ECN # REV. DESCRIPTION DATE 396 001 002 003 004 INITIAL RELEASE DWG FORMAT UPDATE REVISED PER ECR 092810AA01 REVISED PER ECR 011812KH01 7/8/09 8/2/10 10/4/10 1/20/12 INITIALS CHK'D SMU KH KH KH AZ AZ AZ AZ D LITE PIPE ASSEMBLY ORDERING CODE (EXAMPLE): FLX 322 XXX XX LENS COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT WHITE TRANSLUCENT LENS TYPE CODE RTP ATP GTP BTP YTP CTP GLO CMS 322, LOW PROFILE FRESNEL LENS WITH MOISTURE SEAL AND RETAINING RING. MEETS NEMA 4 RATING. 322 C MOUNTING OPTIONS (ORDER SEPARATELY) FIBER LENGTH CODE 02 2.0" 04 4.0" 6.0" 06 08 8.0" 12 12.0" CUSTOM LENGTHS AVAILABLE UPON REQUEST C LENS MOUNT FIBER OPTIC SMD 22 SEAL RETAINING RING LENS B B .06in±.02 1.52mm±0.51 FIBER OPTIC LENGTH XX .25 THR 22 DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED A .X .XX .XXX THR 5 22 63 INCHES .020 .010 .005 ANGLE 1' MM .508 .254 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX APPROVAL DATE DRAWN KHOWARD 8/2/10 CHECKED AZANELLI 8/2/10 OPTOELECTRONICS 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com TITLE: MATERIAL SEE NOTES FLX 322 FLEXFIRE FLEXIBLE LITEPIPE THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 2:1 DO NOT SCALE DRAWING 2 FLX 322 XXX XX 004 SHEET 1 OF 1 1 A
FLX_322_YTP_12
1. 物料型号:文档中没有明确列出物料型号,但提到了“FLX 322 XXX”作为订购代码的例子。 2. 器件简介:文档描述了一种名为“LITE PIPE ASSEMBLY”的光纤产品,包括其光学特性和安装方式。 3. 引脚分配:文档中提到了SMD 22和THR 22作为LED安装选项,以及THR 5 22作为另一种选项。 4. 参数特性:文档提到了光学核心直径为1.5mm,聚乙烯电缆套直径为2.2mm,以及镜头材料为聚碳酸酯,UL评级为94-V2。 5. 功能详解:文档详细说明了产品的安装过程,包括压缩密封和面板安装。 6. 应用信息:文档提到产品具有大于100mcd的输出功率,并且有美国和外国的专利。 7. 封装信息:文档中提到了多种镜头类型和颜色,以及定制长度的选项。
FLX_322_YTP_12 价格&库存
很抱歉,暂时无法提供与“FLX_322_YTP_12”相匹配的价格&库存,您可以联系我们找货
