C13087_MIRELLA-50-W-PF
    LEDIL(芬兰)
    REFLECTOR RND 1POS 49.9MM 24MM
C13087_MIRELLA-50-W-PF 数据手册
PRODUCT DATASHEET C13087_MIRELLA-50-W-PF MIRELLA-50-W-PF ~40° wide beam TECHNICAL SPECIFICATIONS: Dimensions Ø 49.9 mm Height 24 mm Fastening socket ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour MIRELLA-50-W-PF Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C13087_MIRELLA-50-W-PF » Box size: 480 x 280 x 300 mm Qty in box 336 MOQ MPQ 112 28 Box weight (kg) 2.8 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF See also our general installation guide: www.ledil.com/installation_guide Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED V10 Gen6 FWHM / FWTM 39.0° / 79.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C14115_PF-SOCKET-CXA15-18 LED V10 Gen7 FWHM / FWTM 35.0° / 76.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED V10 Gen7 FWHM / FWTM 39.0° / 73.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL LED V10 Gen7 FWHM / FWTM 40.0° / 75.0° Efficiency 77 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED V6 Gen6 FWHM / FWTM 44.0° / 77.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED V6 Gen6 FWHM / FWTM 44.0° / 78.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED V6 Gen6 FWHM / FWTM 31.0° / 72.0° Efficiency 74 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 460 Typ L1 LED V6 Gen6 FWHM / FWTM 27.0° / 76.0° Efficiency 82 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 460 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED V6 Gen6 FWHM / FWTM 39.0° / 81.0° Efficiency 87 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED V8 Gen6 FWHM / FWTM 43.0° / 76.0° Efficiency 82 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED V8 Gen6 FWHM / FWTM 36.0° / 74.0° Efficiency 73 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 460 Typ L1 LED V8 Gen6 FWHM / FWTM 38.0° / 79.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED V8 Gen6 FWHM / FWTM 42.0° / 76.0° Efficiency 82 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED VERO10 FWHM / FWTM 44.0° / 76.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 C12479_MIRELLA-DL LED VERO10 FWHM / FWTM 44.0° / 76.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 C13333_MIRELLA-CL LED VERO10 FWHM / FWTM 40.0° / 79.0° Efficiency 85 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13708_PF-SOCKET-VERO10 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED VERO13 FWHM / FWTM 51.0° / 79.0° Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL LED VERO13 FWHM / FWTM 50.0° / 79.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL LED VERO13 FWHM / FWTM 46.0° / 82.0° Efficiency 90 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED Xenio Point 13mm FWHM / FWTM 48.0° / 80.0° Efficiency 78 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED Xenio Point 13mm FWHM / FWTM 45.0° / 81.0° Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED Xenio Point 13mm FWHM / FWTM 49.0° / 78.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL LED CLL01x FWHM / FWTM 36.0° / 80.0° Efficiency 90 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CLL01x FWHM / FWTM 44.0° / 76.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CLL01x FWHM / FWTM 42.0° / 76.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLL02x/CLU02x (LES10) FWHM / FWTM 41.0° / 76.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 LED CLL02x/CLU02x (LES10) FWHM / FWTM 36.0° / 77.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 LED CLL02x/CLU02x (LES10) FWHM / FWTM 41.0° / 80.0° Efficiency 90 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 46.0° / 77.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CLL02x/CLU02x (LES10) FWHM / FWTM 39.0° / 73.0° Efficiency 78 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED CLL02x/CLU02x (LES10) FWHM / FWTM 46.0° / 78.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLL02x/CLU02x (LES10) FWHM / FWTM 46.0° / 80.0° Efficiency % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CLU700/701/702 FWHM / FWTM 34.0° / 72.0° Efficiency 81 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CLU700/701/702 FWHM / FWTM 42.0° / 78.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CLU700/701/702 FWHM / FWTM 31.0° / 70.0° Efficiency 77 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 LED CLU700/701/702 FWHM / FWTM 26.0° / 73.0° Efficiency 83 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CLU700/701/702 FWHM / FWTM 29.0° / 69.0° Efficiency 80 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED CLU700/701/702 FWHM / FWTM 33.0° / 78.0° Efficiency 88 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CLU700/701/702 FWHM / FWTM 39.0° / 75.0° Efficiency 82 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CLU720/721 FWHM / FWTM 44.0° / 78.0° Efficiency 74 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 433 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CLU720/721 FWHM / FWTM 40.0° / 78.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 433 Typ L1 LED CLU720/721 FWHM / FWTM 43.0° / 74.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 433 Typ L1 LED CXA/B 13xx FWHM / FWTM 42.0° / 76.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED CXA/B 13xx FWHM / FWTM 43.0° / 76.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CXA/B 13xx FWHM / FWTM 37.0° / 80.0° Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED CXA/B 15xx FWHM / FWTM 39.0° / 75.0° Efficiency 75 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 46.0° / 79.0° Efficiency 85 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED CXA/B 15xx FWHM / FWTM 34.0° / 75.0° Efficiency 82 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 441 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CXA/B 15xx FWHM / FWTM 47.0° / 79.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED CXA/B 15xx FWHM / FWTM 37.0° / 72.0° Efficiency 79 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 47.0° / 81.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13723_MIRELLA-RZL LED CXA/B 15xx FWHM / FWTM 41.0° / 82.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 45.0° / 81.0° Efficiency 84 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C14115_PF-SOCKET-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 43.0° / 81.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2101CR + 50-2100MR LED MHD-E/G FWHM / FWTM 44.0° / 77.0° Efficiency 84 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED MHD-E/G FWHM / FWTM 45.0° / 83.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED MHD-E/G FWHM / FWTM 38.0° / 82.0° Efficiency 89 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MHD-E/G FWHM / FWTM 45.0° / 78.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED MK-R FWHM / FWTM 30.0° / 77.0° Efficiency 85 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MK-R FWHM / FWTM 34.0° / 73.0° Efficiency 80 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED MT-G FWHM / FWTM 48.0° / 87.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MT-G FWHM / FWTM 52.0° / 84.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED MT-G FWHM / FWTM 52.0° / 83.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED MT-G2 FWHM / FWTM 51.0° / 82.0° Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED MT-G2 FWHM / FWTM 46.0° / 86.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED MT-G2 FWHM / FWTM 50.0° / 81.0° Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED XHP50 FWHM / FWTM 39.0° / 76.0° Efficiency 82 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED XHP50 FWHM / FWTM 39.0° / 76.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED XHP50 FWHM / FWTM 38.0° / 77.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED XHP50 FWHM / FWTM 33.0° / 80.0° Efficiency 87 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED XHP70 FWHM / FWTM 42.0° / 77.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED XHP70 FWHM / FWTM 44.0° / 80.0° Efficiency 79 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED XHP70 FWHM / FWTM 39.0° / 82.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED XHP70 FWHM / FWTM 43.0° / 77.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED XM-L RGBW (XMLCTW) FWHM / FWTM 41.0° / 80.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED XQ-E HI FWHM / FWTM 42.0° / 82.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 4 Light colour RGBW Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 39.0° / 74.0° Efficiency 80 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED LUXEON CoB 1202/1203 FWHM / FWTM 41.0° / 75.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR LED LUXEON CoB 1202/1203 FWHM / FWTM 40.0° / 75.0° Efficiency 75 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 37.0° / 78.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 35.0° / 76.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 37.0° / 72.0° Efficiency 77 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 39.0° / 79.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET LED LUXEON CoB 1202s FWHM / FWTM 40.0° / 78.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1202s FWHM / FWTM 32.0° / 71.0° Efficiency 77 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 LED LUXEON CoB 1202s FWHM / FWTM 25.0° / 72.0° Efficiency 85 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 452 Typ L1 LED LUXEON CoB 1202s FWHM / FWTM 35.0° / 82.0° Efficiency 88 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED LUXEON CoB 1202s FWHM / FWTM 41.0° / 78.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1202s FWHM / FWTM 28.0° / 69.0° Efficiency 81 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 452 Typ L1 LED LUXEON Z FWHM / FWTM 36.0° / 75.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 4 Light colour RGBW Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CxM-6 (12x13) FWHM / FWTM 36.0° / 79.0° Efficiency 85 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED CXM-7 (13x13) FWHM / FWTM 38.0° / 79.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM 49.0° / 79.0° Efficiency 83 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED CxM-9 (13.5x13.5) FWHM / FWTM 48.0° / 78.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED CxM-9 (13.5x13.5) FWHM / FWTM 48.0° / 83.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED CxM-9 (13.5x13.5) FWHM / FWTM 44.0° / 82.0° Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 46.0° / 82.0° Efficiency 84 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET LED COB L-Type (LES 11) FWHM / FWTM 47.0° / 77.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 11) FWHM / FWTM 46.0° / 77.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 11) FWHM / FWTM 46.0° / 78.0° Efficiency 75 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 41.0° / 79.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM 43.0° / 80.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 11) FWHM / FWTM 45.0° / 75.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 38.0° / 78.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM 38.0° / 73.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13333_MIRELLA-CL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 9) FWHM / FWTM 39.0° / 73.0° Efficiency 80 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12479_MIRELLA-DL IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 9) FWHM / FWTM 35.0° / 77.0° Efficiency 87 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2100NC +50-2100MR LED COB L-Type (LES 9) FWHM / FWTM 40.0° / 75.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 438 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM 34.0° / 76.0° Efficiency 84 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 37.0° / 73.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 438 Typ L1 LED NSCxL036A FWHM / FWTM 34.0° / 76.0° Efficiency 85 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14037_PF-NSX-SOCKET LED Duris S10 FWHM / FWTM 43.0° Efficiency % LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED Duris S10 FWHM / FWTM 45.0° / 82.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED Duris S10 FWHM / FWTM 38.0° / 82.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Duris S10 FWHM / FWTM 45.0° / 81.0° Efficiency 79 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED OSTAR Stage (S2WP) FWHM / FWTM 36.0° / 78.0° Efficiency 83 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED Ostar-SMT RGB FWHM / FWTM 37.0° / 77.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED ZC4/6 FWHM / FWTM 42.0° / 82.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED ZC4/6 FWHM / FWTM 48.0° / 80.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED ZC4/6 FWHM / FWTM 46.0° / 78.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (MEASURED): LED Mini Zenigata (GW6BM) FWHM / FWTM 38.0° / 81.0° Efficiency 88 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Mini Zenigata (GW6BM) FWHM / FWTM 45.0° / 80.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL LED Mini Zenigata (GW6BM) FWHM / FWTM 46.0° / 78.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED XTM - 9mm LES FWHM / FWTM 35.0° / 76.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C14636_XTM-PF-ADAPTER Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED LUXEON CoB Compact FWHM / FWTM 35.0° / 82.0° Efficiency 88 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 LED LUXEON CoB Compact FWHM / FWTM 37.0° / 72.0° Efficiency 77 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 452 Typ L1 LED LUXEON CoB Compact FWHM / FWTM 25.0° / 72.0° Efficiency 85 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 452 Typ L1 LED LUXEON CoB Compact FWHM / FWTM 32.0° / 71.0° Efficiency 77 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED LUXEON CoB Compact FWHM / FWTM 41.0° / 78.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C13333_MIRELLA-CL LED LUXEON CoB Compact FWHM / FWTM 40.0° / 78.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED LUXEON K4 FWHM / FWTM 54.0° / 98.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 C12479_MIRELLA-DL LED LUXEON K4 FWHM / FWTM 46.0° / 84.0° Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13761_PF-SOCKET-CXA15 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM 49.0° / 72.0° Efficiency 75 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 433 Typ L1 LED CxM-14 (19x19) FWHM / FWTM 51.0° / 81.0° Efficiency 70 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 433 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 39.0° / 73.0° Efficiency 78 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 36.0° / 77.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED CxM-9 (13.5x13.5) FWHM / FWTM 41.0° / 76.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 28.0° / 69.0° Efficiency 81 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 452 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 25.0° / 72.0° Efficiency 85 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 452 Typ L1 LED COB S-Type (LES 7) FWHM / FWTM 32.0° / 71.0° Efficiency 77 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 452 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED Soleriq S15 FWHM / FWTM 56.0° / 86.0° Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 433 Typ L1 LED Soleriq S9 FWHM / FWTM 52.0° / 79.0° Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13333_MIRELLA-CL LED Soleriq S9 FWHM / FWTM 38.0° / 77.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 LED Soleriq S9 FWHM / FWTM 51.0° / 80.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C12479_MIRELLA-DL Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED Soleriq S9 FWHM / FWTM 46.0° / 82.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET LED Soleriq S9 FWHM / FWTM 50.0° / 80.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13083_PF-SOCKET C13723_MIRELLA-RZL LED LC010C FWHM / FWTM 32.0° / 74.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 479 Typ L1 LED LC020C FWHM / FWTM 35.0° / 75.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 479 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF PHOTOMETRIC DATA (SIMULATED): LED LC040C FWHM / FWTM 42.0° / 79.0° Efficiency 84 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 480 Typ L1 LED ZC4/6 FWHM / FWTM 39.0° / 73.0° Efficiency 78 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C13333_MIRELLA-CL Bender Wirth: 434 Typ L1 LED ZC4/6 FWHM / FWTM 36.0° / 77.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 Bender Wirth: 434 Typ L1 LED ZC4/6 FWHM / FWTM 41.0° / 76.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13709_PF-SOCKET-VERO13-18 C12479_MIRELLA-DL Bender Wirth: 434 Typ L1 Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 40/41 PRODUCT DATASHEET C13087_MIRELLA-50-W-PF GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/12/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 41/41
C13087_MIRELLA-50-W-PF 价格&库存
很抱歉,暂时无法提供与“C13087_MIRELLA-50-W-PF”相匹配的价格&库存,您可以联系我们找货
  • 1+41.888481+5.25290
  • 28+27.8347028+3.49053
  • 112+24.50774112+3.07332
  • 504+21.94605504+2.75208
  • 1008+21.042811008+2.63881
  • 2016+20.278752016+2.54300
    • 28+13.1002828+1.64280
    • 84+12.9232584+1.62060
    • 280+12.65770280+1.58730
    • 560+12.56919560+1.57620
    • 1120+12.392161120+1.55400
    • 28+15.1361428+1.89810
    • 112+14.95910112+1.87590
    • 420+14.69356420+1.84260
    • 700+14.60504700+1.83150
    • 1400+14.339501400+1.79820
    • 28+18.4997228+2.31990
    • 56+18.2341756+2.28660
    • 112+18.05714112+2.26440
    • 140+17.97197140+2.25372
    • 420+17.61457420+2.20890
