LP-330
LP-330
    BIVAR
    LIGHTPIPERIG3-LEVEL3MMSMD
LP-330 数据手册
REV. 2.775 [70.5mm] DESCRIPTION DATE G Engineering Release. 09/01/04 0.775 [19.7mm] APPROVED M. C. 0.132 [3.4mm] 0.100 [2.5mm] 1.544 [39.2mm] 1.594 [40.5mm] 1.294 [32.9mm] 1.044 [26.5mm] 0.062 [1.6mm] LED CLEARANCE 0.134 [3.4mm] 0.320 [8.1mm] 0.228 [5.8mm] 0.426 [10.8mm] 0.681 [17.3mm] 0.054 [1.4mm] 0.228 [5.8mm] 0.176 [4.5mm] 0.170 [4.3mm] TYP. 0.426 [10.8mm] Ø.060 +.003 -.002 0.171 [4.3mm] 0.255 [6.5mm] 0.176 [4.5mm] Recommended Mounting Holes 0.565 [14.3mm] 0.395 [10.0mm] 0.225 [5.7mm] STANDARD TOLERANCE DECIMALS .X ± .1 .XX ± .01 .XXX ± .005 2. MATERIAL: POLYCARBONATE, 94V-0, CLEAR. BIVAR MATERIAL CODE 47-CR. SAM YANG CORPORATION POLYCARBONATE 3025N2 CLEAR. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.  ( UNLESS OTHERWISE SPECIFIED ) DESIGNED: Michael Chen CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: CUSTOM LIGHT PIPE, 3 HIGH DATE: 04/07/04 DATE: 04/07/04 PART NO: LP-330 CAGE CODE : 32559 REVISION: G SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
LP-330 价格&库存
很抱歉,暂时无法提供与“LP-330”相匹配的价格&库存,您可以联系我们找货
