CX11524_LAURA-REF-W-WHT
    LEDIL(芬兰)
    REFLECTOR 1POS 21.6MM SQ 12.9MM
CX11524_LAURA-REF-W-WHT 数据手册
PRODUCT DATASHEET Laura series last update 17/9/2012 Ordering number CX11352_LAURA-RS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 11 degrees 93 % 16.850 Available FWHM Efficiency cd/lm Gerber File 13 degrees 93 % 11.800 Available FWHM Efficiency cd/lm Gerber File 18 degrees 93 % 4.000 Available FWHM Efficiency cd/lm Gerber File 31 degrees 88 % 2.170 Available Ordering number CX11645_LAURA-SS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready Ordering number CX11359_LAURA-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6X21.6 mm 12.9 mm Square PMMA PC Tape Ready Ordering number CX11354_LAURA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready November 12th 2012 20:16 Copyright Ledil Oy - Subject to change without prior notice - Page 1/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 17/9/2012 Ordering number CX11364_LAURA-O Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 38+14 degrees 93 % Available FWHM Efficiency cd/lm Gerber File 47 degrees 89 % Available FWHM Efficiency cd/lm Gerber File 68 degrees 81 % Available FWHM Efficiency cd/lm Gerber File 68 degrees 90 % 0.630 Available Ordering number CX12568_LAURA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready Ordering number CX11524_LAURA-REF-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Reflector LUXEON Rebel ES White 21.6 mm 12.9 mm Square PC PC Tape Ready Ordering number CX11768_LAURA-WW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 mm 12.9 mm Square PMMA PC Tape Ready November 12th 2012 20:16 Copyright Ledil Oy - Subject to change without prior notice - Page 2/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 17/9/2012 Ordering number CX12983_LAURA-REF-XW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Assembly LUXEON Rebel ES White 21.6 + 21.6 mm 12.9 mm Square PC PC Tape Ready FWHM Efficiency cd/lm Gerber File 72 degrees 84 % 0.640 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. November 12th 2012 20:16 Copyright Ledil Oy - Subject to change without prior notice - Page 3/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura series last update 17/9/2012 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON Rebel ES series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. November 12th 2012 20:16 Copyright Ledil Oy - Subject to change without prior notice - Page 4/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 Bottom view 21.6 4 Oval-version beam direction 3 3 Optic 12.9 Holder Front view Tape 2 2 Materials lens: PMMA holder: PC White Tape: PU Foam 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE Led Teh FIN Fin DRAWING TITLE pv 02.08.2010 sn 22.07.2010 DESIGNED BY hh DATE 21.01.2010 D SIZE Assy Datasheet Laura-tape series DRAWING NUMBER A4 SCALE 2:1 WEIGHT(g) REV CA11352 1 SHEET A 1/1 1
CX11524_LAURA-REF-W-WHT 价格&库存
很抱歉,暂时无法提供与“CX11524_LAURA-REF-W-WHT”相匹配的价格&库存,您可以联系我们找货
